    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto ZoneSense
    Scheduled Pinned Locked Moved SuuntoPlus™ Sports Apps
    1.0k Posts 154 Posters 457.9k Views 132 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • SamppaPS Offline
      SamppaP Silver Members @Guest
      @timecode it happened me the first time a few weeks ago. I didnt wet the belt before my run. I guess the connection was good enough for HR but not the r-r data. After a while probably my sweat made the connection better or something?
      Vertical All Black
      Ambit 3 Peak
      Suunto smart sensor
      isaziI ? 2 Replies Last reply Reply Quote 1
      • isaziI Offline
        isazi Moderator @SamppaP
        @SamuelP indeed, if the data is too noisy it is not used for ZoneSense, data needs to be quite clean to be used.
        Blog: isazi's home
        SamppaPS 1 Reply Last reply Reply Quote 0
        • ? Offline
          A Former User @SamppaP
          @SamuelP good hint, thanks. I will try it again tomorrow and keep this in mind.
          • SamppaPS Offline
            SamppaP Silver Members @isazi
            @isazi would be nice if suunto app could tell the quality of the data(like runalyze), would help with all the confusion 😅
            Vertical All Black
            Ambit 3 Peak
            Suunto smart sensor
            1 Reply Last reply Reply Quote 3
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @Guest
              @timecode If the HR belt dries and/or you have a tech shirt and dry belt it can cause problems. I thoroughly wet my belt before I run and I typically sweat enough that the belt stays wet. If you stop and dry out it could also be an issue.
              Vector/T6c/Vertical 2 Ti
              • ? Offline
                A Former User @Brad_Olwin
                @Brad_Olwin thanks. I also always wet the belt and sweat a lot, like A LOT. But it of course can happen that it dries out - today was quite cold, so it’s possible. I’ll try again tomorrow.
                  @timecode said in Suunto ZoneSense:
                  I rarely have loss of data from ZS but it has occurred. The last time this happened my belt battery was about done. I finally remembered to check it.
                  • ? Offline
                    @Brad_Olwin just fyi, today I ran again with the HR strap and as you can see time spent in each zone on the watch is different as in the app. There’s again a gap at the end. I am sure it’s not an issue with the strap, it’s wet, fairly new and a brand new battery.
                    Brad_OlwinB SportsfreundS 2 Replies Last reply Reply Quote 2
                      @timecode the watch is real time and the app calculates from synced data. Those are very similar IMHO 30s ± for VO2M does not seem like much.
                      Don’t know about the end, perhaps R-R data is noisy from strap drying or static from tech shirt, don’t know. I have not seen this in my experience.
                      • ? Offline
                        @Brad_Olwin ah ok, I thought data in watch == data in SA. Good to know, thanks. Will “investigate” further.
                        • Stefano M64S Offline
                          Stefano M64 Silver Members
                          The past week a made a short easy run (I’m not a runner) primarily to check if the VO2max estimation I got by walking (46.1-46.2) was similar to the one I would obtain by running. Since it resulted to be 45.5, the answer is yes, they are pretty close, ok.
                          The part on which I would like to have an opinion from someone more expert on the argument is relative to the ZoneSense: I walked for 10 minutes with a cadence of 55/60 then increased to about 70, the HR increased from about 100, to 150-160. For most of the time DDFA index was in the aerobic green zone, with two period in the yellow zone, which started at about 150 bpm the first time and at 160 the second time. Previously, I got 3 estimations of the aerobic threshold (134-136-137) while training at the gymn. For my age (61) the usual formula gives an HRmax of 159 pbm, another one I found (213-0.65*age) gives 173 pbm, from which I should have the aerobic threshold at about 134, in line with the previous estimation. So, I was quite surprised to see the transition from ZS green to yellow zones at 150 pbm or even at 160 pbm. By following this forum, I learned that HR zones based on age are just a vague indication, however I’m bit scared to be pushed to training to hard, what I want is just to keep fit (but I like to experiment and understand). Any comment is welcome!
                          Suunto Vector . Vector HR . Core . Race & Race S
                          GiPFELKiNDG EgikaE 2 Replies Last reply Reply Quote 0
                          • GiPFELKiNDG Offline
                            GiPFELKiND Silver Members @Stefano M64
                            @Stefano-M64 i never would use zone sense as training indication or as reason to train harder as you feel. Go to an medical doctor and make a lactat running Test. There you got your right and personal heart rate and Training zones. Good Option here is to do this with Spiroergometrie system.
                            If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
                            Stefano M64S 1 Reply Last reply Reply Quote 1
                            • EgikaE Offline
                              Egika Platinum Member @Stefano M64
                              @Stefano-M64 the use of HR to define a threshold for aerobic/anaerobic/VO2max regions is not a fixed one that is valid over many weeks. It is not even valid for multiple days.
                              This is why lactate tests on a treadmill or cycle are valid for the time of testing only.
                              ZoneSense gives you a live (or after activity) information about your body status.
                              What you are seeing is, what makes it so innovative.
                              The threshold heart rates vary from day to day, depending on muscle and body fatigue, illness etc.
                              You can just use the ZS screen on your watch during training, to make sure you stay in the green area, if this is your goal.
                              thanasisT 1 Reply Last reply Reply Quote 2
                              • thanasisT Offline
                                thanasis Bronze Member @Egika
                                @Egika said in Suunto ZoneSense:
                                i also want to rely on zonesense but i really struggle to understand how is it possible when going uphill , with over 170Bpm for some minutes the app to be showing i am in the green zone… In principle i am excited about relying on hr variability but am i harming myself by relying on it? that’s the big question for me
                                Francesco PaganoF ? cosme.costaC 3 Replies Last reply Reply Quote 4
                                • Francesco PaganoF Offline
                                  Francesco Pagano Silver Members Bronze Member @thanasis
                                  @thanasis from my perspective this question arises not only when going uphill, but when increasing the intensity in general.
                                  When I started using ZS I mostly did easy runs same as I did before, around my theoretical AeT. After months, I realised that ZS was confirming my assumptions simply because my RR intervals are more varied above that threshold; but if I do a hilly run or long tempo intervals, then ZS shows my AeT at a higher HR intensity, and that’s likely because of changing the context where those variations occur. If you read how DFA alpha1 and DDFA work this limitation seems to make sense.
                                  S9PP
                                  Suunto Spark black
                                  S5
                                  • B Offline
                                    borgelkranz Bronze Member
                                    A short question:
                                    I know from experience that zonesense improves when used often in one type of activity, e.g., indoor rowing. I read that it’s a good idea to do at least three light aerobic trainings to improve later readings (calibration).
                                    What I want to know is: does this translate to other activities of the same activity family? Say from running on treadmill to running on track? The activity types are color coded after all.
                                    ravenR 1 Reply Last reply Reply Quote 0
                                    • ravenR Online
                                      raven Bronze Member @borgelkranz
                                      @borgelkranz My guess is “no” but dont know for sure. I’ll note that “indoor rowing” is red while “rowing” is blue which annoys me. Red is apparently the “indoor workout” color, but “indoor cycling” is orange and matches other outdoor cycling.
                                        Stefano M64 Silver Members @GiPFELKiND
                                        @GiPFELKiND said in Suunto ZoneSense:
                                        Thanks, it’s comforting to know that I’m not alone with my doubts 🙄
                                        Thanks, ok I understand that. In any case, an (healthy) HRmax must exists for any person, which progressively decline with the age, varying from person to person. According to that, should also exists an aerobic threshold max, and an anaerobic threshold max. When a person is perfectly healthy and fit, the actual values are close to that max values, otherwise they are lower. Then, I do expect that by performing an high number of the same activity ZoneSense should at the end define a personal range of both aerobic and anaerobic thresholds, both lying below the one’s max thresholds values. With training the performances increases, but not indefinitely, everybody has it’s own limits.
                                        • ? Offline
                                          A Former User @thanasis
                                          @thanasis said in Suunto ZoneSense:
                                          ZS is not only based on HR and also depends on how your current and past baseline is. Have you trained enough in the past in the aerobic zone? Did you give ZS time to stabilize at the beginning of the session?
                                          In the first few minutes ZS calculates the initial baseline (which remains constant throughout the session) and then applies a correction at later times.
                                          Now you have seen 170 bpm in the green zone and it might be strange, but it is perfectly legitimate. Suppose at the beginning of the session you are tired, for example due to accumulated fatigue, stress, etc. This means a low HRV value. This low HRV value determines the initial baseline! Then the ZS begins to determine the correction to be applied to this initial value during training.
                                          e.g.
                                          A (you in good shape, so good HRV): starting baseline 0.90
                                          B (you in bad shape, so low HRV): starting baseline 0.70
                                          suppose during session your values decrease of the same amount for both A and B with the following values:
                                          at 5’ you have 0.9 at 130bpm
                                          at 10’ you have 0.8 at 140bpm
                                          at 15’ you have 0.5 at 170bpm
                                          at 20’ you have 0.2 at 180bpm
                                          so the corrections are:
                                          at 5’ A) 0.9 - 0.9 = 0 B) 0.9 - 0.7 = 0.2
                                          at 10’ A) 0.8 - 0.9 = -0.1 B) 0.8 - 0.7 = 0.1
                                          at 15’ A) 0.5 - 0.9 = -0.4 B) 0.5 - 0.7 = - 0.2
                                          at 20’ A) 0.2 - 0.9 = -0.7 B) 0.2 -0.7 = -0.5
                                          green, yellow and red are then determined when:
                                          green, when correction is >= -0.3
                                          yellow, when -0.3 > correction >= -0.6
                                          red, when correction < -0.6
                                          so
                                          at 5’ A and B are in green
                                          at 10’ A and B are still in green
                                          at 15’ A in yellow, B still in green !!
                                          at 10’ A in red, B in yellow
                                          So a low initial value makes ZS less sensitive to changes
                                          thanasisT Stefano M64S atoponceA 3 Replies Last reply Reply Quote 3
                                          • thanasisT Offline
                                            thanasis Bronze Member @Guest
                                            @6iovanni said in Suunto ZoneSense:
                                            warmed up etc in aerobic yes. then after a point i went uphill .
                                            However those questions indicate that there may be an inherent assumption about zonesense that it should be not considered as a reliable indicator outside some very clear and set preconditions. Unfortunately the app doesn’t tell you if those are met (e.g. can it measure my current load? is my HRV too noisy? am i going uphill but the data are not proper etc…) and it still gives you an indication.
                                            If this hypothesis stands true, I (as an amateur, non scientifically trained user) cannot really make use of it.
                                            However, in my cases , i do try to follow this very easy warmup phase and flat surfaces and then gradually step up
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
