    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    No-Map-Problem
    Scheduled Pinned Locked Moved Suunto Vertical
    299 Posts 65 Posters 109.0k Views 62 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • surfboomerangS Offline
      surfboomerang
      Somewhat similar issue here. Map from a region in The Netherlands seems to work OK, but today I noticed a square black grid spot (approx 1 km²) in it where there was no map. Once I zoomed out to 500m it showed me the map in that part. When I zoom in it disappeared again.
      Re-download the map for this case also?
      Suunto Vertical Titanium Solar
      OnePlus Nord 4
      Dimitrios KanellopoulosD zhang965Z 3 Replies Last reply Reply Quote -1
        Dimitrios Kanellopoulos Community Manager @Guest
        @twekkel I agree
        Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
          Dimitrios Kanellopoulos Community Manager @surfboomerang
          @surfboomerang no that sounds like some render issue.
            @surfboomerang lets wait for the hotfix but you can try to redownload
            surfboomerangS 1 Reply Last reply Reply Quote 1
            • zhang965Z Offline
              zhang965 @surfboomerang
              @surfboomerang said in No-Map-Problem:
              Same there , my Paris map is partially missing
              Winners Wear Winners
              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                surfboomerang @Dimitrios Kanellopoulos
                @Dimitrios-Kanellopoulos Is a re-download also necessary after the hotfix? In that case I will wait patiently until the fix has been released.
                OnePlus Nord 4
                  Dimitrios Kanellopoulos Community Manager @zhang965
                  @zhang965 some coordinates ?
                  zhang965Z 1 Reply Last reply Reply Quote 0
                  • zhang965Z Offline
                    zhang965 @Dimitrios Kanellopoulos
                    @Dimitrios-Kanellopoulos said in No-Map-Problem:
                    It was around here: Bd Poissonnière, 75002 Paris
                    Dimitrios KanellopoulosD surfboomerangS 2 Replies Last reply Reply Quote 1
                      @zhang965 also please logs and pm me your sa account username
                      zhang965Z 2 Replies Last reply Reply Quote 0
                      • zhang965Z Offline
                        Logs sent my account is VFFCL
                          @zhang965 merci
                          • zhang965Z Offline
                            And I saw another issue about the route…
                            The route became alive, it’s became a triangle and move to different direction
                            Screenshot_2023-05-18-20-28-14-71_965bbf4d18d205f782c6b8409c5773a4.jpg Screenshot_2023-05-18-20-28-09-07_965bbf4d18d205f782c6b8409c5773a4.jpg Screenshot_2023-05-18-20-28-04-93_965bbf4d18d205f782c6b8409c5773a4.jpg
                              surfboomerang @zhang965
                              @zhang965 yes, looks like the same issue. Does the missing piece appear if you zoom out to 500m?
                              OnePlus Nord 4
                              • seanvkS Offline
                                seanvk @Guest
                                @twekkel I agree. Today, went on a 2 hour hike , we grabbed some lunch and wanted to explore the map on my watch. But the screen stayed black (just like this morning after installing it) because I didn’t have a fix inside. This is poor user experience. It could easily use last known location and still search in the background while letting me pan around on the pretty map.
                                Suunto Race Titanium
                                Suunto 9 Peak Pro Forest Green
                                Suunto 9 Peak Moss Gray
                                Brad_OlwinB 1 Reply Last reply Reply Quote 1
                                • Brad_OlwinB Offline
                                  Brad_Olwin Moderator @seanvk
                                  @seanvk The last location is not a good idea IMHO, I often run 20k to 50k from home and that would be a problem for me. I can imagine many other scenarios as well. I personally have not had any map issues in over a month in 3 different US states. I think at this time the map issues are infrequent based on the information I have.
                                  Vector/T6c/Vertical 2 Ti
                                  seanvkS 1 Reply Last reply Reply Quote 1
                                  • seanvkS Offline
                                    seanvk @Brad_Olwin
                                    @Brad_Olwin Understand. I’m just used to that from other devices. It’s a bit surprising for me. I’ll agree that last known location can rapidly lose relevancy over time and distance.
                                      @seanvk The map problem I hope is very limited. Suunto will get this taken care of quickly.
                                      • Mff73M Offline
                                        Mff73
                                        At first, I hadn’t any map issue. First activity OK. And during a test, bam no map despite a GPS fix. Soft reset make it back.
                                        About GPS fix needed. I would also vote for being able to see the map, either with latest known GPS postion, or even being able to focus on a POI. Select a POI on the watch, you have a map around it : you can explore the map around.
                                        Last point, navigating to a POI doesn’t show any direction on the map screen?? Need to switch from MAP to compass view. While just a little blue arrow on the map would be good.
                                        SSU (retired), SV1, SV2
                                        Wife : S9PP
                                        SA: Always the latest beta :)
                                        Android + Galaxy S205G
                                        surfboomerangS 1 Reply Last reply Reply Quote 8
                                          surfboomerang @Mff73
                                          @Mff73 said in No-Map-Problem:
                                          +1
                                          OnePlus Nord 4
                                          Mff73M 1 Reply Last reply Reply Quote 1
                                          • Mff73M Offline
                                            Mff73 @surfboomerang
                                            @surfboomerang
                                            Idea can be extended to routes as well : select a route, no GPS fix or far from this route, then being able to explore the map around that route 😊.
                                            Wife : S9PP
                                            renton82R 1 Reply Last reply Reply Quote 4
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
