    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    No-Map-Problem
    Scheduled Pinned Locked Moved Suunto Vertical
    299 Posts 65 Posters 117.0k Views 62 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Majkel PaszekoM Offline
      Majkel Paszeko @Egika
      @Egika Thanks for clarifying this. One more ask, can you somehow figure out if this map upgrade was also supposed to fix this very issue of hanging maps and eventually crashing whole watch on certain “black magic spots”, which this thread is acctually about? The issue that Pavel referred as processing some geometry bug.
      Since this issue - when unluckly happened - is the worst about map interface, this info would be important factor for decision to upgrade maps or not.
      EgikaE 1 Reply Last reply Reply Quote -1
      • EgikaE Offline
        Egika Platinum Member @Majkel Paszeko
        @Majkel-Paszeko no idea. Let’s check if @pavel-samokha can share more insights.
        pavel.samokhaP 1 Reply Last reply Reply Quote 0
        • pavel.samokhaP Offline
          pavel.samokha @Egika
          Opinions expressed are solely my own and do not express the views or opinions of my employer
          • MiniForkliftM Offline
            MiniForklift Platinum Member
            I now have the black screen issue with maps, first time I’ve encountered this. Loaded up the same route I ran yesterday but now the screen is essentially just a breadcrumb like my old S9B. No grid lines or anything, the background is just a solid black screen
            Did a soft reset and tried again but no luck. Hopefully the next update will restore the maps back to the excellence that they were
            SV Titanium Solar Forest
            TieutieuT 1 Reply Last reply Reply Quote 0
            • TieutieuT Offline
              Tieutieu Platinum Member @MiniForklift
              @MiniForklift try to stop your SV and restart it. Every (few) time I had the no map issue, soft reset didn’t solved but restarting my SV dit work
              Suunto’s devices at home :
              Vertical titanium solar
              Suunto Race S
              S9pp titanium sand
              Suunto Wing & Spark
              S9B titanium Ambassador edition, A3P, X6
              MiniForkliftM 2 Replies Last reply Reply Quote 0
                MiniForklift Platinum Member @Tieutieu
                @Tieutieu said in No-Map-Problem:
                Thanks. Do you mean stop and then restart it during an activity?
                • AlexanderA Offline
                  Alexander
                  A short walk with the map update.
                  Ambit 3 Peak / S9 Baro / Vertical Titanium Solar
                  Majkel PaszekoM TieutieuT 2 Replies Last reply Reply Quote 1
                  • TieutieuT Offline
                    @MiniForklift nope : go to « settings/general/stop the watch ».
                    No way to solve it during activity.
                    Let us know if it solved !
                    Suunto Race S
                    S9pp titanium sand
                    Suunto Wing & Spark
                      Majkel Paszeko @Alexander
                      @Alexander Thanks for sharing this. So it’s clear that map update didn’t fix the major map issue.
                        Thank you. I powered off and left it for 5mins or so and now the maps are working as normal. Merci @Tieutieu
                        TieutieuT 1 Reply Last reply Reply Quote 2
                        • TieutieuT Offline
                          @MiniForklift cool ! Glad to hear it solved !
                          I also noticed that when I go the first time to the map screen during an exercise, there is some kind of short « loading time », and if I too quickly try to use zoom button or navigate on map, I can have some black grid (and most of time it dissapears very quickly). Now I just wait a few seconds and since then I didn’t had the problem again.
                          Suunto Race S
                          S9pp titanium sand
                          Suunto Wing & Spark
                          • TieutieuT Offline
                            Tieutieu Platinum Member @Alexander
                            @Alexander did you tried what I suggested : just stop your watch (not a soft reset, just a simple « turn off » thru settings/general menu ?
                            Then turn it on.
                            Suunto Race S
                            S9pp titanium sand
                            Suunto Wing & Spark
                            AlexanderA Majkel PaszekoM 2 Replies Last reply Reply Quote 0
                              Alexander @Tieutieu
                              @Tieutieu
                              No, I only read that afterwards. I’ll test it tomorrow.
                                Majkel Paszeko @Tieutieu
                                @Tieutieu This thread is about very specific map issue, when “black grid” is starting showing ONLY when visible map area is covering certain locations, causing the whole watch malfunctioning and eventually crashing. For this issue stopping/starting watch doesn’t any help. I have such “black magic” spot right couple kilometers from my home. Every time i’m running there with maps on i’m having this issue. Even staying home and just moving maps there i reproduce this crash every single time. No issues with maps in many other locations where I used them. Stopping/starting has the same effect as soft reset in my case, means my SV crashes on “black magic” spot after stopping/stsrting as well as after soft reset.
                                S 1 Reply Last reply Reply Quote 0
                                • S Offline
                                  Shrek3k @Majkel Paszeko
                                  I tried the method to switch off the watch temporary, after SW did not at all solve the map issue.
                                  Unfortunately it does not help either. Even with the updated maps zooming out works until 500m, at 1000m parts of the map are missing (and do not reappear) and 2000m only shows the black Grid without any map.
                                  And, overall the watch reacts incredibly sluggish and slow, to move from one screen to the next does not work properly, it requires several seconds (using the buttons, as touch does not work at all) to move from one to the next, and sometimes screens are skipped.
                                  Currently I am a little bit frustrated I have to admit, as the map was the most important feature that motivated me to move away from the S9.
                                  using a Suunto Vertical & Suunto Wings; mostly running (AKA stomping around) and cycling through the northern german "wilderness", and wherever else I have the chance to do so
                                  OS - Android 16/Pixel Pro 7
                                  • V Offline
                                    vpet_09
                                    Newest update seems to fix the black grid issue or at least my case, very nice!
                                    Majkel PaszekoM 1 Reply Last reply Reply Quote 12
                                      Majkel Paszeko @vpet_09
                                      @vpet_09 Just updated my SV, and my local “black magic” spot doesn’t crashes my watch anymore!
                                      S 1 Reply Last reply Reply Quote 10
                                      • S Offline
                                        🙏 nice surprise and update! Map is visible in all zoom-levels, watch seems to react significantly faster, too.
                                        1 Reply Last reply Reply Quote 4
                                        • Henrik JacobssonH Offline
                                          Henrik Jacobsson @Guest
                                          @A-Former-User said in No-Map-Problem:
                                          @isazi
                                          That’s all that shows up. Needless to say, that’s not what my hometown looks like.
                                          I have this exact problem now where I live 😞
                                          Sweden, Västra Götaland County
                                          (other regions seem to work)
                                          isaziI 1 Reply Last reply Reply Quote 0
                                          • isaziI Offline
                                            isazi Moderator @Henrik Jacobsson
                                            @Henrik-Jacobsson yes, there seem to be an issue with this specific region, and Suunto is aware of it.
                                            Blog: isazi's home
                                            Mats PerssonM 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
