    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Stryd
    Scheduled Pinned Locked Moved Suunto Vertical
    105 Posts 21 Posters 32.5k Views 22 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • R Offline
      RightNow Bronze Member @Guest
      Many thanks for all the information. In summary: The support is great except I have to do an offline sync (That’s acceptable). And the upcoming Suunto plus app is at least promising (because we don’t know what’s included).
      Order is placed 😊👍
      • ? Offline
        A Former User @RightNow
        @RightNow Well, offline sync isn’t an amazing requirement, but it takes 10-15 sec at most and I have to go Stryd app anyways to add shoe information, set workout type, etc.
        I believe it’s a decent trade-off for having all the features above, your workout in Training Peaks with clean* Stryd power data, and full workout details in Power Center.
        (* By clean I mean you have only Stryd power data in your file. If you are using Garmin, there’s no way to disable Garmin running power for Stryd app, so both data streams get exported. And while Runalyze would ignore Garmin’s data and use Stryd, TP is kind of a mixed bag. In some places they use Stryd data and in others – like summaries – they use Garmin’s. Total mess.)
        • herlasH Offline
          herlas Silver Members
          I’d say if you’re new to running power, SV wrist-based should be a good enough starting point. If you have STRYD already and believe you don’t need it, that’s probably true, everyone has different needs/requirements.
          In my case, I made the switch to power-based training couple of years back and love it, it keeps me pushing forward. FTP is a moving metric depending on my current level of fitness. It’s motivational for me as well, receiving FTP updates after a PR race or hard workout is so much fun too.
          I own the next Gen STRYD and looking forward to the Stryd S+ app.
          My only issue on the Suunto side is the power zone Z4 upper limit being the fixed value for FTP. As a result, I have to set TSS from TP to all my Suunto workouts all the time, as my FTP is not by any means close to that Z4 upper limit.
          Options are great to have, if you want to take a full transition to running with power, my opinion is that any wrist-based power isn’t probably enough,it’s just a small taste 😉
          SRS Ti
          SRun (primarily road runner so testing SRun is a must ;))
          seanvkS 1 Reply Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator @Guest
            @NickK said in Stryd:
            Do you know if it’s just an S+ app similar to Training Peaks ones that displays other Stryd metrics and perhaps allows to automatically sync them all to Stryd Power Center, - OR - we will get S+ guides for their training plans/calendar?
            As far as I know, it shows the metrics and saves them to activity (so you see them in SA too). For the training plans, I think they do not need a special app, Stryd could just create guides like other parties do.
            Blog: isazi's home
            • ? Offline
              A Former User @isazi
              @isazi Yes, I meant S+ guides for Stryd. When you say it saves, I assume it saves the entire time series, not just some summaries or what not? So, there’s no longer a need for offline sync and auto-merge?
              isaziI 2 Replies Last reply Reply Quote 0
              • isaziI Offline
                @NickK that’s my assumption, I can test it during the weekend.
                Blog: isazi's home
                • seanvkS Offline
                  seanvk @Guest
                  @NickK That’s a great summary on the support and has been my experience using Stryd with Garmin and Suunto. But now with native running power, I’ve just been using my 8020Endurance running plans (power based) on TP without Stryd entirely. I do recognize that I’ll periodically need to do running tests to adjust my ftp, but I do that anyway as a part of the 8020Endurance training plans.
                  Suunto Race Titanium
                  Suunto Vertical Titanium
                  Suunto 9 Peak Pro Forest Green
                  Suunto 9 Peak Moss Gray
                  • seanvkS Offline
                    seanvk @herlas
                    @herlas said in Stryd:
                    This is a challenge with all device makers. Device makers try to define zones that work best with their their training and load methodologies. When a user is working with a third party training plan which defines its own zones, it’s like trying to merge multiple different paradigms. Stryd has theirs and so does Matt Fitzgerald’s 80/20.
                    It’s a no win scenario
                    seanvkS ? herlasH 3 Replies Last reply Reply Quote 0
                    • seanvkS Offline
                      seanvk @seanvk
                      @seanvk just to add that the real saving grace here is that TP sends only the power ranges for each segment. It still messes with device maker’s zone mapping. But if you use external platforms like TP, FS, and Intervals.icu you can set your zones from a range of methodologies. You do your post workout analysis there and not through Sunnyo’s SA or Garmin’s Connect.
                      • ? Offline
                        A Former User @seanvk
                        @seanvk I follow 80/20 zones too.
                        So, my solution is to anchor my 4/5 zone in the watch to the top of my Zone 3 in Training Peaks (i.e. 3/Y in 80/20 lingo). That gives me accurate pTSS/rTSS/hrTSS in Suunto app without any need for updating TSS in workouts to make them match what I have in TP. The lower zones like X, 2, and 1 then follow. The top zones get all lumped up into 5 in the watch, which is fine as it is unlikely I’ll ever be targeting any of them outside the intervals/repeats anyways. And I can still use lower “gears” for my intensity targets on recovery/easy/long runs without structured workouts.
                        For training, I’m relying on TP and expressing all my intensities as % of pace/power threshold, and so the exact zones are somewhat of a moot point. Stryd gets my TP workouts and is able to show how well I match the power targeted just fine. Most of their analytics is driven by time spent at % of CP.
                        The only thing that is broken in this scheme of things is time spent in specific Stryd zones. Well, you can’t have everything!
                        • herlasH Offline
                          herlas Silver Members @seanvk
                          @seanvk power zones are one thing, TSS calculation doesn’t uses power zones at all, it’s relative to the % of FTP used during your workout and its length.
                          TP allows you to set FTP alone, and you can set whatever power zones schema you want.
                          SRS Ti
                          ? seanvkS 2 Replies Last reply Reply Quote 0
                          • ? Offline
                            A Former User @herlas
                            I think the problem people have is that for TSS to work properly in Suunto watches FTP has to be anchored in 4/5 zone boundary while Stryd, for example, puts it into 3/4. Hence, if you want your watch zones match your Stryd zones for training, your TSS and other analysis – like Coach stuff – will be off.
                            R herlasH 2 Replies Last reply Reply Quote 0
                            • R Offline
                              Too confusing to me what was written. If I am using a TrainingPeaks plan. What is to be done to run excactly the plan with the power Ranges described in TrainingPeaks?
                              What issues are expected?
                              I can’t follow you
                              herlasH 1 Reply Last reply Reply Quote 0
                              • herlasH Offline
                                herlas Silver Members @Guest
                                @NickK that’s exactly what I’ve described as my only issue on the Suunto side, until FTP can be set alone, meaning not dependant of power zones, people will have to do what either you do, adjusting Z4 to fall into your FTP value or what I do, adjusting TSS on Suunto workout every single time as it gets undercalculated. (I opt for the last as I find the power zones ring and power zone targets so useful on my Suunto watch 😉 )
                                SRS Ti
                                • herlasH Offline
                                  herlas Silver Members @RightNow
                                  @RightNow long history short, if your FTP isn’t matching the Suunto Z4 upper limit, the Suunto watch will underestimate your TSS for any given workout, TP will show you the correct TSS though.
                                  As far as the workout execution, nothing changes you should be fine there
                                  SRS Ti
                                  • seanvkS Offline
                                    seanvk @herlas
                                    Yes, I do that. I set 80/20 zones and my FTP in TP and intervals.icu. I just don’t pay attention to SA due to their zone definition.
                                    R 1 Reply Last reply Reply Quote 0
                                    • R Offline
                                      RightNow Bronze Member @seanvk
                                      Sorry that I have to ask again. What I understand is that I can use Stryd structured workouts described in TrainingPeaks and everything will be fine. The only thing is to do the offline sync.
                                      Now the topic I don’t understand excactly. What I have to care about is to align the power setting on my new vertical watch. Right? Between zone 4 and 5 should be the FTP.
                                      But still I have the feeling from your writing/posts before that still something will be wrong or not usable with those settings. Right or wrong?
                                      • ? Offline
                                        @RightNow said in Stryd:
                                        If you don’t care about advanced Stryd metrics like vertical oscillation or leg springiness or form factor no offline sync is required. The offline sync will only bring these to the workouts uploaded by Suunto.
                                        If you don’t set your FTP in Zone 4/5 on the watch, TSS calculated by the Suunto app will be off, and so will be your Progress Report and some of the data in Training Zone in the app. You’d be able to fix that by manually changing TSS for your workouts based on TP values.
                                        Neither TP, nor Stryd care about how your watch is setup specifically.
                                        • isaziI Offline
                                          @NickK I can see at least power and ground contact time in the graph, so not just averages but all recorded values. Cannot say much for other aspects (I only did one test).
                                          Blog: isazi's home
                                          • ? Offline
                                            @isazi You mean in Suunto app workout analysis, after you used that much rumored about Stryd S+ app?
                                            Yes, that’s how I imagine it would work based on what I’m seeing from Fat Burner that gives you not only the averages that go into split/workout summaries but also the actual time series.
                                            isaziI 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
