    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    The logic behind default GPS mode settings in different sports modes
    Scheduled Pinned Locked Moved Suunto 5
    bug
    84 Posts 8 Posters 25.3k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Łukasz SzmigielŁ Offline
      Łukasz Szmigiel @Dimitrios Kanellopoulos
      @dimitrios-kanellopoulos so it may be that I’m dumb as a rock. I don’t know how but I was quite sure it’s 2 min in S5 so I was fighting with custom mode for my casual walks when I need just an estimation and there’s no need to drain the battery with 1s.
      But still ohr would be handy for better calories estimation as without ohr it’s significantly lower and it seems that one can’t force ohr with endurance if it’s not custom.
      S9PP 2.50.28
      Dimitrios KanellopoulosD Brad_OlwinB 2 Replies Last reply Reply Quote 1
        Dimitrios Kanellopoulos Community Manager @Łukasz Szmigiel
        @łukasz-szmigiel I get it and many at suunto. We will be changing the settings system. Takes a while though so don’t expect a change soon.
        Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
        Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 3
        • EgikaE Offline
          Egika Platinum Member @Łukasz Szmigiel
          @łukasz-szmigiel said in The logic behind default GPS mode settings in different sports modes:
          @egika, @Dimitrios-Kanellopoulos, seriously? Is endurance in S5 1 min fix?
          Sorry, got mislead by the word endurance. this thraad is about S5.
          It has no Endurance or Ultra. Just Best and Good.
          Best is 1s, good is 1min.
          Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
            Łukasz Szmigiel @Egika
            @egika isn’t it called performance (green) and endurance (orange)?
            S9PP 2.50.28
              @dimitrios-kanellopoulos errrr it just came to my attention that S5 does switch to 1s fix on navigation screen when on “good”. It even allows to load POI or route. I don’t think it used to be like this on previous firmware - I think that all navigation features were missing on S5 when not using performance. Is it something introduced in recent firmware or am I a potato?
              S9PP 2.50.28
              Dimitrios KanellopoulosD Brad_OlwinB 2 Replies Last reply Reply Quote 0
                @łukasz-szmigiel 😅
                Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 2
                  @dimitrios-kanellopoulos press both 😄
                  I swear it wasn’t there. But what do I know. I’m a potato.
                  Anyway - it opens some opportunities for actually using the “good” gps mode on S5, ie. on hikes where the speed is so low that 1s isn’t necessary but the navigation is a must. Good to know it’s there.
                  S9PP 2.50.28
                    Łukasz Szmigiel
                    Welcome back, it’s been awhile 😄
                    This time, your friendly potato would like to bring you, my fellow S5 users, a pro tip on how to get an extra battery mode that persists on a particular sports mode, as some may want to use it and it’s not widely explained in the manual.
                    So S5 has two battery modes built in - 1s with HR and 60s with no HR.
                    But if you set custom mode with GPS set to OK, a custom mode will be available (after exiting the training screen) with 120s fix (similar to Ultra on S9).
                    So if you set it - the next time you reach for this particular sports mode, a blue (custom) mode with 120s fix will be available to cycle via the top right button. Cool, eh?
                    The only minor drawback is that in S5 it’s impossible to disable HR in custom battery mode - the watch will always force OHR on so you’ll have to go to workout menu and disable it regardless.
                    But - for low speed activities when ascent/descent and OHR are not important (slow hikes or everyday walks) - this gives up to 80 hours of battery life - even more if you add screen timeout.
                    S9PP 2.50.28
                    • Brad_OlwinB Offline
                      Brad_Olwin Moderator @Łukasz Szmigiel
                      @łukasz-szmigiel It is 1 min on the S5, I have done testing on this.
                      Vector/T6c/Vertical 2 Ti
                        This is true for the S9 series as well and has been implemented for a very long time.
                        Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 1
                          Łukasz Szmigiel @Brad_Olwin
                          @brad_olwin said in The logic behind default GPS mode settings in different sports modes:
                          What do you mean? The yellow mode (“good”)? But you can also custom set 2 min as blue with “ok” setting. Or does the watch force 1 min? 😄 I’ll have to check my fit file to be sure 😛
                          S9PP 2.50.28
                          Tomas5T 1 Reply Last reply Reply Quote 0
                          • Tomas5T Offline
                            Tomas5 Gold Members @Łukasz Szmigiel
                            @łukasz-szmigiel time estimstion is different so it should be longer in that setting.
                            Suunto Ambit 2 > Suunto 5 > Suunto Race 2
                            Łukasz SzmigielŁ 2 Replies Last reply Reply Quote 0
                              Yeah. I know now. That’s why I’m a potato - I was quite sure that when you start with anything else but 1s, navigation will be off 😉
                              S9PP 2.50.28
                                Łukasz Szmigiel @Tomas5
                                @tomas5 it should be - but so is when you use different modes than 1s but have eta/ete screens - the watch will force 1s regardless of your setting - and you’ll see wrong estimations.
                                So I wouldn’t bet on those estimations 😉
                                S9PP 2.50.28
                                  @tomas5 well it seems that OK is OK is 120s:
                                       <trkpt lat="51.0729984" lon="16.9918096">
                                          <ele>120.4</ele>
                                          <time>2021-07-27T15:06:59.000Z</time>
                                          <extensions>
                                            <power></power>
                                            <distance>2167</distance>
                                            <gpxtpx:TrackPointExtension>
                                              <gpxtpx:cad>49</gpxtpx:cad>
                                              <gpxtpx:speed>1.3</gpxtpx:speed>
                                            </gpxtpx:TrackPointExtension>
                                          </extensions>
                                        </trkpt>
                                        <trkpt lat="51.0723648" lon="16.9937936">
                                          <ele>124.8</ele>
                                          <time>2021-07-27T15:08:59.000Z</time>
                                          <extensions>
                                            <power></power>
                                            <distance>2322</distance>
                                              <gpxtpx:cad>62</gpxtpx:cad>
                                          </extensions>
                                        </trkpt>
                                        <trkpt lat="51.0735808" lon="16.9948496">
                                          <ele>124</ele>
                                          <time>2021-07-27T15:10:59.000Z</time>
                                          <extensions>
                                            <power></power>
                                            <distance>2477</distance>
                                              <gpxtpx:cad>50</gpxtpx:cad>
                                          </extensions>
                                        </trkpt>
                                  S9PP 2.50.28
                                  Brad_OlwinB 1 Reply Last reply Reply Quote 1
                                    Łukasz Szmigiel
                                    Gotta love what strava does to modes other than 1s though 💩
                                    S9PP 2.50.28
                                    • Tomas5T Offline
                                      @łukasz-szmigiel I think strava didn’t have problem with Ambits 12 seconds interval. So maybe bug related only to this single move ?
                                        @tomas5 I think it’s typical to Strava. I know that there’s a workaround to manually pause the workout at last once which gets rid of Strava’s magic. Perhaps Strava’s algorithm that calculates moving time goes nuts with such long GPS fix intervals.
                                        S9PP 2.50.28
                                          @łukasz-szmigiel All you have to do is set to race, that eliminates the lying Strava does and shows moving time=actual time and the file will be fine. It is Strava’s attempts to make everyone look better by removing non-moving time that messes this up since it received altitude data or cadence data with no GPS data.
                                            @brad_olwin yeah but can it be done on walking activity too? I might have missed it in the settings. It’s pretty lame that they don’t apply a certain threshold so I ended up walking at 103 km/h 😄
                                            S9PP 2.50.28
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
