    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical: Bug Collection
    Scheduled Pinned Locked Moved Suunto Vertical
    1.1k Posts 183 Posters 714.8k Views 155 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • freeheelerF Away
      freeheeler @wmichi
      @wmichi
      I saw it first on S9PP. I think it happens more often than we think, but we don’t watch the watch charging, right? 😉
      it was coincidence in my case
      living sideways
      • ? Offline
        A Former User
        The good, the bad and the ugly 🙂
        The good:
        I’ve received my Vertical yesterday, configured it and did my first multisport activity today. First off, the battery life is crazy!!! Started this morning with 96%, did a 1 h 40 min hours activity with performance GPS - which was also perfect - and now, the watch shows 97%. It’s a very sunny day 😉 Using the map is quite useful.
        The bad (no bugs):
        1. With former Suunto watches (e.g. S9P), when leaving the track during navigation, the map would zoom out and show me where the track was. That’s no longer the case. I need to manually zoom out. If the track is further away than 500 m, I need to move the map around and search for the track, because there is no indication where the nearest direction is back on track. Not a bug, but not so nice.
        2. When panning the map, it snaps back to the current location quite fast. And just after each panning, the map shifts around a little bit. Both makes planning an off-track route a bit difficult. In an emergency situation (blizzard, cold, etc), this could be quite bad.
        3. The onboard HR and particularly the spO2 sensors are still just toys. A waste of space, weight and battery. The acquired data is sometimes quite good, in the case of HR even accurate, but they are just as often absolutely incorrect. Hence, unreliable toys. Yeah, many people want to have that still. I don’t :'-D
        The ugly (bugs):
        1. Using the display “Intensity zones”, one can configure 2 fields. Only 1 is actually shown on S9P/P and on the Vertical. To my knowledge, the second field is only used on S9. Okay, so I filled the field marked as #1 and set the second field to “Empty”. This didn’t work. During the activity, the display did show the current heart rate, but all other data was garbled up. Now I set both fields to the same value and it seems to work now.
        2. When I wanted to start the second activity via the multisport option (long press upper button during activity), there there were no names given for the options to choose from - only blank fields. My configuration: I deleted all default sport modes and created 4 custom sport modes. I can select each of them to start an activity, but their names didn’t appear as multisport choices. A rather ugly bug!
        I noticed a lot of other minor bugs, which are not critical. I’m a software engineer myself and - oh boy - I wouldn’t dare to publish a software that has so many issues. IMHO, Suunto did a quite sloppy job here. But okay, lots of different users with lots of different configurations … and everything should be there and working from the first day on. It’s a tough task. On the other hand, e.g. the above mentioned “Intensity zones” display issue with 2 fields when only 1 is available on the watch, has been known for years. That’s embarrassing 😞
        Not sure if I keep the watch. It seems to be very unreliable all in all.
        ? seanvkS 2 Replies Last reply Reply Quote 5
        • ? Offline
          A Former User @Guest
          @Simon I was also impressed about the battery, but don’t forget to calibrate the battery (discharge from 100% to 0%) 🙃 I went out with 30% battery remaining on my first charge and boom the watch discharged in 30 minutes… Just a FYI to avoid unpleasant surprises 🙂
          ? TieutieuT 2 Replies Last reply Reply Quote 1
          • ? Offline
            @tomasbartko Oh wow, that’s kind of nasty! 🙈
            • TieutieuT Offline
              Tieutieu Platinum Member @Guest
              @tomasbartko said in Suunto Vertical: Bug Collection:
              Did you had the backlight on ? That is THE major bug that over-consume the battery
              Suunto’s devices at home :
              Vertical titanium solar
              Suunto Race S
              S9pp titanium sand
              Suunto Wing & Spark
              S9B titanium Ambassador edition, A3P, X6
              • ? Offline
                A Former User @Tieutieu
                @Tieutieu no, not really. I however had 2 Suunto apps on. I guess this combination with no calibration was the issue.
                • ? Offline
                  @tomasbartko
                  S+ apps eat through your battery faster than it takes a Golden Retriever to finish a bowl of spaghetti. 😬
                  • mikekoski490M Offline
                    mikekoski490 Bronze Member
                    Finally got hit by the reset bug - 60k gravel ride, at about the 30k mark just turned off and restarted. It was going into activity pause mode as I was taking a photo. Profile was just basic. 2 apps running - big numbers and CO2e. Not a big deal but would be nice to stitch the 2 workouts together in SA. Just missed a section of HR, which is seperate from 15 minutes earlier when a fairly large black bear ran across the logging road about 100 meters infront of me - that shows an HR spike lol.
                    Past Suuntos: X-Lander/Observer/T6/X9/X10/X6HR/CORES/Ambits/Spartan/9P/9PP Ti/Vertical Ti
                    Current: Suunto Race Ti
                    Past other GPS watches: Polar Vantage V; Garmin 6X Pro Solar; Coros Vertix 2
                    Suunto App running on Google Pixel 8/Android 14
                    • runomaticR Offline
                      runomatic Silver Members
                      After all that negative feedback, i’ve got a positive one: Went out for a 25k run with just 7% battery left. Coming home with 4% after 2:40h. Call me Mr. Brave!
                      https://runomatic.de
                      SUUNTO VERTICAL 2 Titanium
                      SUUNTO WING Black
                      SUUNTO App (iOS)
                      freeheelerF Frederick RochetteF 2 Replies Last reply Reply Quote 7
                      • freeheelerF Away
                        freeheeler @runomatic
                        @runomatic
                        going out on 7% is living on the edge 😂
                        living sideways
                        • seanvkS Offline
                          seanvk @Guest
                          @Simon On the subject of the widgets. One item I would add to your mentioning of HR and spO2 is that I think they should entirely avoid putting the widgets in a pipeline so to speak. Not just because of the lag, but there is no quick way to get to the one you want. Instead, they should have the following flow:
                          middle button or side swipe -> list of widgets with some partial information.
                          top or bottom buttons, scroll up or down
                          middle button select for more detail
                          I just really dislike the side scroll for the widgets and coupled with the lag, it’s not a very good experience just to get to one widget you wanted to look at in more detail
                          Suunto Race Titanium
                          Suunto Vertical Titanium
                          Suunto 9 Peak Pro Forest Green
                          Suunto 9 Peak Moss Gray
                          ? BrunoHB 2 Replies Last reply Reply Quote 1
                          • ? Offline
                            A Former User @seanvk
                            @seanvk Like Garmin you mean? Would make more sense imho.
                            seanvkS 1 Reply Last reply Reply Quote 0
                            • BrunoHB Offline
                              BrunoH Gold Members @seanvk
                              @seanvk my solution was first to hide the ones I never use. Then I arranged the remaining ones so that the most used widgets are next to the watchface, left and right.
                              I don’t think Suunto will abandon their chosen UX and replace it with something copied from the rivals.
                              Having said that, I’d really like to see Suunto solve the lag…
                              Compasses: M-311, A-10, SK-7
                              Diving: Finnlight Navy 90, Vyper
                              Sports: Metron, S7, S9B and Vertical
                              1 Reply Last reply Reply Quote 3
                              • ? Offline
                                A Former User
                                Btw. that 9pm thing about the Week Report was true. lol
                                • Frederick RochetteF Offline
                                  Frederick Rochette Bronze Member @runomatic
                                  @runomatic On Saturday, I also had 7% left and after going out for a 2-hour run, I also had 4% left.
                                  After completely discharging the watch on Saturday, I recharged it to 100% at around 11.30pm. When I woke up at around 8am on Sunday morning, the watch was at 98%. I went out for a 2-hour run and only 92% remained (6% for 2 hours…).
                                  So battery consumption seems to be random… because one 2-hour run = 3% and another 2 hours = 6%.
                                  surfboomerangS freeheelerF Mff73M E 4 Replies Last reply Reply Quote 0
                                  • surfboomerangS Offline
                                    surfboomerang @Frederick Rochette
                                    @Frederick-Rochette I don’t know if this is some kind of calibration. I noticed similar behaviour.
                                    I charged the watch in the evening but it wouldn’t get over 99%. Next morning it was at 97%. I did a 1:30hr sunny run and it dropped to 95%.
                                    That afternoon I had a 2:30hr car trip where sun hits the watch a lot, but never full bars. Suddenly the watch was at 100%.
                                    Normally it took approximately 1hr of full bars to charge 1%
                                    Next day I did a 2:30hr hike and the watch is down to 93%. I did noticed I left one S+ app active so I don’t know if that was the cause.
                                    Suunto Vertical Titanium Solar
                                    OnePlus Nord 4
                                    • freeheelerF Away
                                      freeheeler @Frederick Rochette
                                      @Frederick-Rochette
                                      always same settings?
                                      living sideways
                                      • isaziI Offline
                                        isazi Moderator @babychai
                                        @babychai no updates, it is not a firmware thing, I believe the maps do not have contour lines for Malaysia at the moment. It probably needs an update of the map. Before release most non European maps had not contour lines.
                                        Blog: isazi's home
                                        babychaiB 2 Replies Last reply Reply Quote 0
                                        • babychaiB Offline
                                          babychai Silver Members @isazi
                                          @isazi oh okay, thanks for the info~
                                          Suunto Vertical Titanium Solar Black
                                          Suunto 9 Peak All Black
                                          Suunto Spartan Trainer Wrist HR (Black)
                                          • Mff73M Offline
                                            Mff73 @Frederick Rochette
                                            @Frederick-Rochette said in Suunto Vertical: Bug Collection:
                                            not random, but non linear.
                                            SSU (retired), SV1, SV2
                                            Wife : S9PP
                                            SA: Always the latest beta :)
                                            Android + Galaxy S205G
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
