    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Direct drive indoor trainer
    57 Posts 14 Posters 9.3k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • D Offline
      Dwartus
      For me, this is not a new function, but rather a correction/improvement.
      The Suunto are able to be connect at sensor (power, speed, …), and sensors of indoor trainer are not detected. But detected by others (Garmin, Polar, Zwift, …).
      @Bulkan I also use Zwift to do my training session, but not sure to do it all the time due to other simulator and also the price. I can also use Wahoo platform for one or two session as example.
      I send data (90% of my activities) directly in Strava platform.
      But at end the real and full tracking is done by Suunto.
      • D Offline
        Dwartus
        Hello,
        Is there a new software released since 2.13.18 ?
        Do you know, if this topic is now correct if new software released ?
        Thanks
        DMytroD 1 Reply Last reply Reply Quote 0
        • DMytroD Offline
          DMytro @Dwartus
          @dwartus no new firmware for the watch yet.
          • D Offline
            Dwartus
            Hello all,
            I now seen the software release 2.16.26
            Does somebody can tell me if this point is now solved / corrected ?
            Thank you
            • DMytroD Offline
              DMytro @Dwartus
              @dwartus nope, works the same way as before.
              • D Offline
                Dwartus @DMytro
                @дима-мельниченко
                OK, did you check with your trainer if you can connect the sensors (cadence, power and speed) ?
                Thank you
                DMytroD 2 Replies Last reply Reply Quote 0
                • DMytroD Offline
                  DMytro @Dwartus
                  @dwartus no, I’m drawing my conclusions from official changelog and general suunto treatment of pods connections. If one could have used multiple pods simultaniously - it definetely would have been mentioned.
                  But maybe someone who did try can suplement/correct my answer.
                  • DMytroD Offline
                    DMytro @Dwartus
                    @dwartus so, bottomline - 1 pod at a time atm.
                    • D Offline
                      Dwartus
                      Does somebody can test this correction (connect at same time RPM, speed and power sensor from a trainer) ??
                      Thank you
                      aroo7A 1 Reply Last reply Reply Quote 0
                      • aroo7A Offline
                        aroo7 Bronze Member @Dwartus
                        @dwartus Nothing has been fixed. In my case, the watch (S9P) connects to the trainer (Elite) only as a power pod. I must admit that it is very disappointing that Suunto has not solved this problem for so long.
                        D 1 Reply Last reply Reply Quote 1
                        • W Online
                          wakarimasen Gold Members
                          Not sure if it helps…Suunto Bike Sensor With Turbo Trainer
                          Suunto Race Titanium
                          Suunto Ambit3 Peak
                          Polar H10
                          Polar OH1
                          • D Offline
                            Dwartus @aroo7
                            @aroo7 Thanks for your feedback, at least we are two guys that waiting this correction looking forward.
                            In my case this is a Wahoo core trainer.
                            The last answer from Suunto support (from 4 August 2021):
                            “Our software departement received some comments related to this issue.
                            At the moment this is under evaluation to introduce this correction for these trainer type, but this is a long projet to do, so no date for a first release.
                            Find original (in French, sorry):
                            Thanks
                            • D Offline
                              Dwartus @wakarimasen
                              @wakarimasen Thank you for this link. This is quite the same issue/way as this topic.
                              • aroo7A Offline
                                @dwartus Thanks for the message! We have to wait but it doesn’t look good, shame
                                • D Offline
                                  Dwartus @aroo7
                                  Hello,
                                  Does somebody can test the release software 2.18.20 for the correction discussed in this topic ?
                                  The winter is coming and I’m still hesitating between buy S9 or definitely a garmin GPS to connect the smart driver…
                                  For sure, I prefer to keep the Suunto brand !
                                  Than you
                                  Regards
                                  • D Offline
                                    Dwartus @Dwartus
                                    @aroo7 : Hello, are you able to test the firmware release 2.18.20 with your Elite trainer, to check if any changes appears ?
                                    Meantime, I bought another GPS, currently under evaluation 🙂
                                    • aroo7A Offline
                                      @dwartus nothing has changed, the situation is the same as before the update
                                      • First post
                                        Last post
                                      Suunto Terms | Privacy Policy
