    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Can't connect to wifi to upload maps
    Scheduled Pinned Locked Moved Suunto Vertical
    6 Posts 4 Posters 713 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Juanma MonteroJ Offline
      Juanma Montero
      Re: Can't connect to wifi or hotspot I’ve tried all the solutions I’ve seen in the forum as simplifying the name of the SSID, creating a hot spot with my laptop, looking for different wifi origins… but independently of what I do, the app always tells “It hasnt been possible to conect to the web. You may solve the problem restarting the router” I’ve done it too, restarting router, and have done a reset to the Vertical too… but nothing worked.
      Anybody knows how to solve this problem? Thanks a lot for any help on this issue!
      It would be much easier if the maps could be uploaded directly into the app phone or if you could administrate directly wifi connection in the watch, witthout the mobile, I’ll ask Suunto to think into this possibilities. Very often you dont find wifi available.
      BrunoHB 1 Reply Last reply Reply Quote 0
      • BrunoHB Offline
        BrunoH Gold Members @Juanma Montero
        @Juanma-Montero the only way I succeeded to overcome this problem was to downgrade my Vertical to the previous firmware version and then wifi started working.
        Go to Settings -> General -> About or Information -> scroll all the way down and then press the lower button for a few seconds. You get to a hidden menu; scroll down to Select OTA package and choose the older one.
        Compasses: M-311, A-10, SK-7
        Diving: Finnlight Navy 90, Vyper
        Sports: Metron, S7, S9B and Vertical
        Juanma MonteroJ 1 Reply Last reply Reply Quote 2
          Juanma Montero @BrunoH
          @BrunoH Thanks a lot for your help! I’ll tell you if I succeed!
          Y 1 Reply Last reply Reply Quote 1
          • Y Offline
            yvesmo @Juanma Montero
            @Juanma-Montero That solved my issue too, thank you !
            thanasisT 1 Reply Last reply Reply Quote 1
            • thanasisT Offline
              thanasis Bronze Member @yvesmo
              having such an issue for such a long time is quite annoying to be honest …
                Juanma Montero
                Thanks a lot for the solution! @BrunoH , I tried everything before, with no success but with your tips is working again! Maps in my watch again! 👍 👏
                Register Login
                • First post
                  Last post
                Suunto Terms | Privacy Policy
