    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Pros/Cons of Suunto 9 BARO * ONLY * be fair and polite!
    330 Posts 46 Posters 77.3k Views 48 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      Here is my point of view and I try to keep a comparison with the Fenix 6x Pro out of this:
      Pro:
      • Great user interface
      • easy usability
      • no overload of options/functions
      • very good GPS tracks on the mountains in my area (Southern Germany)
      • native support for running power
      Cons:
      • lack of watchface configuration for intervals (e.g. 3 metrics: timer or distance, power, heartrate)
      • missing additional data from external sensors in the FIT file
      • vibration alarm too less intensity (I sometimes do not recognize it while sleeping)
      • zhang965Z Offline
        zhang965
        The step counter is too sucking to be a con ?
        Winners Wear Winners
        • A Offline
          azeanic
          I ran a 109k race recently and there was a Suunto 9 (me), a Coros Vertix and a Fenix 5 (two other runners) My observations were.
          • Suunto 9, the distance was off by quite a bit. I had to probably minus 6-8k off the current distance on the watch to match the course. Saving grace was the navigation and course profile. The estimated time arrival was quite useful as well.
          • Fenix 5, had the most accurate distance among the three.
          • Coros Vertix, had the best battery life among us 3 at the 60km mark. I had to disable OHR and charge a bit half-way through the race and finished with about 18% after 29.5 hours. Whilst I vaguely remember the Coros has more than enough battery to get to the finish line without a recharge.
          freeheelerF sartoricS zhang965Z ? 4 Replies Last reply Reply Quote 1
          • freeheelerF Offline
            freeheeler @azeanic
            @azeanic
            never run out of battery says suunto…?!
            living sideways
            • sartoricS Offline
              sartoric Moderator @azeanic
              @azeanic said in Pros/Cons of Suunto 9 BARO * ONLY * be fair and polite!:
              Out of curiosity, was Coros using OHR and same precision (of course,not the same but equivalent) for GPS ?
              SVTS - 2.50.28
              SSSWHR BARO Amber - 2.8.32
              Samsung A5 2016 - Android 7.0
              Suunto App Android 6.8.9 beta
              A 1 Reply Last reply Reply Quote 0
              • zhang965Z Offline
                zhang965 @azeanic
                @azeanic which GPS precision did you use for the running ? I think it’s a problem with FUSEDTRACK
                A freeheelerF 2 Replies Last reply Reply Quote 0
                • A Offline
                  azeanic @zhang965
                  @zhang965 Best GPS Mode.
                  • A Offline
                    azeanic @sartoric
                    @sartoric Not sure what’s the precision but OHR was on based off his Strava logs.
                    freeheelerF 1 Reply Last reply Reply Quote 0
                      freeheeler @azeanic
                      @azeanic
                      how does your s9 and garmin/coros track look compared in strava?
                      …despite that I noticed that strava shows a compressed trackline compared to SA and MC…
                      living sideways
                        freeheeler @zhang965
                        @zhang965
                        you’ve got fusedtrack disabled? and better precision?
                        living sideways
                        • ? Offline
                          A Former User @azeanic
                          Coros Vertix is advertised to have 60 hours in the best GPS mode, but the accuracy isn’t as good as Suunto 9 from some discussions that I’ve seen so far.
                          Suuto 9 could have survived the entire race on a single charge in Performance mode if OHR was turned off from the beginning, but that would be a close call.
                            freeheeler @Guest
                            @silentvoyager
                            does chest strap use less battery than ohr?
                            living sideways
                            zhang965Z 1 Reply Last reply Reply Quote 0
                            • zhang965Z Offline
                              zhang965 @freeheeler
                              @TELE-HO of course, chest belt requests less battery
                              J 1 Reply Last reply Reply Quote 0
                              • J Offline
                                johann.fuehrer Bronze Member @zhang965
                                @zhang965 what makes you think so? Bluetooth/ANT+ consumes also energy and WHR is optimized to use also as less as possible? Just because chast Belt has it’s own battery for sensor and transmission?
                                zhang965Z EgikaE ? 3 Replies Last reply Reply Quote 0
                                • zhang965Z Offline
                                  zhang965 @johann.fuehrer
                                  @johann-fuehrer said in Pros/Cons of Suunto 9 BARO * ONLY * be fair and polite!:
                                  I didn’t think so, it just acts so,
                                  try it yourself, in the same sport mode, s9 will show different estimated battery life.
                                  J freeheelerF 2 Replies Last reply Reply Quote 1
                                  • J Offline
                                    @zhang965 ---- no chance — still on Ambit2 — waiting for improvements in the App and Firmware before wasting money again …
                                    • EgikaE Offline
                                      Egika Platinum Member @johann.fuehrer
                                      It’s true.
                                      WHR consumes more energy because the LED’s use way more than BTLE.
                                      BTLE has an average current of ~0.05mA (depending largely on the chipset)
                                      The high rate LED switching easily uses 10x as much power…
                                      J 1 Reply Last reply Reply Quote 3
                                      • J Offline
                                        johann.fuehrer Bronze Member @Egika
                                        @Egika said in Pros/Cons of Suunto 9 BARO * ONLY * be fair and polite!:
                                        It’s true.
                                        Thx for the info!
                                          @zhang965
                                          what is, by your experience, the battery life in best GPS mode?
                                          and another technical question: is it possible to get oxygen values with these LED’s or would it require a different sensor?
                                          living sideways
                                          • zhang965Z Offline
                                            zhang965
                                            It’s a wise strategy, I think suunto number line will never get the same (feeling ) as ambit line.
                                            Personally I recommend you to get a second hand SSU if you don’t want wasting money, or garmin/polar stuff.
                                            The difference between ambit and suunto number line is huge, I think as long as you stay with ambit, you will get harder to understand a new generation watch
                                            J pilleusP 2 Replies Last reply Reply Quote 0
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
