    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 Baro takes very long to find GPS signal before a move
    134 Posts 29 Posters 41.5k Views 29 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • surfboomerangS Offline
      surfboomerang @kabzior
      @kabzior Do you select your exercise indoor? In other words, is GPS active indoor? I noticed on my s9 baro that when I select an exercise indoor and then walk out the door it takes sometimes significantly longer to get a fix then when I select an exercise while I am standing outside.
      I’m the last case I almost always get a fix immediately
      Suunto Vertical Titanium Solar
      OnePlus Nord 4
      sartoricS 1 Reply Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @surfboomerang
        @surfboomerang
        Starting the GPS fix inside can be counterproductive as the watch starts looking for the satellites it guess to find based on AGPS and last position, but it can’t (in most cases) as it is indoor so it starts the default search.
        This can increase the fix time when you go outside and it’s a common GPS “issue”.
        But I don’t think it’s @kabzior case here
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.11.12 beta
        • kabziorK Offline
          kabzior Bronze Member @Mff73
          @Mff73 yeah, you are right, the next day after reset watch found fix in about 15 sec, just like when it was brand new 🙂
          unfortunately day after that it took again about 2 min and yesterday 4-5 min 😞
          also when entering sport mode watch displayed a message like “sync your watch to suunto app to get best gps accuracy” (never seen that before), but AGPS date in settings was up to date.
          @surfboomerang @sartoric
          I do not select activity when indoor, I go outside the building and do that then, usually before I chose my spotify playlist i get fix, but not those last days now.
          Mff73M Brad_OlwinB 2 Replies Last reply Reply Quote 0
          • Mff73M Offline
            Mff73 @kabzior
            @kabzior
            When GPS fix is long, could it be because you are searching GPS in a new location from last one, and “far” from previous one ? If so, then, GPS fix is also a bit longer, as the watch remember the previous location.
            SSU (retired), SV1, SV2
            Wife : S9PP
            SA: Always the latest beta :)
            Android + Galaxy S205G
            kabziorK 1 Reply Last reply Reply Quote 0
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @kabzior
              @kabzior There might be something wrong, I cannot remember the last time it took me more than 10-20s to get a GPS fix.
              Vector/T6c/Vertical 2 Ti
              surfboomerangS 1 Reply Last reply Reply Quote 1
                surfboomerang @Brad_Olwin
                @Brad_Olwin same for me. Always a fix in seconds.
                OnePlus Nord 4
                • kabziorK Offline
                  @Mff73 said in S9 Baro takes very long to find GPS signal before a move:
                  That’s not the case, I left home, watch got fix in 20 sec, run to a location, stopped activity, went into building, one hour later left building and in the exact same spot selected activity and fix was not found for about 3 min.
                  Same for me before all of this started to happen. You think maybe a factory reset should be performed?
                  sartoricS M 2 Replies Last reply Reply Quote 0
                  • sartoricS Offline
                    sartoric Moderator @kabzior
                    @kabzior said in S9 Baro takes very long to find GPS signal before a move:
                    Just to be sure, when you say “stopped” do you really mean it or do you mean “paused” ?
                    SVTS - 2.50.28
                    • M Offline
                      Mi_chael Bronze Member @kabzior
                      @kabzior
                      If it’s a high building, it’s normal.
                      May you can try in clear area like a parc or on football field?
                      • kabziorK Offline
                        kabzior Bronze Member @sartoric
                        @sartoric said in S9 Baro takes very long to find GPS signal before a move:
                        I really mean it, I never pause activity.
                        @Mi_chael said in S9 Baro takes very long to find GPS signal before a move:
                        OK, will do.
                        • Phil PowellP Offline
                          Phil Powell
                          I’m having the same issue. Tried soft reset and agps is showing current date, but locking on to gps is taking anywhere up to 4mins
                            Brad_Olwin Moderator @Phil Powell
                            @Phil-Powell How long after syncing to the phone did you start the watch, it takes about 15 min to unpack the AGPS data.
                            Phil PowellP 1 Reply Last reply Reply Quote 1
                              Phil Powell @Brad_Olwin
                              @Brad_Olwin thanks for the reply. I’ve tried it just after syncing and sometimes a day or so after the last sync. Today was about 20mins after syncing and didn’t seem to take as long. Only had this s9 a couple of weeks so still getting used to it. Do you recommend syncing it before every time that I’m going to use the gps
                              • sartoricS Offline
                                sartoric Moderator @Phil Powell
                                @Phil-Powell
                                Once a day it’s enough as the agps file is updated daily
                                SVTS - 2.50.28
                                  Phil Powell
                                  So just sync daily to the app should make a difference. Thanks for the help. 😊
                                  isaziI 1 Reply Last reply Reply Quote 0
                                  • isaziI Offline
                                    isazi Moderator @Phil Powell
                                    @Phil-Powell if you leave your watch connected to the app all the time, you don’t have to do much at all. It will update the AGPS file at night I believe, or first thing in the morning.
                                    Blog: isazi's home
                                    Phil PowellP 2 Replies Last reply Reply Quote 1
                                      Phil Powell @isazi
                                      @isazi I leave it connected to the app and normally sync it after a workout to get the data. But I’ll check that it auto updates the agps. Thanks
                                      • ? Offline
                                        A Former User @Phil Powell
                                        @Phil-Powell Sometimes I have the same issue. Mostly if I start training in city. Here I wait minutes to find position. Yes, here is not so good signal (big buildings). But if I compare it with my old Ambit 2, they started in few seconds in the same position. Maybe inner antenna in S9? My AGPS is synced through night. Every morning when I get up I have actually version.
                                        Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
                                        • Łukasz SzmigielŁ Offline
                                          Łukasz Szmigiel @Guest
                                          @mcindr have you tried different GNSS configuration? Ie. GPS + Beidou or only GPS?
                                          S9PP 2.50.28
                                          Phil PowellP ? 2 Replies Last reply Reply Quote 0
                                            Phil Powell @Łukasz Szmigiel
                                            @Łukasz-Szmigiel I’ve not changed any settings from the factory ones
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
