    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    SV clocking a 7.9mi loop at 8.15mi. Is this the general margin of error with Suunto?
    Scheduled Pinned Locked Moved Suunto Vertical
    25 Posts 12 Posters 3.3k Views 12 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • leafs93L Offline
      leafs93 Bronze Member @Andrew_
      @Andrewx01 I faced the exact same issue. I have a Garmin 965, COROS apex 2 pro, Apple Watch 8 and I do wear my vertical together with the rest of my watches just to test out the distances. The distance on my Vertical will invariably be clocked at longer distance , ie for a 10km run , it will be 200m longer for my vertical compared to Garmin 965 and COROS apex 2 pro.
      When I use software to zoom in to the tracks, I can then understand where the extra distance came from as vertical tracks are more often zig Zac compared to the rest and I figured that must have been the reason. However, it seems vertical has the most accurate distance count by the experts. So I guess it should be.
      zhang965Z 1 Reply Last reply Reply Quote 0
      • zhang965Z Offline
        zhang965 @leafs93
        @leafs93 said in SV clocking a 7.9mi loop at 8.15mi. Is this the general margin of error with Suunto?:
        My vertical counts less distance when I run a little bit fast,; if I walk, it gives almost the same distance as epix2pro.
        I saw Suunto’s tester was running at 16mins/km to proof the good gps tracker, sadly I cannot keep running in such a pace.
        Have you tried run slower to see your vertical gps performance?
        Winners Wear Winners
        leafs93L 1 Reply Last reply Reply Quote 1
        • Mouse CruiserM Offline
          Mouse Cruiser Bronze Member @Andrew_
          @Andrewx01 IMHO the matter is quite simple. For example, if you take a perfectly flat road and measure a distance of 1 mile, a watch that measures the GPS location every second will make a tiny error in each measurement. If you run a mile in 5 minutes, that’s at least 300 locations and 300 small misses. The algorithm (and each watch manufacturer has different algoritm) compensates these small errors, of course, but in the end there is still a deviation from the measurement in a straight line and the calculation of the path after 300 locations. In your case the error is around 3 %, which could be smaller, but it could also be larger😕
          Suunto Vertical
          Suunto 9 Baro
          Suunto Spartan
          Suunto Ambit3 peak
          • EzioAuditoreE Offline
            EzioAuditore Gold Members @Brad_Olwin
            @Brad_Olwin Yes usually my AW gives me less distance too from cold start (their not so clever implementation to start the activity within 3 sec might be the case. So what I usually do is start an activity stop it after 5-10 sec - delete it and start again so the GPS lock should be much better).
            Suunto watches: Vertical 2 (Titanium Sage), Race 2 (Titanium Trail), Ocean (Sand), Race (Titanium Charcoal), Vertical (Titanium Solar Sand), 9 Baro (Ambassador Edition), Spartan Ultra (Copper Edition), Ambit 2, S6
            Suunto Wing
            • leafs93L Offline
              leafs93 Bronze Member @zhang965
              @zhang965 walking will definitely get more distance as the gps track will not be smooth and is more zig Zac.
              Register Login
              • First post
                Last post
              Suunto Terms | Privacy Policy
