    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    No-Map-Problem
    Scheduled Pinned Locked Moved Suunto Vertical
    299 Posts 65 Posters 107.4k Views 62 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Mats PerssonM Offline
      Mats Persson @isazi
      @isazi
      @isazi said in No-Map-Problem:
      @Henrik-Jacobsson yes, there seem to be an issue with this specific region, and Suunto is aware of it.
      The same for me for the same region. I was in contact with a support agent today that recommended me to send back the watch. Is this the solution or will the map be fixed/updated?
      @Henrik-Jacobsson, have you got any support?
      TieutieuT 1 Reply Last reply Reply Quote 0
      • TieutieuT Offline
        Tieutieu Platinum Member @Mats Persson
        @Mats-Persson I would certainly not send my watch back if this is the only issue you have….
        There is lot of chance that it fille be fixed, but it could take time to come.
        Suunto’s devices at home :
        Vertical titanium solar
        Suunto Race S
        S9pp titanium sand
        Suunto Wing & Spark
        S9B titanium Ambassador edition, A3P, X6
        • pavel.samokhaP Offline
          pavel.samokha
          @Mats-Persson @Henrik-Jacobsson Could you share (Direct Message) specific location to me which have problems? Coordinates or place name
          Opinions expressed are solely my own and do not express the views or opinions of my employer
            pavel.samokha
            @Mats-Persson @Henrik-Jacobsson you should see an update for “Västra Götaland County” in your Suunto App and can download it to the watch
            Henrik JacobssonH Mats PerssonM 2 Replies Last reply Reply Quote 5
            • Henrik JacobssonH Offline
              Henrik Jacobsson @pavel.samokha
              @pavel-samokha said in No-Map-Problem:
              Thanks! I see it, and will try it soon. I also got weird suggestions from customer support and then sending the watch for repair (when other regions work well) 😞
              Great response on fixing the map that quickly 👍
                pavel.samokha
                @Mats-Persson @Henrik-Jacobsson forgot to say, after map update you may need to restart your watch - otherwise it may have old map cached in memory
                AntoineA 1 Reply Last reply Reply Quote 1
                • AntoineA Offline
                  Antoine Bronze Member @pavel.samokha
                  @pavel-samokha hello. Need to restart watch after each map update ? Soft reset ? Thanks
                  Suunto vertical solar
                  Coros arm HRM / Suunto wing 2
                  Android A55 Samsung
                  Suunto App latest official update
                  pavel.samokhaP 1 Reply Last reply Reply Quote 0
                    pavel.samokha @Antoine
                    @Antoine you don’t need to, the cache will go away eventually, but in cases update is supposed to fix something it’s better to do soft reset to be sure you see updated version (e.g. go settings -> general -> power off, then power on by pressing upper button)
                    SuperFlo75S 1 Reply Last reply Reply Quote 2
                      Mats Persson @pavel.samokha
                      @pavel-samokha Many thanks for your support and solution to the problem! 🙂
                      There was indeed a notification in the maps section and the map now works fine after I deleted the old one and downloaded the new one and did a soft reset (power off/on).
                      Perhaps good to educate customer support not to tell people to send back watches when the problem is only map related and can be fixed remotely!
                      • SuperFlo75S Offline
                        SuperFlo75 Silver Members Bronze Member @pavel.samokha
                        @pavel-samokha For my SV I noticed a increased battery consumption after downloading new maps or updating maps… for example from 100% to 10% in about 3 weeks, and normally it goes from 100% to 10% in 4 weeks… but I also noticed a normal behavior when doing a soft reset after charging and downloading maps… can you explain this behavior?
                        Suunto Vertical 2 Titanium Sage
                        Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
                        Suunto Wing
                        Suunto 9 Peak Pro Titanium (owns my wife now)
                        Suunto Spartan Ultra
                        SA iOS 3.9.0 (22101)
                        Instagram @superflo75
                          pavel.samokha @SuperFlo75
                          @SuperFlo75 I don’t think updated maps have any influence on battery life
                          SuperFlo75S 1 Reply Last reply Reply Quote 0
                            @pavel-samokha Ok, thanks for your answer, but I had this experience 🤔 I wrote down everything I did with my SV and when…
                            Suunto Wing
                            • Raymond WangR Offline
                              Raymond Wang
                              Hello I had purchased a suunto vertical and I’m having issues with the maps. I’ve tried everything I could find on the internet but the maps are always blank. No roads or anything. Already deleted and re-downloaded maps multiple times. Did soft resets and hard resets. I had read over the other post about it but I still cant seem to get the maps to show anything. Good GPS fix and everything
                              cosme.costaC EgikaE 2 Replies Last reply Reply Quote 0
                              • cosme.costaC Offline
                                cosme.costa @Raymond Wang
                                @Raymond-Wang said in No-Map-Problem:
                                First of all. How you download the maps? Is the watch connected to wifi and in the charger? Do you see the message in the screen that the maps are being downloaded and you wait till they are downloaded, depending on the area it could take pretty long time.
                                When you check them are you sure that you are in the downloaded area?
                                • EgikaE Offline
                                  Egika Platinum Member @Raymond Wang
                                  @Raymond-Wang where are you based (coords) and which map did you download to the watch?
                                    Raymond Wang
                                    I’m in NC
                                    N 35° 19’ 48.509
                                    W 80° 43’ 57.064
                                    I downloaded with watch on charger and wifi. Didn’t touch either the watch or my phone while it was downloading. It had the message while it was downloading the whole time and got the message it was completed. All I could ever get the map to show is this ![0_1720532721582_1000001553.jpg](Uploading 75%)
                                    Raymond WangR 1 Reply Last reply Reply Quote 0
                                      Raymond Wang @Raymond Wang
                                      I’m in NC
                                      N 35° 19’ 48.509
                                      W 80° 43’ 57.064
                                        pavel.samokha
                                        There should be an update for North Carolina map now
                                        Raymond WangR 1 Reply Last reply Reply Quote 2
                                          Raymond Wang @pavel.samokha
                                          @pavel-samokha awesome, it has been fixed now thank you so much
                                          • fondueaufromageF fondueaufromage referenced this topic on
                                          Register Login
                                          • First post
                                            Last post
                                          Suunto Terms | Privacy Policy
