    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    suunto race s wifi problem after update 2.39.20
    Scheduled Pinned Locked Moved Suunto Race S
    94 Posts 26 Posters 27.1k Views 25 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • D Offline
      disadisa
      Update suunto release ‘service announcement’ and confess issue with sw 2.39.20 and offer some workaround as a solution, while they are working on permanent fix. 🙂
      D 1 Reply Last reply Reply Quote 1
      • D Offline
        danudyk @disadisa
        @disadisa today i have successfully downgrade to 2.37.38
        check this link below
        https://www.suunto.com/Support/faq-articles/lifecycle/2.39.20-trouble-shooting/
        D 1 Reply Last reply Reply Quote 2
        • D Offline
          disadisa
          Update - I check suunto app on phone and saw notification about necessary steps to download downgrade sw version using firefox browser with enabled notification to be able current download open into suunto app. It worked, suunto app downloaded OTA 2.37.48 and transferred ono watch. I need help from you also, if someone has exact file name OTA package on watch started with Ulsan-fw_2.39.20… like on photo below? I need exact name of file Ulsan-fw_2.39.20 to be able to download that package also because I haven’t on my watch. In previous unsuccess attempt of downgrade sw version I had notification about safe restore and watch reverted to sw version 2.39.20. On that way I will have all necessary OTA package downgrade procedure to sw version 2.37.48 to be able for watch to revert itself to working sw version. Tahnk you.
          • D Offline
            disadisa @danudyk
            @danudyk Thanks
            • R Offline
              RichardP
              @disadisa Is the wifi working now on your race S with the new software update?
              • D Offline
                Dj_afrolexios
                Hello,
                After Update to 2.40.38 I can’t enable Wi-Fi on my Race S, both from phone or watch, so I can’t download offline maps.
                Is there anyone who has the same problem?
                A Lukmanul HakimL 2 Replies Last reply Reply Quote 1
                • A Offline
                  aiv4r Silver Members @Dj_afrolexios
                  @Dj_afrolexios yea, I have the same issue, cannot enable Wi-Fi in the watch and neither over the app.
                  Suunto Race 2 (Titanium Trail)
                  Suunto Vertical (Titanium Solar Forest)
                  • D Offline
                    disadisa @aiv4r
                    Hi to all, sorry for late answer. We tested watch intensively. Did not done upgrade on version 2.40.38, still on version 2.39.44. Everything working on version 2.39.44. If you have issue try to downgrade to previous version software. BR
                    • Lukmanul HakimL Offline
                      Lukmanul Hakim @Dj_afrolexios
                      @Dj_afrolexios have the same issue here, just bought race s yesterday, immediately upgrade to 2.40 firmware because i don’t know there is an issue on this firmware, it only connect to wifi for 3 second, then disconnected, tried downgrade to 2.35, but stuck on safe state mode.
                      C 1 Reply Last reply Reply Quote 1
                      • C Offline
                        cenkturkinan @Lukmanul Hakim
                        @Lukmanul-Hakim sadly no news from Suunto. I have a Race S. I was able to download maps before upgrading. Now not able to enable wifi connection.
                        A 1 Reply Last reply Reply Quote 0
                        • A Offline
                          aiv4r Silver Members @cenkturkinan
                          @cenkturkinan have you tried to do a reset?
                          Settings -> General -> Reset settings
                          I had the same issue, was not able to toggle wifi on after the upgrade, but after the reset it went back to normal.
                          C 2 Replies Last reply Reply Quote 1
                          • C Offline
                            cenkturkinan @aiv4r
                            @aiv4r thanks. I will try.
                            • C Offline
                              cenkturkinan @aiv4r
                              @aiv4r It worked!!! Thank you.
                              • Hafilat BalanceH Offline
                                Hafilat Balance Banned
                                after everything you already tested, this really does sound more like a firmware issue on the Suunto Race S after 2.39.20 than a router/network problem.
                                The interesting part is your router logs showing absolutely no connection attempt from the watch. That usually means the WiFi module itself is not initializing correctly after the update, not just failing authentication.
                                I d still try one last simple test: connect it to a very basic 2.4 GHz network without mesh/repeator features, WPA3, band steering, or hidden SSID. Some devices become weirdly picky after updates. But since you already tested multiple routers and hotspots, I honestly doubt your network is the real issue here.
                                Feels like the update broke WiFi handling for some units, especially since the problem started right after the firmware upgrade and before the maps could finish downloading.
                                Register Login
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
