    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    So, what are you going to do after Movescount closes?
    Scheduled Pinned Locked Moved Digital service transition
    434 Posts 63 Posters 202.1k Views 61 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Fenr1rF Offline
      Fenr1r @Ennoch
      @Ennoch The poor old SU does indeed suck in the wild compared to its predecessors and, now, its successor. The Instinct Solar sort of seems the business except … and I know this seems shallow, considering I want the watch for the outdoors … it looks like some Cronenbergian G-Shock and vintage Casio hybrid. Can’t look at it. Which is sub-optimal, in a watch.
      • sebchastangS Offline
        sebchastang Silver Members @pavel.samokha
        @pavel-samokha Sure, it’s not used by every Ambit owner, but as it is a feature and a possibility offered by the watch (to use custom apps in sports mode), I don’t see any reason to remove it, and no reason to not sync recorded data anymore with Suunto app. When you configure a sport mode with a suunto apps, you can tick a checkbox to enable data logging. Even with the transition, you are still supposed to be able to view those logs.
        Suunto Vertical Titanium Solar
        Suunto Traverse
        pavel.samokhaP 1 Reply Last reply Reply Quote 2
        • Kuba SarataK Offline
          Kuba Sarata Bronze Member @Guest
          @MartinLX said in So, what are you going to do after Movescount closes?:
          I do not miss MC at all, since all my historical moves are in SA, plus I have Strava and QS. I love that I can configure the watch via my mobile phone and being completely independent of a computer! You are out on a trip, want to change the set-up? Easy!
          It was the same possible with Movescount app soooo… no change here 😉
          Fenr1rF 1 Reply Last reply Reply Quote 0
          • pavel.samokhaP Offline
            pavel.samokha @Ennoch
            @Ennoch you can tap on screen in any place, not only icon. As with gloves - you’re right, yeah.
            Opinions expressed are solely my own and do not express the views or opinions of my employer
              Kuba Sarata Bronze Member @Brad_Olwin
              @Brad_Olwin said in So, what are you going to do after Movescount closes?:
              I will miss tags! RIP ~450 tags.
              @Brad_Olwin can’t agree more. The bigger part of my analytical work is going to trash 😞
              • Fenr1rF Offline
                Fenr1r @Kuba Sarata
                @Kuba-Sarata For a lot of functions (possibly only the ones that couldn’t also be changed on the watch) you do need a computer with MC App: it’s the server at the other end of the data connection you also require for that set-up change. SA does more settings changes to the watch “independently” in that sense.
                lohtseL Kuba SarataK 2 Replies Last reply Reply Quote 1
                • isaziI Online
                  isazi Moderator @lohtse
                  @lohtse said in So, what are you going to do after Movescount closes?:
                  I have tried using a stick, axe, explosives just won’t die lol…PERFECT WATCH.
                  We are waiting for your YouTube series in which you try to kill wild Ambits.
                  Blog: isazi's home
                  Fenr1rF lohtseL 2 Replies Last reply Reply Quote 0
                    pavel.samokha @sebchastang
                    @sebchastang As far as I understand (I may be wrong) it’s not “removing Mini Apps” it’s rather “Saving data generated by Mini Apps is not supported by Suunto App”.
                    sebchastangS 1 Reply Last reply Reply Quote 0
                    • Fenr1rF Offline
                      Fenr1r @isazi
                      @isazi said in So, what are you going to do after Movescount closes?:
                      I believe the Traverse has a Sport Mode for that.
                      lohtseL 1 Reply Last reply Reply Quote 2
                      • lohtseL Offline
                        lohtse @Fenr1r
                        @Fenr1r said in So, what are you going to do after Movescount closes?:
                        MC app you could do far more on the ambits SA you can do nothing
                        Ambit 3 Peak with HRM, Movescount on Samsung S6 Active,Android 7.1.2…Suunto app installed for test only…
                          Kuba Sarata Bronze Member @Fenr1r
                          @Fenr1r You’re right but not with the Ambits 😉
                          • lohtseL Offline
                            lohtse @Fenr1r
                            oooooooooo share please pretty please lol
                            • lohtseL Offline
                              lohtse @isazi
                              I still have my ambit peak somewhere…this seems like a plan lol
                              • Fenr1rF Offline
                                Fenr1r @Kuba Sarata
                                @Kuba-Sarata @lohtse So long as you have a data connection. If not, you can actually do at least one more thing with an A3 and SA than with MC. You’re screwed on setup, routes, etc., with either app but (as I understand it) you can effectively offload Moves to SA. On a long, multi-day trek, that might save your records before the A3 starts overwriting them for lack of memory space.
                                  @pavel-samokha said in So, what are you going to do after Movescount closes?:
                                  Yes, you are correct. It is more about saving those data. But I understand that at the end of this month, only watch profile feature and route management would be possible through movescount.com. (link to “Suunto app zone” would be removed, just like other sections on the website). That is why I talk about loosing mini apps and loosing associated logs.
                                  Suunto Traverse
                                  pavel.samokhaP 1 Reply Last reply Reply Quote 0
                                    @sebchastang as I said it’s not clear to me if “Suunto app zone” (http://www.movescount.com/apps) to be shutdown. Generated data is not supported by Suunto App, for sure - but Apps Directory - not clear.
                                    lohtseL sebchastangS 2 Replies Last reply Reply Quote 0
                                    • lohtseL Offline
                                      lohtse @pavel.samokha
                                      Better not shut it down… I use mini apps far too much…
                                      At least two of my sports modes are purely based around mini apps and the data they collect… And the rest will have one or two if not more mini apps in them…
                                      pavel.samokhaP 1 Reply Last reply Reply Quote 1
                                        pavel.samokha @lohtse
                                        @lohtse would be interesting to know what apps and sportmodes, how you use them. But better as separate topic.
                                        lohtseL 1 Reply Last reply Reply Quote 0
                                          @pavel-samokha thank you for your information. Do you think “Suunto app” will support the generated data in the future ? Do you agree it is a loss and it is legitimate to ask for synchronizing and viewing those data in Suunto app ?
                                          Suunto Traverse
                                          • lohtseL Offline
                                            lohtse @sebchastang
                                            @sebchastang said in So, what are you going to do after Movescount closes?:
                                            I think it is!!!
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
