    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 Baro takes very long to find GPS signal before a move
    134 Posts 29 Posters 40.1k Views 29 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • inkognitoI Offline
      inkognito Platinum Member
      Hi guys, just one thought: Sometimes I feel like the GPS status arrow probably freezes even though the GPS signal is already acquired before starting the exercise… The GPS arrow symbol is grey and blinking. But once I press the lower button to access the options and immediately press the upper button to go back to the “Start screen”, the arrow immediately turns green. Cannot this be the case? Could you test this when acquiring GPS signal takes noticeably long?
      SV: fingers crossed :D
      S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
      Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
      Despite some pretty bad luck, I still love Suunto!
      • ? Offline
        A Former User @Łukasz Szmigiel
        @Łukasz-Szmigiel yes, I tried all possibilities. At this moment I use GPS+Galileo. It look like fastest. But as I wrote, it is happen only when I have worst signal in city. When I am in open area it start very quickly. But it is interesting for me, that if I use in the same bad conditions Ambit2 (both together on one arm) with Ambit I can run in few seconds and for S9 wait more than minute…
        • ? Offline
          A Former User @inkognito
          @inkognito Ok, when I will next time waiting, I will try it. Thank you.
          • Phil PowellP Offline
            Phil Powell @isazi
            @isazi just checked and it’s showing yesterday’s date from when I last synced it. Doesn’t seem to have auto updated the agps
            Phil PowellP 1 Reply Last reply Reply Quote 0
              Phil Powell @Phil Powell
              @Phil-Powell also has an occasional issue where it’s turned itself off completely. Was like that out of the box and has done it twice. At the moment screen is completely blank and if you hold top right button for soft reset it beeps but that’s it
              • Richard ThygesenR Online
                Richard Thygesen @MaxiPalle
                @MaxiPalle I have noticed that my AGPS file hasn’t been updated since december 18th. Soft reset and reinstallation of the app hasn’t resolved the issue. The app tries to optimize GPS every sync but it never shows up on the watch. Now it says that AGPS is n/a on the watch. Can anyone help?
                S9
                S9 Peak
                Race
                Phil PowellP Łukasz SzmigielŁ 2 Replies Last reply Reply Quote 0
                  Phil Powell @Richard Thygesen
                  @Richard-Thygesen mine has completely turned itself off. Managed to get a display back by holding soft reset button a few times. But now is also showing assisted gps not available
                  • Łukasz SzmigielŁ Offline
                    Łukasz Szmigiel @Richard Thygesen
                    @Richard-Thygesen the watch needs approx. 15 minutes to unpack the data after it finishes syncing. Did you wait long enough before checking if AGPS is fresh?
                    S9PP 2.50.28
                    Richard ThygesenR 1 Reply Last reply Reply Quote 0
                      Richard Thygesen @Łukasz Szmigiel
                      @Łukasz-Szmigiel yes I have waited way more than 15 minutes.
                      S9
                      S9 Peak
                      Race
                      Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
                        @Richard-Thygesen this shouldn’t happen then. Do you have latest firmware and Suunto App installed?
                        S9PP 2.50.28
                        Richard ThygesenR 2 Replies Last reply Reply Quote 0
                          @Łukasz-Szmigiel yes the most recent firmware and the most recent beta version of the app.
                          S9
                          S9 Peak
                          Race
                            @Łukasz-Szmigiel This is how it looks on the watch.
                            S9
                            S9 Peak
                            Race
                              @Richard-Thygesen I’ve just called Suunto support and gone through a factory reset with them. Seems to ok again now fingers crossed
                                Richard Thygesen @Phil Powell
                                @Phil-Powell Perhaps a hard reset is all that is left to do for me also.
                                S9
                                S9 Peak
                                Race
                                  Dimitrios Kanellopoulos Community Manager
                                  Let me help. If you are on latest software it will show processing once the sync is done.
                                  I am suspecting that sony has issues with updating the agps. Reporting this.
                                  Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                                  Richard ThygesenR 2 Replies Last reply Reply Quote 1
                                    Richard Thygesen @Dimitrios Kanellopoulos
                                    @Dimitrios-Kanellopoulos on the app is says optimizing GPS after syncing activities and resources etc. It takes a fairly long time and when its done I see a green check mark. It does this every sync. I think it only did the optimizing GPS once a day before this issue occurd.C945D1A9-B889-4EF8-BF82-0E66284AAC0D.png D9ABA597-EB69-49FE-9AC0-75B581E8995D.png
                                    S9
                                    S9 Peak
                                    Race
                                      @Dimitrios-Kanellopoulos now I have the newest A-GPS file. Not sure if it is related but after changing the setting to GPS only an syncing I got the file.
                                      S9
                                      S9 Peak
                                      Race
                                      helgonet12H 1 Reply Last reply Reply Quote 0
                                      • helgonet12H Offline
                                        helgonet12 @Richard Thygesen
                                        @Richard-Thygesen This happened to me as well a couple of days ago. Did the same as Richard Thygesen. Changed to gps only and Agps updated almost directly.
                                          Phil Powell @helgonet12
                                          @helgonet12 how do you change to gps only. Is it the gps qzs ?
                                          Richard ThygesenR helgonet12H 2 Replies Last reply Reply Quote 0
                                            @Phil-Powell yes thats the one, GPS+ qzss
                                            S9
                                            S9 Peak
                                            Race
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
