    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Turn by turn doesnt work
    Scheduled Pinned Locked Moved Suunto 7
    47 Posts 13 Posters 5.6k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Annika I.A Offline
      Annika I.
      Hi together, I am new to Suunto and trying the Suunto 7 since a week now. The one thing that puzzles me: when I import a GPX track (from outdoor active) to navigate me while running, the track shows in the Suunto app as „from point A to point B“. Although turn by turn is activated, the track shows on the watch but it doesnt say „hey, turn right in 50m“. 😞 am I doing sth wrong or do I really have to mark every crossing to achieve the Navigation signs I am looking for? Maybe someone has a hint for me 🙂 Thanks a lot in advance.
      DMytroD 1 Reply Last reply Reply Quote 0
      • DMytroD Offline
        DMytro @Annika I.
        @annika-i I don’t think OutdoorActive supports TbT. The only apps that do the thing for suunto that I know of are Suunto App, Komoot and PlotARoute.
        Annika I.A 1 Reply Last reply Reply Quote 1
        • EgikaE Offline
          Egika Platinum Member
          I also wish, one could enable turn notification on an imported track… But this would only work, if you could make sure, that an imported track followed actual paths. Since this is not always the case and you can import any point list, inserting waypoints for turns will be guessing and not reliable.
          I think this is why it is not there
          t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
            Annika I. @DMytro
            Thanks @dmytro . That would mean, switching to Komoot and importing my tracks from there, could solve my problem? (other option being doing it all manually in the Suunto App… )
            • EgikaE Offline
              Egika Platinum Member @Annika I.
              @annika-i Yes, if you create your route in Komoot, it will get the turn indication waypoints from there and they will sync through to your Suunto. Has been working pretty well for me.
              Annika I.A 1 Reply Last reply Reply Quote 0
                Annika I. @Egika
                Thanks @egika
                • olymayO Offline
                  olymay Gold Members
                  @Annika-I I also use the Komoot method to import routes and it works very well with turn by turn.
                  Some things to be aware of (and I apologise if you already know this, but if not then they may prove useful)…
                  Once the route has been imported into the Suunto app, you may need to turn on the turn by turn navigation part. You need to go in to the edit route section and the toggle is at the bottom, just above the ‘use in watch’ toggle.
                  Also, whilst still in the edit screen, you can see all of the points where you will get notifications. You can then edit or remove them. (I find that the auto generation of directions produces too many for me, so I will remove many of the obvious ones and leave just the key ones).
                  Have a play around with it and if you have any other questions about how it works we are more than happy to help 🙂
                  Suunto 7 Graphite Copper
                  Suunto App Beta (Android - Pixel 6 Pro)
                  • N Offline
                    nerones
                    Hello, I renew this post, I use Komoot to create the routes, it automatically imports them into the Suunto app and then I find them on my watch.
                    The turn by turn option is activated in the characteristics of the route but I have no indication of a turn during the activity, I have tried everything, but nothing.
                    Do you have any idea what I could be doing wrong?
                    Thank you.
                    freeheelerF 1 Reply Last reply Reply Quote 0
                    • freeheelerF Offline
                      freeheeler @nerones
                      @nerones
                      I never used komoot for planning, how does an imported route with TBT look like, can you share a screenshot? …if it doesn’t violate your privacy of course
                      living sideways
                      • N Offline
                        nerones
                        freeheelerF 1 Reply Last reply Reply Quote 1
                          freeheeler @nerones
                          @nerones
                          how’s the behavior when you create a route in SA?
                          does it work then?
                          living sideways
                          • N Offline
                            nerones
                            It doesn’t work, as far as I know the only way is to create the path on Komoot and then import it, but that doesn’t work for me either!
                              freeheeler @nerones
                              @nerones
                              turn by turn works very well with my watch with routes created with SA and TBT toggles on.
                              the root cause must be somewhere else.
                              I normally get the notification around 100m before the turn. is that what you expect to see but you didn’t during your activity?
                              living sideways
                              • N Offline
                                nerones
                                Exactly, I tried everything I found written around the web, but no turning directions…
                                • N Offline
                                  nerones
                                  I’m using IOS…probably on android it behaves differently…
                                    freeheeler @nerones
                                    @nerones
                                    can you try to restart the watch and try again? if you didn’t already
                                    living sideways
                                    • N Offline
                                      nerones
                                      About a hundred times, I’ve been looking for the solution for weeks… 🙂
                                        freeheeler @nerones
                                        @nerones
                                        let’s ask our friend @isazi who has an S7 🙂
                                        living sideways
                                        isaziI 1 Reply Last reply Reply Quote 0
                                        • isaziI Offline
                                          isazi Moderator @freeheeler
                                          @freeheeler testing it later today.
                                          Blog: isazi's home
                                          • isaziI Offline
                                            isazi Moderator
                                            Okay it doesn’t work for me either. Is it supposed to work on S7? Not sure. Maybe not.
                                            Blog: isazi's home
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
