    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Direct drive indoor trainer
    57 Posts 14 Posters 10.8k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • BulkanB Offline
      Bulkan Moderator @Dimitrios Kanellopoulos
      @Dimitrios-Kanellopoulos yes, all the issues are solved, even one where the temperature wrong. Now works pretty well. The “issue” is if you use zwift or any other app for virtual cycling right now there isn’t any watch which use the data of zwift (speed, ascend…) while you are riding. Is not and issue for me because I transfer the fitfile from training peaks to SuuntoApp with RunGap.
      @Dwartus if you want a web service to summarize everything I recommend you quantied-slef, works pretty well and you can have all the data which is in the watches.
      Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
      D 1 Reply Last reply Reply Quote 0
      • J Offline
        johann.fuehrer Bronze Member @Dwartus
        @Dwartus said in Direct drive indoor trainer:
        @johann-fuehrer I have read your other topic.
        Your smart trainer Tacx Neo is able to send Power, Cadence and Speed by Bluetooth ?
        Yes, and Garmin and Polar Devices catch up all of them
        Your S9Baro is able to catch Cadence and Speed from the Tacx Neo by using paire a « Bike POD » ?
        Thanks
        Yes. But no Power, although it is found as PowerPod when I attach search for devices, when starting the workout, no connection is made anymore… Same for A3. Seems to be a BT issue.
        What I want is: Power, Speed, Cadence and Distance from the trainer. I was not able to configure this with any Suunto device (A2, A3, S9B) but even my old V800 makes it. And I’m not even talking about parallel connection to the computer for Zwift, Rouvy, Sufferfest or whatsoever! All other stuff was disabled, turned off and out of reach (needed for STRYD pod which can mess up your setting because of being on always 😉 )
        • D Offline
          Dwartus @Bulkan
          @Bulkan thank you for information.
          Does « Quantified self » can be use as Movescount was (history of activities, tags, training effect performed by FirstBeat or other (TSS as example) ?
          Do you have a short comparaison of rungap//quantifed self ?
          Is it same functionnalities ?
          thanks
          I created a new topic within Spartan regarding smart trainer and data sync not possible.
          But lots of interest things on this topic, thanks to all !!!
          Are you able to delete the new topic in Spartan group ?
          J 1 Reply Last reply Reply Quote 0
          • J Offline
            thanks
            Hello, I think for QS @Dimitrios-Kanellopoulos would be THE source of knowledge 😉 You will find out, why…
            • D Offline
              Dwartus @johann.fuehrer
              @johann-fuehrer I think a smart trainer (Tacx, Wahoo, …) will send Power, Cadence and Speed but not a distance, the distance will be calculate by device (watch or GPS), isn’t it ?
              It’s really strange because the Wahoo Kickr core, send also Power, Cadence and Speed (receive by Wahoo app and Garmin), with A2 and Spartan I can’t receive Cadence and Speed, but Power is possible. And you is clearly the opposite…
              Do you know if Suunto work on this issue ??
              • J Offline
                @Dwartus No idea if Suunto is seeing this even as an issue or is working on a fix. Distance could be calculated if a wheel size (virtual) is configureable for such trainers and the watch will do so. Never will be like in real live, but as a rough estimation it would be ok…
                D BulkanB 2 Replies Last reply Reply Quote 0
                • D Offline
                  @johann-fuehrer Your S9Baro is 2.12.30 software version ??
                  I’m always thinking of buying a S9Baro …
                  • J Offline
                    Yes, it was…
                    • BulkanB Offline
                      Bulkan Moderator @johann.fuehrer
                      @johann-fuehrer I recall something about the bluetooth of the Neo smart, about the broadcasting of all the data via bluetooth but I didn’t find it to bring it here. That problem with ant+ isn’t there. What you can try is cable which converts the ant+ signal to bluetooth.
                      I own the version 1 of the Neo and I don’t paired the Suunto to the trainer, I use zwift. I prefer to have all the info and I enjoy it more. At the beginning I recorded in the suunto as a indoor cycling but unpaired to the trainer… but I don’t do it anymore.
                      About QS it doesn’t have TSS. If you want training load, check out runanalyze or Strava free account with the extension called elevate in Chrome.
                      • D Offline
                        Dwartus
                        Hello, thanks for information regarding Quantified Self, I will have a look on the dedicate post, and also try to create an account to play with.
                        Regarding the main topic, that the watch (A2 or Spartan or Suunto 9) doesn’t catch all signals comes from smart trainer (Power, speed and cadence), does someone of Suunto teams can give support here or maybe give timeline to solve it ??
                        Unfortunately, Garmin and Polar catch all signals form smart trainer.
                        Thank you
                        isaziI 1 Reply Last reply Reply Quote 0
                        • isaziI Offline
                          isazi Moderator @Dwartus
                          Better contact Suunto directly for that. Have you asked support?
                          Blog: isazi's home
                          • D Offline
                            Dwartus @isazi
                            @isazi Yes, I’ve done two phone call and one email traffic -> no answer.
                            At the second phone call, Suunto support say me that “they never tested Wahoo and Tacx with Suunto”.
                            Sorry, but I don’t know really if they understand sometimes…
                            Does someone here work in Suunto R&D departement or something like that ??
                            Thanks
                            • isaziI Offline
                              I am aware of two Suunto developers (app and backend I guess) in the forum. Not sure if any firmware developer is here.
                              Blog: isazi's home
                                Dimitrios Kanellopoulos Community Manager
                                So I raised this issue.
                                I am not sure when this can be improved to be honest but now the R&D + PO teams are aware of this. Thank you
                                Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                                1 Reply Last reply Reply Quote 5
                                • D Offline
                                  Dwartus
                                  @Dimitrios-Kanellopoulos thank you for your help.
                                  Do you know if Suunto confirm this trouble or will work on it ? or just they received claim ?
                                  As you know I’m in a way to buy a Suunto 9, but I would like to know if this issue will be solve or not before buy it… (I have other question task to be check as example disable the wrist HR definitevly to avoid battery consumption during day working, compatible H10/TickrX, …)
                                  Thank you
                                  • isaziI Offline
                                    You can disable 24h heart rate monitor, and H10/TickrX heart rate monitor are compatible, but if you are interested in more discussion about these topics search the forum or write a new post 🙂
                                    Blog: isazi's home
                                    • D Offline
                                      Dwartus @isazi
                                      @isazi Thank you, Yes it’s the idea to find correct topics about.
                                      • D Offline
                                        Dwartus
                                        Hello,
                                        I saw the Software update 2.13.18 released.
                                        But it seems not to be concern the issue of this topic 😞
                                        Do you have an idea of the reason ??
                                        Does this topic is really take into account ?
                                        Thanks
                                        Dimitrios KanellopoulosD BulkanB 2 Replies Last reply Reply Quote 0
                                          Dimitrios Kanellopoulos Community Manager @Dwartus
                                          @Dwartus well it’s 17 days that passed.
                                          That is not something much as of development time.
                                          Also I didn’t say that they will do this feature. They just know that people want this.
                                          • BulkanB Offline
                                            Bulkan Moderator @Dwartus
                                            @Dwartus I use trainer and I get your point about the Suunto getting all the signal, but sincerely I would prefer to support Zwift as a partner because all the indoor trainer I do is in zwift, but if I wouldn’t use Zwift I will need a better support of the trainer in my Suunto watch.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
