    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto ZoneSense
    Scheduled Pinned Locked Moved SuuntoPlus™ Sports Apps
    1.0k Posts 155 Posters 526.3k Views 131 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Łukasz SzmigielŁ Offline
      Łukasz Szmigiel
      Is there a neat way to update zones in the watch according just to calculated aerobic threshold? Or I’d have to push hard enough to have anaerobic calculated too (to hell with max, I don’t care about that).
      S9PP 2.50.28
      Zdeněk HruškaZ 1 Reply Last reply Reply Quote 0
      • Zdeněk HruškaZ Offline
        Zdeněk Hruška Bronze Member @Łukasz Szmigiel
        @Łukasz-Szmigiel if you go for an accurate result you need to push unfortunately.😄 There are ways how to calculate zones (probably not directly in the watch/app) but without the numbers it’s always an estimate which can be widely wrong:) I think that something like 20 minutes test could be enough to have a quite good estimation.
        isaziI 1 Reply Last reply Reply Quote 3
        • martintrailM Offline
          martintrail Silver Members
          I also tested yesterday for the first time in the hills and it’s very strict. 😅 I had to push a lot, but that’s about it. 😄
          I would have liked a lot to have ZoneSense as the first dial at the start of the activity + to be able to see the length and time of the activity. That’s all I need. But that’s really a minor thing.
          Suunto Vertical Ti Solar
          M 1 Reply Last reply Reply Quote 2
          • M Offline
            Matúš Bronze Member @martintrail
            @martintrail said in Suunto ZoneSense:
            I’ve just found out that it is possible to modify the data fields showed during the activity by modifying them through the ZoneSense app page on S+: acutally, there is a option reporting both distance and duration.
            Suunto 9 Peak Pro Ti Slate
            Suunto Spartan Sport
            #swatt
            martintrailM 1 Reply Last reply Reply Quote 5
              martintrail Silver Members @Matúš
              @Matúš oooh, I see… thank you!
              • EgikaE Offline
                Egika Platinum Member @Luis Andés Olmedo
                @Luis-Andés-Olmedo said in Suunto ZoneSense:
                @GiPFELKiND said in Suunto ZoneSense:
                First run today with the new ZoneSense…
                Can anybody explain whats going on here!
                Aerobic Zone Green with heart rate 180!!!
                I had more or less the same feedback after my first run yesterday: Green zone with heart rate clearly in yellow zone (165).
                BTW, I tried it with my COOSPO HR Belt and it works 🙂
                The new thing about ZoneSense is, that it is not just another representation of HR. HR and Zone are not a linear dependence, otherwise this would not be a big innovation.
                Please differentiate between zone and HR.
                Maybe read here: https://www.suunto.com/de-de/sports/News-Articles-container-page/introducing-zonesense-revolutionizing-intensity-insights-with-heart-stress-measurement/
                Example from that page: 563b5099-fa28-4fa0-82c0-83fdc6c53273-image.png
                And also watch and try to understand: https://youtu.be/bD3O4BZ9vIc
                thanasisT 1 Reply Last reply Reply Quote 4
                • thanasisT Offline
                  thanasis Bronze Member @Egika
                  @Egika I don’t understand why I m not seing zonesense in my app ! I added it ok the watch , I could see the details but there is nothing on the app. Where do you see that ? (iOS btw)
                  EgikaE 1 Reply Last reply Reply Quote 1
                  • EgikaE Offline
                    Egika Platinum Member @thanasis
                    @thanasis have you updated your app? It is in the activity details.
                    thanasisT 1 Reply Last reply Reply Quote 0
                    • EgikaE Offline
                      Egika Platinum Member @GiPFELKiND
                      Later the graph from ZoneSense is Red with 180 bpm… And finally we have Red graph With 170 bpm… Suunto Smart Sensor!
                      Please check the video:
                      https://youtu.be/bD3O4BZ9vIc?si=FfvmBw9HMXuT19HK&t=2551
                      There is muscle stress that is independent of the heart stress. ZoneSense does no only map your HR zones in a different way. It is an independent real time measurement.
                      And it needs some time to reach homeostasis. Short activity tests with longer resting will not properly reflect in ZoneSense. This is also in the video.
                      • thanasisT Offline
                        @Egika said in Suunto ZoneSense:
                        Well it indeed needed an update and it doesn’t show that there is a newer version ,. Thanks !!!
                        • ? Offline
                          A Former User
                          I’m curious to know if disabling sleep tracking and HR 24/7 on the watch still allows the ZoneSense algorithm to function properly.
                          L isaziI 2 Replies Last reply Reply Quote 0
                          • L Offline
                            Luis Andés Olmedo Bronze Member @Guest
                            @obhikkhu said in Suunto ZoneSense:
                            I do not use sleep tracking nor HR 24/7 and yesterday I got ZoneSense suggestions after 45’ running.
                            • AntoineA Offline
                              Antoine Bronze Member
                              Screenshot_20240919_130531_Suunto.jpg Screenshot_20240919_130017_Suunto.jpg Screenshot_20240919_125455_Suunto.jpg
                              I don’t have the “measured” values and HR values do not correspond to HR zone i can see in information field.
                              With ZoneSens i am in “arrobie” zone but according to HR zones i should be in zones 3/4/5.
                              I don’t understand ? 🤔
                              Can someone explain ?
                              Thanks
                              Suunto vertical solar
                              Coros arm HRM / Suunto wing 2
                              Android A55 Samsung
                              Suunto App latest official update
                              L 1 Reply Last reply Reply Quote 0
                              • L Offline
                                Luis Andés Olmedo Bronze Member @Antoine
                                @Antoine said in Suunto ZoneSense:
                                Thanks
                                It is explained above (with links) in this same thread.
                                • isaziI Offline
                                  isazi Moderator @taziden
                                  @taziden well this would not be fair to people not using a chest strap (or equivalent device that measures the time between beats)
                                  Blog: isazi's home
                                  tazidenT 1 Reply Last reply Reply Quote 0
                                  • tazidenT Offline
                                    taziden Gold Members @isazi
                                    @isazi said in Suunto ZoneSense:
                                    And after using it today and seeing the presentation video, I’m wondering how usable it is in real time as, from what I understand, it requires some time to settle (homeostasis) to be accurate.
                                    S9PP
                                    • isaziI Offline
                                      isazi Moderator @Zdeněk Hruška
                                      @Zdeněk-Hruška it should also be mentioned in the documentation, but the suggested thresholds are only computed during the first hour, because after fatigue starts setting in. So a good 20-30 minute aerobic test should be enough.
                                      Blog: isazi's home
                                      • isaziI Offline
                                        isazi Moderator @Guest
                                        @obhikkhu yes, totally unrelated, ZoneSense only works for activities (and using a chest strap)
                                        Blog: isazi's home
                                        • L Offline
                                          larrybbaker @Mff73
                                          @Mff73 you need a chest strap that measures R-R and the S+ app is my understanding.
                                          Vertical Ti Solar
                                          Vertical 2
                                          Race 2
                                          iPhone 17 Pro
                                          isaziI 1 Reply Last reply Reply Quote 1
                                          • isaziI Offline
                                            isazi Moderator @larrybbaker
                                            @larrybbaker for real time, yes. For seeing ZoneSense in the app, just the strap is enough.
                                            Blog: isazi's home
                                            ? 1 Reply Last reply Reply Quote 2
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
