    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical: Bug Collection
    Scheduled Pinned Locked Moved Suunto Vertical
    1.1k Posts 183 Posters 778.8k Views 155 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • 6 Offline
      6294946 Bronze Member
      Not sure if this is a bug but since its not explained in suunto manual:
      Sometimes I can activate backlight by tapping the screen and sometimes not. Other times I need to press the middle button to be able to use touch screen gestures and swipes. What is the expected behaviour? Can I change this in some menu?
      ? 1 Reply Last reply Reply Quote 1
      • ? Offline
        A Former User @6294946
        @6294946 That’s the automatic screen lock. You can’t change it.
        “When you are not recording an exercise, the screen locks and dims after one minute of inactivity. To activate the screen, press any button.”
        https://www.suunto.com/en-ie/Support/Product-support/suunto_vertical/suunto_vertical/settings/button-and-screen-lock/
        • P Offline
          plisken
          Found out that despite the manual suggesting that Low Power Mode would be activated automatically at 10% battery, this did not happen. I have also read that it activates at 1% but can also confirm that this is also not the case. Watch drained completely today, no Power Saving Mode activation, no warning, just dead.
          2.25.66
          Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
          • Łukasz SzmigielŁ Offline
            Łukasz Szmigiel @plisken
            @plisken keep in mind that:
            • Two S+ apps will drain battery more than one, and you won’t see it in pre-workout estimation.
            • Navigation screen switches the watch to the best GPS mode available.
            • I have no means of testing it in SV as I don’t own one, but using ETA/ETE fields may also switch the watch to the best battery mode (this needs confirmation).
            And there may also be some more quirks.
            S9PP 2.50.28
            P 1 Reply Last reply Reply Quote -1
            • P Offline
              plisken @Łukasz Szmigiel
              @Łukasz-Szmigiel The power drain is not an issue for me, it is the fact that it does not automatically enter power saving mode as per the manual, which is not ideal.
              • mikekoski490M Offline
                mikekoski490 Bronze Member
                For some reason Vertical just stopped providing HR readings today at 6am for pretty much the whole day based on the SA graph. Confirmed that 24/7 hr recording is on. Toggled it off/on and still no reading. Powered off and on and now getting HR again.
                Past Suuntos: X-Lander/Observer/T6/X9/X10/X6HR/CORES/Ambits/Spartan/9P/9PP Ti/Vertical Ti
                Current: Suunto Race Ti
                Past other GPS watches: Polar Vantage V; Garmin 6X Pro Solar; Coros Vertix 2
                Suunto App running on Google Pixel 8/Android 14
                GiPFELKiNDG jjpazJ 2 Replies Last reply Reply Quote 0
                • GiPFELKiNDG Offline
                  GiPFELKiND Silver Members @mikekoski490
                  @mikekoski490 😬 so do you know the Problem?!
                  If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
                  mikekoski490M 1 Reply Last reply Reply Quote 0
                    mikekoski490 Bronze Member @GiPFELKiND
                    @GiPFELKiND No. In 4 months it’s never happened. Fixed with a reset.
                    Mitch9M 1 Reply Last reply Reply Quote 0
                    • Mitch9M Offline
                      Mitch9 Silver Members @mikekoski490
                      @mikekoski490 said in Suunto Vertical: Bug Collection:
                      I had the same problem some days ago. Soft reset fixed the hr reading.
                      Watch: Suunto Vertical Titanium Solar (Sand)
                      SA: Android (beta)
                      HRS: Polar H10
                      • jjpazJ Online
                        jjpaz Bronze Member @mikekoski490
                        @mikekoski490 I had the same problem several weeks ago. Also the “no map” issue was there at the same time, black map screen. After a soft reset all started to work again.
                        Perhaps both issues were related, some memory buffer getting empty or something like that.
                        Suunto Vertical Titanium Solar, Suunto Race 2 Ti & Suunto Wing.
                        • v.sacreV Offline
                          v.sacre Silver Members
                          Got a bug for the first time today during my lunch run.
                          Activity has been shutdown after about 1 km. The watch got back on the main screen. I had to restart another activity.
                          Activity before the bug has been well recorded.
                          Laps each km were activated and S+ fused zone as well.
                          I suspect I got the crash because of the first lap (but it is strange as it is the first time I have this). But it is the first time I used laps and fused zone at the same time.
                          A3S | S9B | S9P | S9PP | SV1 Ti | SV2 Ti
                          Suunto Wing
                          Suunto App: Android Beta
                          jjpazJ EzioAuditoreE 2 Replies Last reply Reply Quote 0
                          • jjpazJ Online
                            jjpaz Bronze Member @v.sacre
                            @v-sacre That’s the already known “random reboot” while in activity, I think there are topics about it in the forum.
                            You can try to send logs to Suunto to help developers find the solution to the issue.
                            • danklodD Offline
                              danklod
                              Hello,
                              I noticed that sometime the touch screen blocked. When the screen block the watch works and I can navigate in the menu. I found two ways to fix it - restart and start and discard the activity.
                              • EzioAuditoreE Offline
                                EzioAuditore Gold Members @v.sacre
                                @v-sacre I am on my second unit (the first one was crashing on every 2nd to 3d run) but the replacement I got is even worse. I got the replacement, couldn’t use it since I was away for a month then come home turn it on put it in my backpack and went biking to work to set it up during lunch break. I just got it out of the bag and touched it, it crashed and restarted. Brand new watch just turned on!!
                                Reset it turned it off and back to the drawer. Since I am terribly dissapointed with the SV I started testing another watch (and loved it). So after 2 weeks turned on the SV, synced and put the 2 wathces to check the GPS accuracy and pace between them. While similar in distance the maps on the SV were shoing me off by almost 100m?! Than on the 3rd km it crashed again!
                                I mean if it was one unit, ok sh*t happens it is tech so it might be expected. But the new unit also! And nothing to fix the crashes, no hotfix no nothing!
                                Suunto watches: Vertical 2 (Titanium Sage), Race 2 (Titanium Trail), Ocean (Sand), Race (Titanium Charcoal), Vertical (Titanium Solar Sand), 9 Baro (Ambassador Edition), Spartan Ultra (Copper Edition), Ambit 2, S6
                                Suunto Wing
                                TieutieuT 1 Reply Last reply Reply Quote 1
                                • TieutieuT Offline
                                  Tieutieu Platinum Member @EzioAuditore
                                  @EzioAuditore said in Suunto Vertical: Bug Collection:
                                  Sorry to hear that…It’s pretty unlucky…are you using guides or particular settings ??
                                  Accuracy of the SV it outstanding, no reason to be off by 100m…
                                  Suunto’s devices at home :
                                  Vertical titanium solar
                                  Suunto Race S
                                  S9pp titanium sand
                                  Suunto Wing & Spark
                                  S9B titanium Ambassador edition, A3P, X6
                                  EzioAuditoreE mikekoski490M 3 Replies Last reply Reply Quote 0
                                    EzioAuditore Gold Members @Tieutieu
                                    @Tieutieu I know my first unit was super accurate. Ok it may happen to drift a bit on weird GPS days but this time it was really something off. I waited 2-3 mins after gps lock aquired and started running first in the open and then entering the woods (here is were it started acting weirdly). Yes I use TrainingPeaks Guides and Stryd food pod since I train with power. But as I said the watch restarted even out of activity!
                                    Suunto Wing
                                      @Tieutieu What else is worth mentioning is that even off the overall distance with the other watch was only 10m. So after I saw the maps I returned to the default sport face (first screen) and after some running said to check again the maps. Upon pressing to advance to the 3rd screen (the maps, 2nd one being the laps) the wath froze and restared. Tried to start activity while running but couldn’t lock on gps. So being in a season of marathons and long runs the SV is too unreliable to go for a walk not to train with it!
                                      Suunto Wing
                                        mikekoski490 Bronze Member @Tieutieu
                                        @EzioAuditore Can you post app screenshots from the workouts you did with both the Suunto and also the ‘other brand’ you were wearing at the same time? It’s ok to name the other brand too. Curious. Thanks! I’ve had my Vertical since launch and only one crash a few months back, which put it on par with Garmin and Coros (both had crashes at some point).
                                        When my Vertical crashed I had to restart the workout (trail run) mid-way so it showed up in SA as 2 workouts.
                                        TieutieuT 1 Reply Last reply Reply Quote 0
                                        • TieutieuT Offline
                                          Tieutieu Platinum Member @mikekoski490
                                          @Tieutieu Can you post a screenshot of the workout you did with both the Suunto and also the ‘other brand’ you were wearing at the same time? It’s ok to name the other brand too. Curious. Thanks! I’ve had my Vertical since launch and only one crash a few months back, which put it on par with Garmin and Coros (both had crashes at some point).
                                          Not concerned by crashes neither accuracy pbs…don’t you wanted to tag @EzioAuditore ?
                                          Suunto Race S
                                          S9pp titanium sand
                                          Suunto Wing & Spark
                                          mikekoski490M EzioAuditoreE 2 Replies Last reply Reply Quote 1
                                            @Tieutieu Yes. Corrected the tag name. Thanks.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
