    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    The logic behind default GPS mode settings in different sports modes
    Scheduled Pinned Locked Moved Suunto 5
    bug
    84 Posts 8 Posters 23.8k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Tomas5T Offline
      Tomas5 Gold Members @Łukasz Szmigiel
      @łukasz-szmigiel well you are fast 😉
      Suunto Ambit 2 > Suunto 5 > Suunto Race 2
      Tomas5T 1 Reply Last reply Reply Quote 0
      • Tomas5T Offline
        Tomas5 Gold Members @Tomas5
        Today after latest firmware update i tried create custom mode.
        1. When i create “best” custom mode it defaults to performance every time and i can swith by upper right between performance/endurance.
        2. If i create custom mode with “good” mode it defaults to endurance and i can switch between endurance/performance by upper right.
        3. If i create custom mode with “ok” gps it defaults to custom mode. And i can switch between custom/performance/endurance by upper right button.
        So it is still needed to change custom mode to best if we want to default use perfomancd mode. And i we want get best from battery with “ok” gps accuracy we need to change it prior to excercise and than after excercise change custom back to “best” performance if we don’t want defaults to custom lowest GPS.
        It would be best if we could default to performance or last selected but loop trough performance/endurance/custom everytime with upper right button. ( i know at this point it is unlikely that we will get this change on old S5 but stilli had to try again )
        Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
        • Łukasz SzmigielŁ Offline
          Łukasz Szmigiel @Tomas5
          @tomas5 I think that it was already stated that it’s either desired behaviour or that S5 was never intended for such personalization of battery modes / accuracy.
          S9PP 2.50.28
          • Mitchell StarcM Offline
            Mitchell Starc @Łukasz Szmigiel
            @Łukasz-Szmigiel said in The logic behind default GPS mode settings in different sports modes:
            FYI: This is even more buggy than I initially thought. I just realized it as I was too lazy to change it to either Custom or Performance so I left it on broken post-custom Endurance. However when looking at path it seemed strange to me that the points plotted on the map are more like in 1 min fix instead of 2 min fix. So I’ve downloaded GPX from QS and it’s indeed 1 min fix.
            It seems that S5 doesn’t switch to Endurance from Custom. It seems so from the UI but judging from the GPX - the track is actually saved in 1 min intervals, so:
            There’s no OHR because the watch enforces Endurance and the UI changes to orange.
            But the GPS mode is as defined in custom (Good = 1 min).
            So what results is some kind of weird amalgamation Not a custom sports mode and not a default Endurance either.
            Steps to reproduce:
            Go to any outdoor mode
            Go to battery modes, set custom
            Set OHR on, set GPS good
            Confirm custom
            Notice start screen turns blue
            Either exit start screen or start the activity (doesn’t matter, it’ll work this time)
            Go to the same activity
            Notice the UI changes color to orange, indicating the watch defaults to Endurance
            Start the activity and record ~15 min or more
            Check GPX for timestamps - after initial few minutes of 1 sec it defaults to 1 min.
            Thanks for the heads-up! Sounds like a tricky bug with the S5 not properly switching to Endurance mode despite showing the UI change. The GPS fix sticking to 1 minute instead of 2, along with no OHR, definitely makes it seem like a strange mix of modes. Your steps to reproduce are clear, and it’s helpful to know what to watch for with the GPX timestamps. Hopefully, a fix is on the way for this! 😄
            Register Login
            • First post
              Last post
            Suunto Terms | Privacy Policy
