    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Several navigation issues (feedback)
    Scheduled Pinned Locked Moved Suunto Vertical 2
    61 Posts 12 Posters 10.9k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • JoaquinJ Offline
      Joaquin Moderator @maszop
      @maszop this is good improvement/feature👌 I’ll pass this on to the team in case we can do something about it in the future.
      Super thanks!!
      Technical & Product Specialist – Suunto Iberia
      M 1 Reply Last reply Reply Quote 3
      • M Offline
        maszop Bronze Member @Joaquin
        @Joaquin Thanks. Komoot does that mainly for staying on roads and trails, whereas with Suunto it would be more about adding missing elevation and TBT.
        From what I’ve seen, only Komoot (online) – using the phone’s computing power – can generate a logical route.
        Garmin is just okay at best. The Hammerhead Karoo is pretty weak. Google Maps, apart from driving, is rubbish. Mapy . com is okay at best. And I’m mostly talking about using the phone’s processing power and usually having an internet connection.
        So I don’t know if it’s worth putting so much effort and resources into adding routing to Suunto watches, knowing it’s going to be very unreliable, except maybe in cities.
        • JoaquinJ Offline
          Joaquin Moderator @dreamer_
          @dreamer_ I think there might have been a small misunderstanding, so just to clarify my point.
          I was simply referring to the brands you mentioned as examples, not trying to say one approach is better or worse. Each brand has its own philosophy, and this is just ours.
          Of course, we are actively working towards improving things like GPX-based turn guidance or routing directly on the watch, but we want to do it in a way that we believe is robust and reliable for the user. That’s why, for example, offline maps in the app combined with routing to the watch is part of what I’d call the “Suunto way” of building a routable map experience.
          I really appreciate your feedback and the level of detail you’re bringing to the discussion. It’s genuinely valuable for us ❤️‍🔥
          1 Reply Last reply Reply Quote 6
          • sky-runnerS Offline
            sky-runner Platinum Member @Joaquin
            @Joaquin said in Several navigation issues (feedback):
            you will have it, but in reverse; that is, instead of going from left to right, you will see how the ascent guide will go from right to left, and you will always have the current segment, updating to your route direction
            Can someone please tell the Suunto team that the elevation profile (climb guidance) updating in reverse right to left with the color swapped is a very questionable solution. I find it extremely confusing. It isn’t a good user experience in my experience.
            And in general the whole idea of automatic route reversal is more trouble than it is worth 90% of the time. Just two days ago I tried "Navigate on watch now function and as soon as I used it the watch showed a notification that I have reached the destination, followed shortly by an off route notification and then followed shortly by back on route notification. I can only assume it immediately reversed the route. There are many more examples of the route reversal messing things up. For one case of when I truly want the route reversed there are 9 cases of when it wrongly reverses it.
            Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
            Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
            JoaquinJ 1 Reply Last reply Reply Quote 2
            • JoaquinJ Offline
              Joaquin Moderator @sky-runner
              @sky-runner Changing the colors in reverse is difficult, although we’re working on it. The current segment is indeed inverted,I hope we can do this at some point.
              • 2 Offline
                2b2bff Silver Members
                One thing that is not actual navigation but very much related: In yesterday’s Race I loaded the course and started navigation without TbT just to be able to see where the route would be just in case. As I run through the finish point, I got a full screen notification that I reached the end of the course and had to dismiss this notification to be able to actually stop my activity tracking.
                I think the upper button should have paused regardless…
                Race S
                • dreamer_D Offline
                  dreamer_
                  Edit. I just realized joaquin’s photo I was referencing is comparing a Coros with Garmin, and that Coros does also have an offset, which seems even bigger than what is seen in Suunto.
                  Removed bad photo (of my post)
                  In those photos you see only a 3 meter offset with Garmin, but I’m finding many turns with much more distance offset with Komoot’s algorythms, as explained. Even something like 15 meters several times.
                  Suunto Vertical 2 Titanium Sage, Suunto Run
                  JoaquinJ 2 Replies Last reply Reply Quote 0
                  • JoaquinJ Offline
                    @dreamer_ I didn’t remove any photo or modify the post, so I’m not sure what you’re referring to.
                    As I mentioned before, turn notifications depend on the vector map data that generated that turn. Even when using the same map provider, you can still have different turn thresholds depending on the algorithm or routing engine used, as well as the map update frequency of each platform.
                    That’s why sometimes Garmin is more reactive, other times Suunto, and other times COROS. In any case, navigation remains perfectly usable on all of them.
                    These are simply normal differences and limitations across platforms.
                    dreamer_D 1 Reply Last reply Reply Quote 0
                    • dreamer_D Offline
                      dreamer_ @Joaquin
                      The photo was removed by me, not you @joaquin . I misunderstood one of the photos and that’s why I corrected the post
                      JoaquinJ 1 Reply Last reply Reply Quote 1
                      • JoaquinJ Offline
                        @dreamer_ all clear ☺️ I didn’t understand what you meant.
                        By the way, it would be great if you were in Zegama, Val de Aran, Mallorca, or Andorra UTMB. It would be nice to meet you, and I’m sure we’d have a nice chat about GPS gadgets.
                        • JoaquinJ Offline
                          @dreamer_ I did a quick test route in Madrid, in an area where I don’t usually run, created natively in each platform (Suunto App, COROS App, Garmin Connect, and Amazfit App) to avoid any inconsistencies coming from GPX imports.
                          For clarity, I’ll only show the first three turns. For example, COROS only generates one turn here (the third one).
                          As you can see, each platform interprets turns differently depending on their routing engine, vector map data, and turn detection thresholds.
                          Garmin & Suunto
                          Very close overall. In the first two turns, a slight advantage for Suunto in terms of reactivity, and on the last one, Garmin was slightly ahead.
                          JoaquinJ sky-runnerS 2 Replies Last reply Reply Quote 0
                          • JoaquinJ Offline
                            Joaquin Moderator @Joaquin
                            COROS & Suunto
                            On the third turn, which is the only one COROS detected among the first three, it clearly triggers earlier. The turn is indicated when I’m still around 15–20 m away, as you can see in the track displayed on the map.
                            Amazfit & Suunto
                            Amazfit consistently triggers earlier on each turn. As shown in the images, the turn notification appears significantly before reaching the actual turning point.
                            Final conclusion
                            That said, YOU CAN PERFECTLY FOLLOW TURN-BY-TURN NAVIGATION WITH ANY OF THE FOUR WATCHES.
                            From my experience, Garmin and Suunto are quite similar in terms of turn reactivity and distance to turn when routes are created manually in their respective apps.
                            As mentioned, this will depend on the platform where the route is created, and of course your experience may vary. I’m simply sharing my tests across different locations.
                            We will of course continue working to improve this for all users, which is why this kind of feedback is very valuable. Thank you very much!
                            2 1 Reply Last reply Reply Quote 2
                            • 2 Offline
                              2b2bff Silver Members @Joaquin
                              @Joaquin Looking at the watch photos - why does Suunto not pointing to the left next to the distance remaining in the 2nd and 3rd photo? It’s counter intuitive, isn’t it?
                              Race S
                              EgikaE JoaquinJ 2 Replies Last reply Reply Quote 2
                              • EgikaE Offline
                                Egika Platinum Member @2b2bff
                                @2b2bff said in Several navigation issues (feedback):
                                This is the display, when the next turn is not within notification distance. Then it is basically a generic icon for this data field how far the next turn is.
                                I also think the actual direction could be shown in this state. No idea if this will come later.
                                • JoaquinJ Offline
                                  Joaquin Moderator @2b2bff
                                  @2b2bff We don’t have a dynamic icon in the data field that shows the turning direction; we’re working on it, and it’s something I’d love to have. The correct turn signal appears after 20 meters.
                                  dreamer_D 1 Reply Last reply Reply Quote 2
                                  • dreamer_D Offline
                                    dreamer_ @Joaquin
                                    @Joaquin I think I have found the issue.
                                    First, I’d like to thank you for taking the time for the tests and the very detailed post.
                                    After looking at your track, I have just realized that my track is a roundtrip track, and means the same way out and back. This is something that I always do by default when I test the navigation.
                                    And that track it also means that in the way out (going up), I also take a fork that I repeat in 2 directions and then return to the track up to a mountain. In the way back (and going down) I take the same fork doing the same repeat and then return to the track. Or sometimes I take a completely different fork, and then I return to the track.
                                    I have tested this convoluted track in every brand of the market but Polar. And the reason is that in short trail runs or in very fast ones, sometimes you repeat parts of the tracks and knowing your watch has strong and reactive indications is interesting.
                                    For this same reason, specially in very technical paths, is interesting to have the audio navigation indications (that can enabled/disabled with just a trigger in the navigation options of the watch for most brands of the market). About this, Garmin has audio prompts for even roundabouts.
                                    Said this. I went for an small walk to show you what I’m seeing
                                    Have a look at this shot:
                                    As you can see, there are 2 notifications for the roundabout (the way out, and the way back). When I arrive (way out, first time) to the roundabout, and when I’m almost at the roundabout, the watch is saying that there are still 18 meters left, and that’s impossible. There are perhaps 18 meters but to the point of the other notification (that should be triggered when you are back), not to the first one
                                    • Is it possible the watch in this roundtrip scenario is notifying the second notification, instead the first one?
                                    Then, I walked like 300 meters and I turned back and I did not got any roundabout notification again (this works in Garmin). I think the autoreverse is not as reactive as it should be, as I was explaining.
                                    But this is today with an extremely small test as it’s very late now here. If a run a lot longer, I have the feeling that the watch is giving notifications inside the turns and the notifications sometimes remain after those turns. And despite the notifications are ok, and in the corresponding direction, I think there’s something very strange with the distances and response time in this roundtrip scenario.
                                    The track I’m using means also a check that enables the roudtrip inside Komoot.
                                    Could you test a roundtrip scenario (way out and back using the same way)?
                                    BTW, only Garmin and Suunto can notify roundabouts and forks. And I have even seen the go straight in a fork in Suunto (not only take the fork) so this is very nice (Coros and Amazfit only notify the turn left-right and Amazfit even misses several forks, if not most). I don’t understand why you are getting that “0 meters” in all the shots in Amazfit. As far as I remember, the Ultra 2 was accurate with the distances in my tracks. But I wouldn’t be surprised if they have broken something in their very last updates (which I have not tested). And in any case, that is not our problem here.
                                    I think that in this roundtrip scenario, Suunto has something strange here. Perhaps is something that happens where I live or in my tracks, but the thing is that I only see this discrepancy with the accuracy in responsiveness and distance in Suunto (and in this roundtrip scenario).
                                    JoaquinJ 1 Reply Last reply Reply Quote 0
                                      @Joaquin I’ve noticed that turn icons (symbols) are incorrect at the bottom Suunto map screen on the 2nd and 3rd pictures. The icons seem to indicate sharp right turn if I interpret them correctly while in fact there are left turns in both cases.
                                      Edit: I see that this has already been answered above.
                                      • JoaquinJ Offline
                                        @dreamer_ Thanks a lot for the very detailed feedback, really appreciate the time you took to explain and test this scenario.
                                        If possible, could you please share a full screenshot of the route you are using (showing the complete roundtrip)? I’ll try to reproduce it on my side.
                                        That said, unfortunately I have Madrid Marathon and a Trail Camp with El Corte Inglés next week, so it might take me a bit longer than usual to properly test this. In any case, I will definitely pass this to the dev team if I’m able to reproduce the behavior you’re describing.
                                        Regarding your findings, this could indeed be related to the auto-reverse logic. It’s great that the watch is able to adapt to the direction of navigation, but we introduced a safety threshold of around ~200m before switching direction. This is intentional, as switching too quickly could be problematic in some scenarios and we need to ensure the user has actually turned back and not just made a small deviation.
                                        Because of this threshold, if there is a turn event within that ~200m window after changing direction, it’s possible that the watch could still be “anchored” to the previous direction and therefore confuse turn events, like in your example.
                                        That said, I believe these are quite specific edge cases, and in most normal navigation scenarios this should not be noticeable.
                                        Also, currently turns are handled with two different behaviors:
                                        1. Autozoom → the map zooms in advance when approaching a turn
                                        2. Turn notification → triggered around ~20m before the turn
                                        And I agree with you here: depending on speed, 20m can sometimes be too short.
                                        We are currently working on unifying both behaviors, so turn notifications will be driven by a more dynamic threshold (similar to autozoom or off-route logic), which should provide more consistent and earlier alerts regardless of speed.
                                        Again, thanks a lot for the feedback ❤️‍🔥
                                        BTW, I also personally really like the idea of having a microphone and speaker. However, this is handled by our product team, and currently it introduces trade-offs with the barometer performance, which is critical for us. Hopefully we can find a good balance in future generations without compromising barometric accuracy.
                                        • dreamer_D Offline
                                          dreamer_ @Joaquin
                                          @Joaquin sure.
                                          This is the usual route for these testings (re-uploaded with better quality)
                                          The track is roundtrip: Up (with 2 additional forks) to the top of a mountain, and down repeating everything again
                                          Notifications mostly work in both directions. It’s just about the accuracy of them, remaining the notifications inside and after the turns (refer to my previous post with the shots of the very first roundabout)
                                          About the microphone/speaker, I was only speaking about the audio navigation notifications since this thread is about navigation thinking in the use of the headphones (I.E, the Garmin Instinct 3 does not have a microphone or speaker but has audio notifications through the headphones (and that watch is able to even notify the roundabouts and despite It can’t show the maps). Suunto has already invested in the engineering of very nice headphones and with very interesting products that are already in the market (like the Spark). I think that with several software updates (both watch and headphones), those kind of products could be used as a very nice marketing thing (for something like an “ecosystem”). I’m thinking also in running indoor or treadmill when there’s no GNSS signal.
                                          But this is another topic, just to explain It further (and also to say that you already have the microphone and speaker in the market that could be used to go further). In my opinion, optional audio navigation notifications are sometimes incredible useful.
                                          Thank you so much
                                          dreamer_D 1 Reply Last reply Reply Quote 1
                                          • dreamer_D Offline
                                            dreamer_ @dreamer_
                                            @joaquin there’s definetely a bug here, and I found the explanation.
                                            I made another experiment. If inside Komoot I don’t check the roundtrip, it does not make any effect , since the route is roundtrip (or at least, I can see indications in both directions despite of that)
                                            But it is more. It’s Komoot what is making the bad turn-by-turn directions. Have a look at this photo:
                                            A: Start point
                                            B: End point of the route
                                            What you see in the photos I posted in the other post is that Suunto is notifiying that 1 as the very first point, because of Komoot’s issue. That’s why there’s the 18 meters offset in the photos I posted for you.
                                            So offset explained.
                                            Now, about the photos you uploaded.
                                            Photos 2,4,3,5. Suunto’s notifications seem to be wrong and that is a one-way track (no roundtrip).
                                            What I’m seeing (3 and 5) is that there are several turns close together. It’s like there is something bad at the algorythms, detecting 2 very close left turns as an U-turn. Perhaps this is Komoot related.
                                            What happens when turns are very close inside Komoot?
                                            In my opinion, it’s very clear Komoot’s workaround is more a problem, once we know others are not having these kind of issues.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
