    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Number of downhill runs in alpine skiing
    downhill skiingsuunto 9 baroalpine skiing
    45 Posts 15 Posters 13.2k Views 15 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • MdzOttM Offline
      MdzOtt
      Re: Number of downhill runs in alpine skiing
      I am new to S9. I just used it for the first time with Alpine Skiing (Downhill). I did 13 runs on a local hill. The watch reported 62 runs and once the data was passed on to Strava, Strava shows it as 125 runs! Though, Strava was able to correct the vertical to 2183 m.
      Also, the total descent is off. The watch reported 2869 m (downhill descent) and 3823 m (Descent), but calculating the number of runs X the hill’s altitude, it is about 2150 m. Btw. what is the difference between “downhill descent” and “Descent”?
      Is this a problem that can be corrected? Am I doing something wrong, or is it the watch.
      Until now, i was using the Ambit 3 and never had this problem.
      Any advise?
      thanks
      R2
      S9 Baro
      SA on Android
      Ambit 3 Peak
      Ambit 2 Sapphire
      freeheelerF EgikaE 2 Replies Last reply Reply Quote 2
      • freeheelerF Offline
        freeheeler @MdzOtt
        @mdzott
        yes, you did everything within your possibilities… you’ve reported it 👍
        I’ve observed this weird counting, too. But honestly, I don’t care about the number of runs, as every slope I ride has a different shape, steepness and descent. I only look at daily descents, nothing and really nothing else for downhill skiing… sorry, telemark skiing 😜
        living sideways
        MdzOttM 1 Reply Last reply Reply Quote 0
        • EgikaE Offline
          Egika Platinum Member @MdzOtt
          @mdzott can you share the activity?
          I noticed last season and the years before with SSU, that a run will be counted sometimes when you stop during you run (or walk a little in the flat before continuing the descent)
          It would be helpful to see your altitude profile.
          freeheelerF MdzOttM 3 Replies Last reply Reply Quote 1
          • L Offline
            Lozen
            If you are in iOS, the sport mode is not “working” in terms of what it is possible to see in SA (there are some posts regarding this issue for iOS). The watch seems to record “correctly” the info at least based on what I was able to see in Movescount February last year. This winter I didn’t check (the slopes are still closed in my country)
            S9 Baro v. 2.14.16
            SA 2.4.0 (8992)
            iPhone12 Pro Max iOS 14.2
              freeheeler @Egika
              @egika
              I don’t think that short stops count… if this would be the case I would have +1k runs… 😂
              short and slow uphills or flats, yes maybe.
              but for sure if you have slopes with multiple lift sectors in series. If you ride the lower sector it detects the lift and counts, then you go up the lower and second sector and ride it detects the second sector, too and you already have 3 runs.
              Maybe it’s more a sector counter that a number of descents counter?
              living sideways
              • MdzOttM Offline
                MdzOtt @Egika
                @egika
                A silly question: how to share it?
                R2
                S9 Baro
                SA on Android
                Ambit 3 Peak
                Ambit 2 Sapphire
                • MdzOttM Offline
                  MdzOtt @freeheeler
                  @freeheeler - the number of runs is just a number, agreed, who cares. But the Total Descent should be accurate, but it isn’t. Any ideas?
                  R2
                  S9 Baro
                  SA on Android
                  Ambit 3 Peak
                  Ambit 2 Sapphire
                  • MdzOttM Offline
                    MdzOtt @Egika
                    @egika this was a very simple day on a local hill - multiple runs on a single chair. It should be reasonably easy to figure out how many runs.
                    I noticed in SA that there were numerous tiny runs (a couple of metres), probably when moving through the line to the lift.
                    I would gladly share the file. Let me know what you would like to see (and how to upload it).
                    R2
                    S9 Baro
                    SA on Android
                    Ambit 3 Peak
                    Ambit 2 Sapphire
                    BulkanB N Stefano M64S 3 Replies Last reply Reply Quote 0
                    • BulkanB Offline
                      Bulkan Moderator @MdzOtt
                      @MdzOtt I don’t sky, here there is no snow but @Brad_Olwin does although he is more into skimo. Maybe he knows.
                      Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
                      • N Offline
                        nseslija Bronze Member @MdzOtt
                        @mdzott as far as I know, I am using s9 baro, when you start to descent the watch start the interval, and the interval is finished when you start to ascent.
                        If you have small descents and ascents the watch will record that as ski runs.
                        Alpine skiing sport mode syncing problem with iOS is another problem, still unsolved unfortunately.
                        Ambit 2S
                        Ambit 3 Peak
                        Suunto 9 baro
                        Suunto Vertical Ti Solar
                        freeheelerF 1 Reply Last reply Reply Quote 1
                          freeheeler @nseslija
                          @nseslija
                          I did a small test recently and could not see a reasonable pattern… I did one decent without any bigger climbs that S9B with its 3m threshold would recognize and it showed 3 runs.
                          The theory that a longer pause might not be right either as I did a lot of quite similar pauses to get the fire out of my legs
                          https://www.suunto.com/move/skiingone/603a4763d03bd02037ba863d
                          living sideways
                          Mff73M N 2 Replies Last reply Reply Quote 0
                          • Mff73M Offline
                            Mff73 @freeheeler
                            @freeheeler
                            do you see that in QS, there seems only to be 2 laps (descents) vs 3 in the SA ?
                            SSU (retired), SV1, SV2
                            Wife : S9PP
                            SA: Always the latest beta :)
                            Android + Galaxy S205G
                              freeheeler @Mff73
                              @mff73
                              and the sum is not the total duration
                              living sideways
                              • N Offline
                                nseslija Bronze Member @freeheeler
                                @freeheeler I only see one descent there… I must say that I didn’t experience such a behavior with the watch… Did you feel vibration when the watch started a new interval during your descent?
                                I can feel the vibration almost every time, and it is when I start to descent, and when the ascent starts on the chairlift.
                                Ambit 2S
                                Ambit 3 Peak
                                Suunto 9 baro
                                  @nseslija
                                  I rarely feel it. It’s only when I pay attention when I enter or leave the chairlift station. I never notice the unwanted descent count vibration
                                  living sideways
                                  • MdzOttM Offline
                                    MdzOtt @MdzOtt
                                    @mdzott here is the link to the activity: https://www.suunto.com/move/marekdziedzic/6037d336cdd3874e077c7966
                                    R2
                                    S9 Baro
                                    SA on Android
                                    Ambit 3 Peak
                                    Ambit 2 Sapphire
                                    • MdzOttM Offline
                                      MdzOtt @MdzOtt
                                      @mdzott In the activity i just posted, the total descent is ~3800 m, whereas, when you count the runs, it should be around ~2500 m.
                                      R2
                                      S9 Baro
                                      SA on Android
                                      Ambit 3 Peak
                                      Ambit 2 Sapphire
                                      freeheelerF 1 Reply Last reply Reply Quote 0
                                        freeheeler @MdzOtt
                                        @mdzott
                                        I see 2’868m descent… it’s about alright.
                                        but 62 runs… hmmm…
                                        living sideways
                                        • MdzOttM Offline
                                          MdzOtt @freeheeler
                                          @freeheeler when i looked at the SA, there were multiple runs of 2 m, 3 m etc. It seems that it counted every single step i took waiting in line to the chair.
                                          R2
                                          S9 Baro
                                          SA on Android
                                          Ambit 3 Peak
                                          Ambit 2 Sapphire
                                            freeheeler @MdzOtt
                                            @mdzott
                                            possible, not good and not logic with the threshold… but only the dev teams knows 🙄
                                            living sideways
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
