    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Number of downhill runs in alpine skiing
    downhill skiingsuunto 9 baroalpine skiing
    45 Posts 15 Posters 13.2k Views 15 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • MdzOttM Offline
      MdzOtt @freeheeler
      @freeheeler when you look at the move on the web site, it shows only 0.5 km laps. On the SA it shows “downhills” - I assume runs. The first few are fine, then it starts showing 0 m length, 5 m descent for 5-6 “runs” and then a longer one. Somehow the logic has failed the watch.
      R2
      S9 Baro
      SA on Android
      Ambit 3 Peak
      Ambit 2 Sapphire
      freeheelerF 1 Reply Last reply Reply Quote 0
      • freeheelerF Offline
        freeheeler @MdzOtt
        @mdzott
        did you use the famouse lock button?
        living sideways
        MdzOttM 1 Reply Last reply Reply Quote 0
        • MdzOttM Offline
          MdzOtt @freeheeler
          @freeheeler I did. I have to under the jacket. What am i missing here?
          R2
          S9 Baro
          SA on Android
          Ambit 3 Peak
          Ambit 2 Sapphire
          freeheelerF 1 Reply Last reply Reply Quote 1
            freeheeler @MdzOtt
            @mdzott
            nothing… I have the impression the ski mode simply does not work properly
            living sideways
            • MdzOttM Offline
              MdzOtt @freeheeler
              @freeheeler The development team could use the code that is available for Ambit 3 (and 2), as “Downhill Counter, Max speed, Distance”. It works like a charm. And the code is almost trivially simple.
              R2
              S9 Baro
              SA on Android
              Ambit 3 Peak
              Ambit 2 Sapphire
                freeheeler @MdzOtt
                @mdzott
                for us developers it is more entertaining to re-invent the wheel 😉
                living sideways
                surfboomerangS 1 Reply Last reply Reply Quote 1
                • surfboomerangS Offline
                  surfboomerang @freeheeler
                  @freeheeler Then why is Stackoverflow so popular? 😉
                  Suunto Vertical Titanium Solar
                  OnePlus Nord 4
                  • MdzOttM Offline
                    MdzOtt
                    I am resuscitating this old topic - the new season, some of the same problems.
                    I started skiing again and the number of runs is still a problem. It has improved dramatically (SA adds a couple of runs, and they are quite legitimate (e.g., a short run to the chairlift).
                    The latest issue is how the activity is passed from Suunto to Strava. I thought it might be a Strava issue, but their response is that “if the platform with which the activity was recorded passes a number of runs, Strava will take it at its face value. If there is no such number, Strava will calculate it internally”. So it seems that Suunto is counting the runs in a strange way.
                    For example, the last time, SA reported 21 runs (https://www.sports-tracker.com/workout/marekdziedzic/63a0950e27a4974d2657ebe4), but Strava shows 43 runs. It seems that Suunto is passing some other number (some other variable) as the number of runs.
                    As we discussed before, this is not a huge issue, but possibly, this could be fixed. And as mentioned before, the Ambit 3 (and 2) reported these numbers correctly.
                    Btw. the total descent is much closer now, so I am not complaining.
                    R2
                    S9 Baro
                    SA on Android
                    Ambit 3 Peak
                    Ambit 2 Sapphire
                    northeast_trekkerN Umer JavedU 2 Replies Last reply Reply Quote 2
                    • northeast_trekkerN Offline
                      northeast_trekker Bronze Member @MdzOtt
                      @MdzOtt seems odd that SA would be able to know the correct run count but then Suunto would be storing a bogus number in the “supported” run count field - seems like this number includes the auto laps and how those segment the activity up artifically. I wish that Strava either allowed user to “correct” lap count like you can with elevation and override with their calculated run count with an algorithm based value.
                      • Umer JavedU Offline
                        Umer Javed @MdzOtt
                        @MdzOtt said in Number of downhill runs in alpine skiing:
                        …“if the platform with which the activity was recorded passes a number of runs, Strava will take it at its face value. If there is no such number, Strava will calculate it internally”. So it seems that Suunto is counting the runs in a strange way.
                        Have you tried looking at the GPX or FIT file, do you note any count of runs written into it?
                        MdzOttM 2 Replies Last reply Reply Quote 0
                        • MdzOttM Offline
                          MdzOtt @Umer Javed
                          @Umer-Javed I haven’t tried. But I will and report back.
                          R2
                          S9 Baro
                          SA on Android
                          Ambit 3 Peak
                          Ambit 2 Sapphire
                          • MdzOttM Offline
                            MdzOtt @Umer Javed
                            @Umer-Javed Interestingly, if I export from Sport-Tracker using GPX, Strava reports the same (correct) number of runs as Sport Tracker. The same happens if I “Export GPX workout” from SA (which seems logical, as it seems that this is the same file). However, if I “Download FIT file” from SA and upload it to Strava, the double number of runs shows up.
                            I think that Suunto is passing the FIT file to Strava (and the problem is within the FIT file).
                            Unfortunately, I have no tool to look inside the FIT file to see what information is there.
                            R2
                            S9 Baro
                            SA on Android
                            Ambit 3 Peak
                            Ambit 2 Sapphire
                            Umer JavedU 1 Reply Last reply Reply Quote 2
                              Umer Javed @MdzOtt
                              If you’re interested in diving deeper, you may try the https://runalyze.com/tool/fit-viewer you could upload the .fit and see if you can find a field for runs and what the count is from the file from SA.
                              MdzOttM 1 Reply Last reply Reply Quote 2
                              • MdzOttM Offline
                                MdzOtt @Umer Javed
                                @Umer-Javed thanks!!
                                R2
                                S9 Baro
                                SA on Android
                                Ambit 3 Peak
                                Ambit 2 Sapphire
                                M 1 Reply Last reply Reply Quote 1
                                • M Offline
                                  mihai_omega @MdzOtt
                                  I revice this topic because I have the same issue between Suunto and Strava.
                                  My Suunto App displays 18 runs, while the Strava app displays 37 runs. After analyzing the FIT file from Suunto App I discovered the issue. At the end of the file there is a statistics for the entire activity including number of laps = 37. This is the source used by Strava to count the runs. If this field is missing, than Strava calculates the number of runs by itself.
                                  Suunto developers, please set the correct number of laps/runs into the FIT file so that Strava can read the correct value. Thank you!
                                  = TYPE=0 NAME=session NUMBER=18
                                  --- timestamp=1077629177=2024-02-23T13:26:17Z
                                  --- start_time=1077612424=2024-02-23T08:47:04Z
                                  --- event=8=session
                                  --- event_type=1=stop
                                  --- sport=13=alpine_skiing
                                  --- sub_sport=9=downhill
                                  --- first_lap_index=0=0
                                  ***--- num_laps=37=37***
                                  --- min_heart_rate=45=45 bpm
                                  --- avg_heart_rate=106=106 bpm
                                  --- max_heart_rate=166=166 bpm
                                  --- avg_speed=2191=7.888 km/h
                                  --- max_speed=14540=52.344 km/h
                                  --- total_calories=1364=1364 kcal
                                  --- total_timer_time=16752340=16752.340 s
                                  --- total_elapsed_time=16752332=16752.332 s
                                  --- total_distance=3670800=36708.00 m
                                  --- total_ascent=3684=3684 m
                                  --- total_descent=3688=3688 m
                                  --- max_altitude=12954=2090.8 m
                                  --- min_altitude=9740=1448.0 m
                                  --- training_stress_score=1903=190.3 tss
                                  --- total_cycles=2926=2926 cycles
                                  --- avg_temperature=17=17 deg.C
                                  --- max_temperature=25=25 deg.C
                                  --- avg_cadence=58=58 rpm
                                  --- max_cadence=254=254 rpm
                                  --- total_training_effect=23=2.3
                                  --- time_in_hr_zone=14688130=14688.130 s,1182.209 s,645.201 s,173.892 s,61.085 s
                                  --- pool_length_unit=0=metric
                                  --- pool_length=2500=25.00 m
                                  --- 0_2_recovery_time=106140=106140
                                  --- 0_4_peak_epoc=133=13.3
                                  1 Reply Last reply Reply Quote 3
                                  • Lawrence KuracinaL Offline
                                    Lawrence Kuracina
                                    I have a similar problem using the Vertical. The Suunto App shows for Alpine Skiing that I did 13 runs (which is the same as my SkiTracks App)but on Strava it shows 26 runs. I have not looked at the FIT file. I see nothing in the Suunto App with 26 in it.
                                    MdzOttM 1 Reply Last reply Reply Quote 1
                                    • MdzOttM Offline
                                      MdzOtt @Lawrence Kuracina
                                      @Lawrence-Kuracina It seems that the problem was resolved, at least with Race 2. Today was my first alpine skiing session with the new Race 2 and the number of runs is correct (and the same in SA and Strava). I have no idea if it is Suunto’s doing or Strava, but it works.
                                      R2
                                      S9 Baro
                                      SA on Android
                                      Ambit 3 Peak
                                      Ambit 2 Sapphire
                                      N 1 Reply Last reply Reply Quote 0
                                      • N Offline
                                        nseslija Bronze Member @MdzOtt
                                        @MdzOtt Thanks for the info.
                                        Ambit 2S
                                        Ambit 3 Peak
                                        Suunto 9 baro
                                        Suunto Vertical Ti Solar
                                        • Stoke80S Offline
                                          Stoke80
                                          I recorded my first Alpine Skiing session with the Race 2 watch on Saturday.
                                          Unfortunately it does not show the number of runs, either on the watch itself, nor on the Suunto App.
                                          On the other side, the Suunto App shows me stats like steps cadence for steps and cycling?
                                          And it also gives me recovery time of 51 hours. Although I am pretty sure I did not do the Lauberhorn downhill race 4 times 😃
                                          Suunto Quest / Suunto Ambit 3 Peak / Sununto Spartan Sport Wrist HR / Suunto 9 Baro / Suunto 9 Peak Pro / Suunto Vertical / Suunto Race S / Suunto Race 2
                                          • EgikaE Online
                                            Egika Platinum Member @Stoke80
                                            @Stoke80 I’d like to file a bug for this.
                                            If it happens again, that neither watch nor app shows the # of runs, can you please send logs from the settings of the app as soon as possible after the activity?
                                            Then please let me know your app user name in private message and the date and time, when you sent the logs.
                                            Thank you!
                                            MdzOttM 2 Replies Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
