    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Stryd
    Scheduled Pinned Locked Moved Suunto Vertical
    105 Posts 21 Posters 32.5k Views 22 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • L Offline
      loopylou72 @tiago
      @tiago so I did the comparison runs, Vertical power and my old Peak connected to Stryd as a foot pod not calibrated. My weight the same on all devices. This time the Stryd gave less distance 6.25km with 155w (in the race I had more distance) and 9w more power than the Vertical 6.36km with 146w (mayeb due to the difference in distances). Was on a rocky trail but open on a ridge. In my miler I will use the Vertical GPS and the Stryd separately not connected to my watch and see what I get! Thanks for everyone’s help.
      tiagoT L 2 Replies Last reply Reply Quote 0
      • tiagoT Offline
        tiago Bronze Member @loopylou72
        @loopylou72 I use stryd uncalibrated on Garmin,but the distance and pace came from Garmin,is a big plus on Garmin we have that option and in all of my runs the difference between Suunto Race power and Stryd is about 1 or 2 wats most of the times,I even did a offline sync with stryd to check if the power numbers are the same provided by Garmin+stryd and in my 6 runs with both in the end the power was almost the same on both. The only situation where stryd could be more reliable as source of power is in runs where you have strong head wind, because Suunto doesn’t have wind detection like stryd.
        • L Offline
          loopylou72 @loopylou72
          @loopylou72 so I used the Stryd separately in my race but out of habit offline synced it with the app, and it merged which watch data, not sure how that can happen as I didn’t use Stryd connected to my watch at all. I guess my watch was set to upload to the Stryd app? Is there a way to see only the Stryd data?
          tiagoT 1 Reply Last reply Reply Quote 0
          • tiagoT Offline
            @loopylou72 in order to only have stryd data you can’t have your Suunto account connected with stryd, otherwise the data from Suunto goes to stryd
            L 1 Reply Last reply Reply Quote 0
            • L Offline
              loopylou72 @tiago
              @tiago OK thanks
              R 1 Reply Last reply Reply Quote 0
              • R Offline
                RightNow Bronze Member @loopylou72
                What happens if you connect the Stryd pod as a power pod instead of a foot pod. Is that possible? It seems only power is used in that case.
                R isaziI 2 Replies Last reply Reply Quote 0
                • R Offline
                  RightNow Bronze Member @RightNow
                  @RightNow New year. Same question 😂. When will it come? 😎
                  isaziI 1 Reply Last reply Reply Quote 0
                  • isaziI Offline
                    isazi Moderator @RightNow
                    @RightNow if you pair as power pod, you only get power and not pace, cadence, etc.
                    Blog: isazi's home
                    • isaziI Offline
                      @RightNow what?
                      Blog: isazi's home
                      • FunkyLarmaF Online
                        FunkyLarma
                        Hi Stryd users, can I just confirm the usage of a Suunto with and without the new Suunto+ Stryd app and what to pair my Stryd as.
                        My understanding is that if I use the Suunto+ Stryd app it will display some of the metrics in realtime, but I think I have read somewhere that you need to remove the connection to the Stryd to get it to pair from the app. Can anyone confirm?
                        If I did not want to use the Suunto+ app and just paired the Stryd to the watch I would still get power readings from the pod and would need to do the double sync method to get the gps watch track into PowerCenter with the full metrics? To which what do I pair as; power pod or foot pod?
                        Cheers!
                        herlasH 1 Reply Last reply Reply Quote 0
                        • herlasH Offline
                          herlas Silver Members @FunkyLarma
                          @FunkyLarma correct, you won’t be able to use the new S+ Stryd app if Stryd is enabled as footpod or power pod under the sensors option in the pre-run screen, no need to remove Stryd completely from the watch, just make sure you turn it off in sensors when you want to test the S+ app.
                          Check out my initial feedback on the S+ Stryd app.
                          https://forum.suunto.com/post/139268
                          For the other Qs, the new S+ is not a replacement of the offline sync, in fact, I’ve just discover from Stryd directly they’re not merging their data with Suunto when we use the new S+ app, the feature is not there, so basically you’ll have two workouts in power center, this is not good at all.
                          And you can pair it as power pod if you only want power data coming from Stryd, if you want power, distance, pace and cadence from the Stryd, pair it as footpod, heck, you can pair both ways and it’ll work.
                          I always use it as footpod (don’t forget to turn off auto calibration after pairing), I like having 0 issues when I run through underpass in my city, or GPS affected by very tall buildings ( city runner here 🙂 ) etc etc.
                          And when I’m doing power-based intervals I also enable it as power pod to get power avg lap reported on the lap screen instead of avg pace 😉
                          Hope this helps.
                          SRS Ti
                          SRun (primarily road runner so testing SRun is a must ;))
                          FunkyLarmaF 1 Reply Last reply Reply Quote 1
                            FunkyLarma @herlas
                            @herlas thank you for the reply, I did find your feedback review after I posted; just finding my feet in the forum.
                            It does kind of feel like a missed opportunity with this ‘integration’ at present. Not sure if this is the start of a deeper integration but the lack of recording all metrics and the syncing does not really feel like using the app has much benefit.
                            Personally, like you, I prefer the pace coming from Stryd as it does feel more responsive; at least on Garmin and Wahoo. Most of my workouts are power based but I’m not looking at Air Power or Form during a workout, post analysis yes but when you have your head down I just want to know if I’m hitting targets. Which sort of puts me in the ‘pair as a foot pod’ camp.
                            Also did note your comment on Suunto Guides for Stryd workouts, which would be great. Currently I build most of mine in TrainingPeaks and so far have made the most of the Stryd plans or workouts. Fingers crossed for deeper integration.
                            herlasH 1 Reply Last reply Reply Quote 1
                            • herlasH Offline
                              @FunkyLarma right, at least the thing finally came, now the big question is, can they have gone for a regular S+ app instead of a device type ? Stryd was already talking to our Suunto watches in a native way if you know what I mean 😉
                              If displaying Stryd metrics and saving them to the workout is possible with a regular S+ app, that would be cleaner and more functional for everyone.
                              Any ideas on that? Thx
                              SRS Ti
                              FunkyLarmaF 1 Reply Last reply Reply Quote 0
                                FunkyLarma @herlas
                                @herlas very true. When I started running just over a year ago I really struggled, but as a cyclist, running with power was easy to understand; paces always confuse me as I have no idea what a 5k pace is 😉
                                My biggest complaint with Stryd is not the platform or the device but more the company and customer support. It is not as easy to understand and my experiences of their forums or Facebook group can be quite aggressive. I really think they could benefit from a bit more in terms of documentation and user guides, not everyone is a science and tech savvy as they are.
                                Had confirmation from DPD that my first Suuntu will be delivered this afternoon so hoping to test some settings over the coming days 👍
                                K 1 Reply Last reply Reply Quote 1
                                • F Offline
                                  far-blue
                                  I’m much the same - I actually originally purchased a stryd to use as a footpad when the milestone pods stopped being supported. I run a lot of canal routes which in summer with the tree cover have some really bad spots for gps. According to the average gps trace I swim more than run and I run through people’s houses rather than round a gentle curve of the canal path!
                                  However I did then start using power as another metric and have found it hugely useful so I use it for steady runs (easy, tempo & long) on more undulating terrain and also for most of my races. I’d use it more if TrainAsOne could generate power-based workouts but I’m too lazy to copy them and convert them when they sync to my watch so smoothly as pace-based workouts.
                                  • K Offline
                                    kurtpenter Bronze Member @FunkyLarma
                                    @FunkyLarma Hey! how did it go with Suunto and Stryd? did you get what you where looking for?
                                    • R Offline
                                      RightNow Bronze Member @kurtpenter
                                      I recently had so much trouble with Stryd and accuracy that I ditched the pod. The service is so bad that they are blocking people in their forums. Changing shoes definitely will need a new calibration factor. And their you have the problem: No way to manually enter a calibration factor in the Suunto Ecosystem. Especially when changing shoes: no way. The only chance is to use the Stryd + App. Which has its own hiccups.
                                      I cannot recommend the pod and the company at all
                                      F EzioAuditoreE 2 Replies Last reply Reply Quote 0
                                      • F Offline
                                        far-blue @RightNow
                                        @RightNow You can’t manually add a calibration factor but you can get the watch to calibrate from GPS. If you go to the stryd pairing settings you can select ‘calibrate from GPS’ then go for a run somewhere you know you will get a solid gps lock. I’ve never felt a need to calibrate my 2nd gen stryd so I’ve not tried it myself but the theory is sound. Just remember to untick the option afterwards if you regularly run where gps isn’t solid.
                                        Although I use my stryd on every run I do note that my Race S is perfectly capable of providing a power value. My use of the stryd is for pace rather than power because it’s much more reactive and responsive than using GPS for pace. As such, calibration isn’t quite so important to me. I also run a lot along canals where there’s a lot of tree cover and even the best gps track can end up jumping from one side of the canal to the other which can throw pacing so a footpod is just more consistent. For races I generally download the GPX files and use snap to route navigation for more accurate distance and ETA.
                                        • R Offline
                                          RightNow Bronze Member @far-blue
                                          @far-blue That procedure does only work in case you are always wearing the same shoes. I need different calibration factors for every shoes. So annoying. Result: Ditched the stupid inaccurate and expensive pod. The power value from Suunto is good enough.
                                          KetoohsK 1 Reply Last reply Reply Quote 0
                                          • KetoohsK Offline
                                            Ketoohs Silver Members @RightNow
                                            @RightNow I am only using stryd on the treadmill, to give me a better approximation of the pace and distance. Stryd is usualy about 10-15s slower per km as the treadmill (gets better with higher speeds).
                                            Suunto is extremely bad when it comes to treadmill speed. I can do an exact same run on the treadmill (lets say 5:00 per km) and if the last outside run was a faster run (4:30 per km) them the treadmill run will be around 4:40-4:45. If i do the last run before treadmill at slow speed (5:30 per km) the 5:00 run on the treadmill will be in the ballpark of 5:40. 😠
                                            Karoo3 (2024)
                                            Vertical allBlack (2023)
                                            9 Peak Black (2022)
                                            Spartan WHR Black (2017)
                                            Ambit 2 Black (2013)
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
