    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain
    Scheduled Pinned Locked Moved Suunto Vertical
    760 Posts 137 Posters 348.1k Views 114 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • K Offline
      Kramble @Mff73
      @Mff73 said in Battery drain:
      @Kramble
      y tiens dans la main, y tiens dans la main 😂😂
      Désolé je l’avais raté 😂
      Ambit 3 peak saphir
      Spartan Ultra (sold)
      S7 graphite copper
      S9 peak all black
      Vertical titanium green forest
      Wings
      • stromdiddilyS Offline
        stromdiddily Gold Members @Ultrawalker
        @Ultrawalker said in Battery drain:
        When will the hotfix come?
        I wear my Vertical only for exercise.
        This week, my watch did nog use for 3 days…watch lay on a table and i saw a battery drain of 30%!
        Hope that a hotfix will solve this problem!
        Soft reset solves the problem - hold upper button for 12 seconds
        Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
        User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV2 :)
        D 1 Reply Last reply Reply Quote 0
        • D Offline
          duffman19 @stromdiddily
          @stromdiddily said in Battery drain:
          This is not a solution. It only delays the inevitable. And it also resets quite a few of the on-watch statistics like resources and the altitude and solar history charts. And it does not always work. I still sometimes see abnormal battery drain after a soft reset. And it’s terribly inconvenient if you use your watch to record several activities throughout the day.
          We’ve been a told a fix should be here by the end of September. I’ve still got my fingers crossed, but that leaves us with one more working day (unless Suunto releases updates over the weekend?). I’ve come to take any suggested timelines for releases with a (large) grain of salt.
          Vertical Ti / S9PP Ti / S9P Ti
          stromdiddilyS isaziI 2 Replies Last reply Reply Quote 4
            stromdiddily Gold Members @duffman19
            @duffman19 said in Battery drain:
            It solves the problem - of rapid battery drain post work out.
            By no means, is it or should it be the permanent solution. I think it’s quite clear given the direct interaction with Suunto folks in this thread and others regarding the behavior, that they are actively working on a fix
            Agreed regarding release timelines…mostly directionally correct 😄
            1 Reply Last reply Reply Quote 3
            • isaziI Online
              isazi Moderator @duffman19
              @duffman19 should have come this week already, but luckily for us Suunto developers found out some more battery drain issue and are trying to fix them too, so delayed to next week.
              Blog: isazi's home
              D Fenr1rF Antoine LancrenonA 3 Replies Last reply Reply Quote 6
              • D Offline
                duffman19 @isazi
                Thanks, @isazi. I do appreciate your updates and the devs work to solve this.
                • Fenr1rF Offline
                  Fenr1r @isazi
                  @isazi said in Battery drain:
                  And @thanasis
                  isaziI thanasisT 2 Replies Last reply Reply Quote 1
                  • isaziI Online
                    isazi Moderator @Fenr1r
                    @Fenr1r yes, but this happened only today. Hope the developers can also reproduce that, and fix it by next week
                    Blog: isazi's home
                    Fenr1rF 1 Reply Last reply Reply Quote 1
                    • Fenr1rF Offline
                      Fenr1r @isazi
                      @isazi Word. (I may have read too much into the swift interest of DK …)
                      • Antoine LancrenonA Offline
                        Antoine Lancrenon Bronze Member @isazi
                        ouha! it feels like it, that there are multiple RC of the drain issue. happy to see they found out various and not only one… good, now the last pattern of today reported, lets hope it will be fixed as well, as the flow is pretty much commun!
                        thank you for the update. We are almost their, i dont mind waiting a week more to be sure the hotfix is covering everything!
                        thank you!
                        • thanasisT Do not disturb
                          thanasis Bronze Member @Fenr1r
                          @Fenr1r it may be the same thing as the developers have identified .without knowing the facts I believe it is related to what we observe by starting an activity .
                            Dimitrios Kanellopoulos Community Manager @thanasis
                            @thanasis said in Battery drain:
                            changed the S+
                            entered the write HR setting (enabled/disabled)
                            went all the way down to the last item
                            thank you
                            Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                            • EgikaE Offline
                              Egika Platinum Member
                              Quick heads-up:
                              New FW is just under test with fix for battery drain issue.
                              If all goes well, it can hopefully be released within a few days 👍
                              Antoine LancrenonA AntoineA 2 Replies Last reply Reply Quote 19
                                Antoine Lancrenon Bronze Member @Egika
                                @Egika how many fixes have you found finally related to battery drain?
                                Any others bugs fixes coming along?
                                • AntoineA Offline
                                  Antoine Bronze Member @Egika
                                  @Egika said in Battery drain:
                                  Quick heads-up:
                                  Are there good feedbacks from tests ? 🤗
                                  Suunto vertical solar
                                  Coros arm HRM / Suunto wing 2
                                  Android A55 Samsung
                                  Suunto App latest official update
                                  • Danny polegD Offline
                                    Danny poleg Silver Members
                                    I just finished installing the update that came out a few hours ago
                                    This should take care of some of the battery issues
                                    Ars VitaeA 1 Reply Last reply Reply Quote 1
                                    • Ars VitaeA Offline
                                      Ars Vitae Silver Members @Danny poleg
                                      @Danny-poleg said in Battery drain:
                                      Of some problems related to battery drain, specifically only those related to navigation : “fixed a case where power consumption remained high after navigation”. Am I wrong, or were there other causes of the problem?
                                      Danny polegD 1 Reply Last reply Reply Quote 2
                                        Danny poleg Silver Members @Ars Vitae
                                        @Ars-Vitae I did not suffer from any problems with the battery, I only know from this forum that there were various problems
                                        Ars VitaeA 1 Reply Last reply Reply Quote 0
                                        • Mff73M Offline
                                          Mff73
                                          hey guys, now WE have one fix for battery drain, let ALL people who were experiencing issues to come back with feedbacks, instead of speculating wether all cases are fixed or not.
                                          It might be iterative process.
                                          My first feedback : i was 26% of battery before the update, and it was 26% after the update, it seems to work 🥳
                                          SSU (retired), SV1, SV2
                                          Wife : S9PP
                                          SA: Always the latest beta :)
                                          Android + Galaxy S205G
                                          ? Ars VitaeA 2 Replies Last reply Reply Quote 0
                                          • ? Offline
                                            A Former User @Mff73
                                            @Mff73 Good call! I took the liberty to charge my watch while I installed the new FW and plan on doing a ride after work to confirm. I was one of the ones affected by the battery drain (8-10% daily drop) and run navigation during activities.
                                            Currently at 99% and will keep the forum posted on battery usage.
                                            ? 1 Reply Last reply Reply Quote 3
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
