    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    The logic behind default GPS mode settings in different sports modes
    Scheduled Pinned Locked Moved Suunto 5
    bug
    84 Posts 8 Posters 23.8k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
      Dimitrios Kanellopoulos Community Manager @Tomas5
      @tomas5 well I suppose not a thing of such priority on the current phase.
      Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
      Tomas5T 1 Reply Last reply Reply Quote 0
      • Tomas5T Offline
        Tomas5 Gold Members @Dimitrios Kanellopoulos
        @dimitrios-kanellopoulos hopes you are right and they will fix it later. I still love suunto and suunto 5 watch are great. But this small bugs or simplified features reduce the user experience.
        Suunto Ambit 2 > Suunto 5 > Suunto Race 2
        • Tomas5T Offline
          Tomas5 Gold Members
          Still an issue in 2.14.16
          Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
            @tomas5 not going to be fixed soon. In a way it works as designed they say.
            Łukasz SzmigielŁ Tomas5T 2 Replies Last reply Reply Quote 0
            • Łukasz SzmigielŁ Offline
              Łukasz Szmigiel @Dimitrios Kanellopoulos
              @dimitrios-kanellopoulos to me it clearly looks like a bug. The only way to get 1 min fix in S5 is via custom battery settings and while they are being saved, the watch doesn’t default to custom. Rather - watch defaults to endurance, but if one goes to battery settings and just selects custom - it seems to remember last custom settings (ie. 1 min fix). So it’s not a matter of the watch not remembering the custom settings but somehow wanting to default to one of its main modes - performance or endurance.
              So it’s less than a battery customisation issue (which in essence works OK) but rather a smaller issue of watch forcing the predefined mode instead of custom.
              S9PP 2.50.28
              • Tomas5T Offline
                @dimitrios-kanellopoulos well it is clearly a bug. When you select custom mode to best. Next time it switch you to performance. This can be accepted because it is same. But when you change custom to good. Next time it switch you to endurance. But endurance means no whr but custom gps good means that you can have whr enabled.
                Next problem is that when i choose performance mode or endurance mode i can switch between them by upper right button. When i switch to custom with gps good i can switch between custom (blue), performance (green), endurance (orange) but next time i want do this excercise i am switched to endurance and i can no logner switch by upper right button to custom mode (blue) i need to go to setting again.
                It should switch to performance every next time and allow to change by upper right button between green,orange,blue. Or it should save and next time stay on prefered setting meaning if i choose performance next time it will be performance, if i choose endurance next time it sill be endurance, if i choose custom (best,good,ok) i should next time stay with my preference.
                But keep it fair, it is not painful bug, at least to me. I need to change to custom very rarely.
                  I won’t argue. But unfortunately I cannot push anymore for this one. My bug report got denied.
                  The reason I am saying this and taking the time to post here , is not to convince you it’s not a bug but rather to indirectly (and now directly) perhaps bother support with this.
                  I am not pleased with Suuntos take on this bug tbh.
                  Tomas5T Łukasz SzmigielŁ 2 Replies Last reply Reply Quote 2
                  • Tomas5T Offline
                    @dimitrios-kanellopoulos yeah, i know you do your best. Thanks for feedback.
                      @dimitrios-kanellopoulos I appreciate your effort. Thank you. I’m simply puzzled why it’s so low priority and I get it that it probably won’t be fixed 😐
                      S9PP 2.50.28
                      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                        Dimitrios Kanellopoulos Community Manager @Łukasz Szmigiel
                        @łukasz-szmigiel to be honest and without really knowing , maybe it’s going to be completely reworked or attached to a more bigger task.
                        I thought there was at least a workaround for this but I might be wrong.
                        Anyways. Additionally I would say ping me back here in eta 3 weeks after the product + fw is launched to push them again
                          Łukasz Szmigiel
                          FYI: This is even more buggy than I initially thought. I just realized it as I was too lazy to change it to either Custom or Performance so I left it on broken post-custom Endurance. However when looking at path it seemed strange to me that the points plotted on the map are more like in 1 min fix instead of 2 min fix. So I’ve downloaded GPX from QS and it’s indeed 1 min fix.
                          It seems that S5 doesn’t switch to Endurance from Custom. It seems so from the UI but judging from the GPX - the track is actually saved in 1 min intervals, so:
                          There’s no OHR because the watch enforces Endurance and the UI changes to orange.
                          But the GPS mode is as defined in custom (Good = 1 min).
                          So what results is some kind of weird amalgamation 😄 Not a custom sports mode and not a default Endurance either.
                          Steps to reproduce:
                          1. Go to any outdoor mode
                          2. Go to battery modes, set custom
                          3. Set OHR on, set GPS good
                          4. Confirm custom
                          5. Notice start screen turns blue
                          6. Either exit start screen or start the activity (doesn’t matter, it’ll work this time)
                          7. Go to the same activity
                          8. Notice the UI changes color to orange, indicating the watch defaults to Endurance
                          9. Start the activity and record ~15 min or more
                          10. Check GPX for timestamps - after initial few minutes of 1 sec it defaults to 1 min.
                          @Dimitrios-Kanellopoulos I know what you said before about this issue, so no additional pressure - just reporting my additional finding as it seems really buggy now.
                          S9PP 2.50.28
                          Dimitrios KanellopoulosD Mitchell StarcM 3 Replies Last reply Reply Quote 1
                            @łukasz-szmigiel said in The logic behind default GPS mode settings in different sports modes:
                            Go to any outdoor mode that will be bonkers afterwards 😛
                            Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 1
                              @łukasz-szmigiel I am a bit confused. Why would it not use 1min GPS ?
                                Btw I have a workarround. In order to remove the custom dbug, you can set the custom to be performance (change the settings as so) and then use it. It will be green the next time.
                                Maybe the same happened with you @Łukasz-Szmigiel but instead of making the custom performance you made it endurance ?
                                Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
                                  @dimitrios-kanellopoulos said in The logic behind default GPS mode settings in different sports modes:
                                  Well running, walking, you get the idea 😛
                                  It should use 1min GPS as defined in Custom battery mode. However - the GUI indicates that the watch is in Endurance, which is 2min GPS. Also, OHR is off despite being on in custom.
                                  So: UI is Endurance. OHR is Endurance. GPS is Custom.
                                  To sum it up.
                                  S9PP 2.50.28
                                    I know that you need to set the custom mode to equal performance in order to reset the bug.
                                    S9PP 2.50.28
                                      @łukasz-szmigiel isn’t endurance 1min 🙈?
                                      • EgikaE Offline
                                        Egika Platinum Member @Dimitrios Kanellopoulos
                                        @dimitrios-kanellopoulos yes, endurance is 1min, Ultra 2min
                                          Łukasz Szmigiel @Egika
                                          @egika, @Dimitrios-Kanellopoulos, seriously? Is endurance in S5 1 min fix?
                                          S9PP 2.50.28
                                          Dimitrios KanellopoulosD EgikaE 2 Replies Last reply Reply Quote 1
                                            @łukasz-szmigiel I think so. (if you want me I can ask the others)
                                            At least for s9 endurance is 1 min and ultra 5min. But I don’t use those modes personally.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
