    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Can't connect to wifi or hotspot
    Scheduled Pinned Locked Moved Suunto Vertical
    7 Posts 5 Posters 1.8k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • A Offline
      Arnaud
      Hi,
      I received my Vertical yesterday and have been unable to connect it to my wifi or hotspot.
      With my wifi, it detects the network, asks for credentials but then tells me that the password is wrong. (I’ve done this operation over a dozen times, copy-pasting the password and inputing it manually; it is not wrong.)
      With my hotspot, it just doesn’t detect it (it never shows in the list of networks).
      Thoughts?
      Brad_OlwinB pnevesP 2 Replies Last reply Reply Quote 0
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @Arnaud
        @Arnaud If you have comma or dash , or - or other characters the WiFi will not connect. Known but don’t know when or if it will be changed.
        Vector/T6c/Ambit 3 Peak/S5 Copper/S3/S7 Ti/S9 baro Ti/S9P Ti/S9PP Ti/Vertical Ti/Race Ti/RaceS/Ocean/Wing/Race2Ti
        A 1 Reply Last reply Reply Quote 0
        • A Offline
          Arnaud @Brad_Olwin
          Thanks for the reply, @Brad_Olwin. Unfortunately, that’s not the issue. Also, that doesn’t explain the lack of hotspot.
          Mff73M 1 Reply Last reply Reply Quote 0
          • Mff73M Online
            Mff73 @Arnaud
            @Arnaud
            Check also if your password contains the special characters Brad talked about.
            Also, WiFi or hotspot can only by 2.4Mhz ones
            Suunto Spartan Ultra (since 2016) FW: 2.8.24 (retired)
            Suunto Vertical all black
            Wife : S9PP
            SA: Always the latest beta :)
            Android 13, Galaxy S205G
            • A Offline
              Arnaud @Mff73
              Thanks, @Mff73
              My hotspot is set to 2.4MHz and the password doesn’t contain any special characters, so that’s not the issue either. Also, I’ve turned off my VPN, in case that makes a difference
              • Mff73M Mff73 referenced this topic on
              • pnevesP Offline
                pneves @Arnaud
                @Arnaud I had the same issue with Race yesterday. Closed the app and open again and it registered the network almost immediately. Hope it helps.
                Suunto Race owner since 24/10/2023
                • ? Offline
                  A Former User @Arnaud
                  @Arnaud I can say that @Mff73 helped sort out issues I had with WiFi and (in my case) crashing while downloading maps seen here.
                  https://forum.suunto.com/post/128049 and resolution here
                  https://forum.suunto.com/post/128067
                  I now run the Hotspot off my phone in compatibility mode and is very stable either with my data or public WiFi.
                  Thanks again @Mff73 you got my Vertical maps loaded!
                  • System referenced this topic on
                  • TieutieuT Tieutieu referenced this topic on
                  • First post
                    Last post
                  Suunto Terms | Privacy Policy
