    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 Baro takes very long to find GPS signal before a move
    134 Posts 29 Posters 40.0k Views 29 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • MaxiPalleM Offline
      MaxiPalle Bronze Member
      Have some problems with finding a gps signal before a move since a few days.
      I usually start where I finished my previous move - Right in front of my house.
      Since a few days it really takes Long to find a gps Signal (2-3 minutes) - in the past (Maybe one week ago) it only took a few seconds.
      Does anyone know what might cause this problem?
      Brad_OlwinB Richard ThygesenR 2 Replies Last reply Reply Quote 6
      • AudaxjoeA Offline
        Audaxjoe
        If in doubt try a soft reset and/or sync with SA or Movescount.
        Suunto Vertical
        Suunto 9 BARO
        Garmin Fenix 3, 5
        Suunto Vector
        S 1 Reply Last reply Reply Quote 0
        • S Offline
          Shrek3k @Audaxjoe
          @Audaxjoe usually a good proposal, nevertheless I have the same issue for the last weeks, no matter if freshly reset, synced with SA wirelessly and/or with MC by cable. Additionally the GPS-reception is rather poor under nearly all circumstances (currently I have to admit that is has the slowest time to pick up GPS since my Garmin 305, the Garmin Fenix has been slightly better, the SSSWHR and Ambit 2 and 3 extremely faster and better).
          So I have no solution, but simply join the club of not so positively excited S9-users (the same still valid for SA …)
          P.S.: it does not even become significantly better, when being used at the same starting point, but when used in a new place (approx 200-300km away) it significantly worsens. But mostly, after approx 2-5 Minutes there will be at least initial GPS coverage.
          using a Suunto Vertical & Suunto Wings; mostly running (AKA stomping around) and cycling through the northern german "wilderness", and wherever else I have the chance to do so
          OS - Android 16/Pixel Pro 7
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @MaxiPalle
            @MaxiPalle This is most likely due to the AGPS file not being updated or present in the watch. My S9 acquires a GPS fix in seconds. Check Settings/General/About and make sure the AGPS file is current. If not, then perform a sync. If the sync is failing to restore/update AGPS then soft reset the watch.
            Vector/T6c/Vertical 2 Ti
            1 Reply Last reply Reply Quote 4
              Dimitrios Kanellopoulos Community Manager
              After sync check you have AGPS.
              Settings -> general -> about
              Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
              MaxiPalleM 1 Reply Last reply Reply Quote 1
              • S Offline
                Shrek3k
                AGPS at least looks good (of course I can’t check the content). Today it is still 2019-06-12T00:0:00Z (checked it before and it always looked like the most current version)
                Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                  Dimitrios Kanellopoulos Community Manager @Shrek3k
                  @Shrek3k perhaps the battery mode?
                  • S Offline
                    Shrek3k @Dimitrios Kanellopoulos
                    @Dimitrios-Kanellopoulos is on performance; and I am a little frustrated but mostly surprised. Simply waiting for an update (watch not SA 😉 … but who is not 😁) somehow expecting to see a miracle happen.
                      @Shrek3k its a bit strange that it takes time to be honest. I have not experienced that.
                      • Saketo NemoS Offline
                        Saketo Nemo Moderator
                        trying to reset all settings from suuntolink?
                        • S Offline
                          @Dimitrios-Kanellopoulos me neither (At least not with Suunto … but very often with Garmin), especially frustrating that my wifes Ambit 3 is so much faster and exact, when synced at the same time and even used during the same activity (running together)
                            @Shrek3k is that after a soft reset? Because after a reset of the watch (12s upper button) it will take longer…
                            Perhaps your watch softresets it self?
                            You can chec kthat via the pressure chart if it has gaps.
                            • S Offline
                              Shrek3k @Saketo Nemo
                              @Saketo-Nemo no, as I usually sync with SA during workdays (I am a weekly commuter without PC during the week), might check in the next days when there are no changes …
                              • S Offline
                                @Dimitrios-Kanellopoulos where can I find the pressure chart? 😳
                                Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                                  @Shrek3k altitude card -> go right
                                  • S Offline
                                    Shrek3k
                                    😔 seems that I can’t offer / use that chart as I have the “simple version” (aka non-baro).
                                      @Shrek3k check 24/7 hr
                                      • S Offline
                                        @Dimitrios-Kanellopoulos I am really grateful for your assistance, and I hope that I understand you correctly … as I am not using the any of the 24h-capabilities (sleep / HR) as I have no need at all for any of them (add to this opion, that these data could/would be collected but not interpreted in a meaningful way as far as I understand), so I might not be able to check there either if there are any ‘automatic’ resets 😔
                                          MaxiPalle Bronze Member @Dimitrios Kanellopoulos
                                          @Dimitrios-Kanellopoulos Checked it and it was appr. 3 weeks old.
                                          Did a soft reset and voila - GPS optimization started during next sync.
                                          Thanks!
                                          Brad_OlwinB 1 Reply Last reply Reply Quote 1
                                            @MaxiPalle That should solve the problem. My S9baro acquires a fix in about 5 sec.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
