Several navigation issues (feedback)
Be careful not to chase perfection and in the end nothing is completed.
The komoot route is a bit cumbersome and komoot is far from perfect (even if I tell komoot to not change the route, the route on my suunto race s is different than on my wife’s apple watch.) The garmin/wahoo way (select a gpx file and use the open with app) would be an improvement, even if not all tbt alerts are perfect.
My first gps watch (a ambit 3 sport) only had breadcrumb navigation. Did I ever got lost? No.
My watch after that, a forerunner 935, had breadcrumb and tbt alerts. (Which didn’t work well. A route could only have 50 navigation alerts and if you did your route reversed you lost all tbt alerts). Did I ever got lost? No.
My first watch with maps (a forerunner 965) and having some context is nice. Eventually garmin fixed the 50 alert limit, but not the reverse problem and they introduced a timing bug (up to 10k the alerts are before a corner, after 20k alerts are in a corner, or after). And yes, on a twisty road you get alerts for every corner. Did I ever get lost? No.
Now I have a suunto. Komoot is fine, but could be better. Autodetect of going reverse is good. No problem if I do a round route and the end is detected before the start (garmin has problems with this. Navigations stops when you reach the goal, which could be before you actually started). Autozoom actually works as one would except (garmin had autozoom, but that doesn’t work, or not as one should expect). But do I get lost ever? No.In the end, all are equally good in the “do not get lost” requirement.
Is everything perfect? No. But don”t wait until everything is perfect. Release small steps. Get feedback. Improve some more.
Register Login
