    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto ZoneSense
    Scheduled Pinned Locked Moved SuuntoPlus™ Sports Apps
    966 Posts 149 Posters 413.4k Views 127 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • James EastwoodJ Offline
      James Eastwood Bronze Member
      It’s possible now to use ZoneSense to provide your activity TSS. Does anyone know of it is possible to set this as the default for an activity type?
      SquirrelS 1 Reply Last reply Reply Quote 0
      • SquirrelS Offline
        Squirrel Silver Members @James Eastwood
        @James-Eastwood said in Suunto ZoneSense:
        In Suunto app, you can edit the latest activity and change the TSS to TSS (ZoneSense). Afterwards, I think, TSS ZS will be used for that particular activity type. So you might have to edit all the different activity types once, as desired.
        Race S
        • thanasisT Offline
          thanasis Bronze Member
          i hope when they release the new firmware they fix the issue of the differences between app and watch as well
          isaziI 1 Reply Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator @thanasis
            @thanasis probably not possible, app will always be more accurate because it can compute statistics with the full dataset
            Blog: isazi's home
            thanasisT 1 Reply Last reply Reply Quote 1
            • thanasisT Offline
              thanasis Bronze Member @isazi
              @isazi thanks, I understand but up to a level. For instance I see 7-8min in the red zone on the watch and 0 on the app. Since zonesense is supposed to be offering a near realtime indication , having such discrepancies is not very helpful and somehow is a let down because you cannot really benefit from it if it only gives a general direction (which you can also get from your body … as a living organization) and then having the app telling you differently …
              1 Reply Last reply Reply Quote 5
              • helgonet12H Online
                helgonet12
                Does anyone else have the zone sense working some times and other times not? Im on the latest firmware and have the same problem on vertical & race2 I did not have this problem on my vertical on previous firmware.
                A S 2 Replies Last reply Reply Quote 0
                • A Offline
                  Alonzo @helgonet12
                  @helgonet12 I wasn’t able to get ZS working with SW 2.44 on Race S. Rolled back to 2.43 and ZS readouts are back to ‘normal’.
                  • S Offline
                    Skicoach @helgonet12
                    @helgonet12 I’m having a problem with the Race S real time display of ZoneSense just freezing half way through my workouts - data is fully recorded though and is correct when synced with the phone app - just real time display not working properly.
                    • S Offline
                      Skicoach @Alonzo
                      @Alonzo I think there’s a bug! My ZS display just locks up half way through my workouts - fixed on a static value - but the data logged is fully correct.
                      Is it easy and safe rolling back the update?
                      A 1 Reply Last reply Reply Quote 0
                      • A Offline
                        Alonzo @Skicoach
                        @Skicoach It is easy, but expect many watch settings to be lost - very similar to a hard reset. If you are fine exercising with HR data for a timebeing (hopefully there will be a fix soon), I won’t recommend to roll back.
                        ZS only work for me, when I basically do not need it - during zone 2 runs. Otherwise it’s too often show green zone (even during long tempo runs or Cooper test!) being detached from my perception and abilities.
                        M 1 Reply Last reply Reply Quote 0
                        • M Offline
                          MarkusG Bronze Member @Alonzo
                          I’m using ZoneSense (Race 1) since it was released. Until recently (I guess before the last update) it worked quite well. Now I observe the same that has been reported here, as long as it’s below LT1, it totally makes sense.
                          As soon as I cross LT1 it doesn’t, From LT1 to LT2 there is roughly a spawn of max. 15 beats. It also doesn’t correlate to the felt effort. E.g. LT2 comes too early.
                          To make sure that my belt is still ok, I use the app “HRV Monitor” on Android. It’s a quite simple app that counts the artifacts while it’s recording a 2min HRV session. It’s still ok for my belt, so I doubt it’s related to a worsen quality of the R-R signals.
                          • sky-runnerS Offline
                            sky-runner Platinum Member
                            My experience with ZoneSense has been quite mixed. I have over a decade long experience running on hilly and mountainous terrain and know my body well. Either I am an outlier who doesn’t fit DFA-alpha1 model or there are factors that it doesn’t take into account, or perhaps I don’t interpret it correctly.
                            For me, it seems to shift into the red zone way too easily - at an effort that I know I can sustain for a long time and wouldn’t characterize as anaerobic. But on some other runs it seems much more reasonable and fitting to the level of effort. Also, it seems to have improved when I changed from Polar H10 HRM to Suunto HRM. Perhaps my Polar strap wasn’t new so the HRV data contained more glitches. But if that is the case, the algorithm should try to deal with that by filtering the data and excluding outliers.
                            Furthermore, when it detects Aerobic and/or Anaerobic thresholds for me, these numbers always seem ridiculously low - like everything is shifted by one zone down. It consistently detects AeT around 130 and AT around 150. Yes, I am 55 years old, and for an untrained person of my age these would be fine numbers. But I am in the top 5% percentile for my age, if not top 1%. I regularly take podium in my age group. I easily sustain 140 after multiple hours of running. I did a number of tests that all suggested that my AeT is in low-mid 140s. Similarly, I did a number of tests, including a few guided LTHR tests with Garmin, that all consistently detected my AT around 161-163.
                            I asked Gemini (Google’s AI) if DFA-alpha1 (the algorithm behind Zone sense) can thrown off by muscles being fatigued or by running on a hilly terrain. Here are some quotes:
                            When an athlete is fatigued, the normal relationship between DFA-alpha1 and exercise intensity can be altered. Instead of reflecting a rise in exercise intensity, the DFA-alpha1 values may be lower than expected for a given workload due to shifts in the autonomic nervous system balance.
                            Perhaps this is fine and this is what Zone sense is supposed to do, but it shouldn’t suggest aerobic and anaerobic thresholds. I think those should reflect a fresh recovered state.
                            Running on hilly terrain introduces variations in vertical motion and effort, which can affect the accuracy of DFA-alpha1 readings, according to Scientific Triathlon. This is because DFA-alpha1 relies on consistent heart rate variability patterns, and the sudden changes in effort associated with inclines and declines can disrupt these patterns.
                            I run on a hilly terrain a lot. Two days ago ZoneSense detected my AT at 155, which is closer to actual than usual but still closer to what I believe the low end of my Z4. I already knew during the run that that would be what it would detect it at. There was a moderate hill that I ran at the end of the run, and that it where my HR stabilized just as the climb started to flatten. In fact, later in that run my HR reached almost 160 and I still wasn’t in what I would classify as Z5 and not even breathless. I know how Z5 feels, and that wasn’t it.
                            Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
                            Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
                            Zdeněk HruškaZ 1 Reply Last reply Reply Quote 3
                            • Zdeněk HruškaZ Offline
                              Zdeněk Hruška Bronze Member @sky-runner
                              @sky-runner I’ve had a similar experience. As with most metrics, the numbers are not as simple as companies make them seem – it takes some knowledge and practice to really understand and apply them. For now, I see ZoneSense as a helpful tool to keep me from pushing too hard on easy days. That alone can be very valuable, assuming it works as we believe it does.
                              B B 2 Replies Last reply Reply Quote 0
                              • VoiGASV Offline
                                VoiGAS Gold Members
                                Has someone already used Zonesense, especially ZS based TSS with Cross Country Skiing? Winter is coming in the northern hemisphere and I am curious how it works compared to Heartrate
                                Race S
                                Vertical Titanium Solar
                                Ambit3 Vertical
                                • B Offline
                                  bubuche @Zdeněk Hruška
                                  @Zdeněk-Hruška said in Suunto ZoneSense:
                                  the numbers are not as simple as companies make them seem.
                                  Totally agree. After my last race (trail running), I have to chose between MET at 101, ZS at 139, power at 158 and HR at 186. How to be confident with CTL and co.?
                                  • JosaipluJ Offline
                                    Josaiplu Silver Members
                                    Interesting video on zone sense on the nakan. ch channel
                                    Sorry it’s French but YouTube now allow live translation hope it will help some to better understand zone sense
                                    There is also a blog post to read that I did not had time yet to discover
                                    Old: SV, SR
                                    Currently enjoying race 2, wife on SRs
                                    • T Offline
                                      tomtom73
                                      Did some of you tried a (ramp) test to validite LT1 LT2 thresholds ? What would you recommand ?
                                      Brad_OlwinB 1 Reply Last reply Reply Quote 1
                                      • B Offline
                                        brave_dave Bronze Member @Zdeněk Hruška
                                        @Zdeněk-Hruška from a scientific perspective, ZoneSense is nothing more than a theoretical concept and a marketing move rather than something really useable in its current state. The principal behind it works but it is too unreliable in its current state. Even under perfect “lab” conditions accuracy is not good enough to be useable for most people, especially not on individual runs as they market it. Maybe in the future…
                                        Made a summary of a recent scientific study with a link to the publication testing ZoneSense, in the thread below.
                                        https://forum.suunto.com/post/175109
                                        @Josaiplu “Study” by Nakan is somehow useless because such a study has already been performed with way higher n-number by the experts that developed ZoneSense. I can also only put it in the category of marketing…
                                        Brad_OlwinB Zdeněk HruškaZ 3 Replies Last reply Reply Quote 6
                                        • Brad_OlwinB Offline
                                          Brad_Olwin Moderator @tomtom73
                                          @tomtom73 When I am fresh, my ZonseSense L1 and L2 are very close to validated laboratory tests. Know that the ZS thresholds will change depending on your physiology and fatigue, that is the point! It is not meant to be a tool to set HR zones but a tool to use in real time to assess your effort.
                                          Vector/T6c/Vertical 2 Ti
                                            Brad_Olwin Moderator @brave_dave
                                            @brave_dave Have you read the scientific peer-reviewed manuscripts for ZS and HR arrhythmias or exercise? It works well. I would rely on peer-reviewed published data and not anecdotal information. I find ZS to work extremely well for me given the limitations and the intended use for ZS.
                                            Here is the DOI link for peer-reviewed data on ZS.
                                            10.3389/fphys.2023.1299104
                                            B 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
