    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Stryd + Vertical Pairing
    Scheduled Pinned Locked Moved Suunto Vertical
    19 Posts 10 Posters 3.2k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • murphyp228M Offline
      murphyp228
      Hi have recently bought the Stryd duo pods - does anyone know when pairing the devices does the SV pair both of them or just one ?
      Ultra marathon / Ironman triathlete
      Suunto Vertical Titanium + Stryd Duo
      Suunto Baro 9
      Suunto Spartan
      Ze StuartZ 1 Reply Last reply Reply Quote 0
      • Ze StuartZ Offline
        Ze Stuart Gold Members @murphyp228
        @murphyp228 just one, and to extract the most data, don’t use the Stryd S+ app, but instead pair them as a footpod.
        After your run, sync the pods via the Stryd app and the data from both platforms will match.
        If you’re following a Stryd workout, don’t forget to disable auto-laps on your running profile, as otherwise Stryd won’t be able to match the intervals.
        https://zulusierra.co
        herlasH murphyp228M Alexey KholodkovA 3 Replies Last reply Reply Quote 0
        • herlasH Online
          herlas Silver Members @Ze Stuart
          @murphyp228 Stryd Duo is created on the Stryd app, as @Ze-Stuart said, the watch will only see one but for Stryd purposes, both will record data and you’ll see that in the Stryd app metrics.
          SRS Ti
          SRun (primarily road runner so testing SRun is a must ;))
            murphyp228
            Thanks @herlas @Ze-Stuart
            Suunto Baro 9
            Suunto Spartan
              @murphyp228 I made a longer write-up: https://zulusierra.co/p/using-suunto-and-stryd-in-2024
              herlasH 1 Reply Last reply Reply Quote 1
              • herlasH Online
                @Ze-Stuart nice article, couple of bits to add to it:
                usage is counter-intuitive: if you have your Stryd pod paired to the watch, you have to un-pair it as a foot pod, so that the S+ app can connect to it —> no need to un-pair from watch, just disable foot pod from pre workout screen and that’s it.
                for the not so good section, in case you want to add, it’s not a big deal, but there’s a long standing issue with Suunto-Stryd only, runs will get shorten from 7 to 10 secs on the first lap once synced to Stryd.
                Suunto watches do not record power into FIT file during those initial seconds and Stryd doesn’t show you on their platform any time without a watt associated. Long history short, neither Suunto or Stryd want to fix this, I have tried and more than once 🙂
                SRS Ti
                Ze StuartZ Steven VanlanckerS 2 Replies Last reply Reply Quote 1
                  Ze Stuart Gold Members @herlas
                  @herlas nice! Thanks! I’ll update tomorrow.
                    murphyp228 @Ze Stuart
                    @Ze-Stuart thank you, I tried the s+ app today as a trial and i did a manual sync int eh Stryd app - I ended my with duplicates - is this normal and I just delete the one with the least data in it ?
                    Also is I don’t use the S+ app and I do the same, save and sync run in Suunto app and then do a manual sync in Stryd - will I end up with duplicates ?
                    Cheers
                    Suunto Baro 9
                    Suunto Spartan
                    • Steven VanlanckerS Offline
                      Steven Vanlancker @herlas
                      @herlas Is this solved yet? I just paired my Stryd to the Race 2, didn’t do a run but testing in out while walking around in the house. Seems the data is coming correctly from the Stryd (because the Suunto is on the table). I can’t pair as a foot pod as that doesn’t shows up. I also don’t use the Stryd+ app but have a data field with 3sec power.
                      herlasH 1 Reply Last reply Reply Quote 0
                      • herlasH Online
                        herlas Silver Members @Steven Vanlancker
                        @Steven-Vanlancker with Race 2 and other models that received lasted firmware, Stryd can only be pair as footpod, which means you’ll get data from the Stryd in most conditions, it’s said that in future update, you’ll be able to select what data to receive from the Stryd pod.
                        SRS Ti
                        • v.sacreV Offline
                          v.sacre Silver Members
                          Hey all stryd users.
                          Can you tell me the correct procedure to use stryd with Vertical after recent update ?
                          It’s a bit weird how it is actually on my settings.
                          When using run mode, stryd is paired as sensor but watch doesn’t detect my heartrate smart sensor.
                          When using trail, it detects HR but not stryd as a sensor. But I can use stryd s+ app and it records all stryd data in addition to suunto wrist power…
                          A3S | S9B | S9P | S9PP | SV1 Ti | SV2 Ti
                          Suunto Wing
                          Suunto App: Android Beta
                          • Alexey KholodkovA Offline
                            Alexey Kholodkov @Ze Stuart
                            @Ze-Stuart just bought Stryd5 and trying to configure it to get Stryd’s pace on my Vertical. Pairing with S+ app is easy, but that app doesn’t display pace.
                            I found your post with suggestion to pair as foot pod, but how to do that?
                            I tried to disconnect Stryd and uninstall S+ app. And when I connect Stryd again, it connects as power sensor. There is no menu where I could select “foot pod” pairing.
                            Communication with Suunto support is also confusing. They say that:
                            1. There is no way to get pace directly from pod. Watches will anyway calculate pace with their own algorithms
                            2. I could get pod pace in custom sport mode. I tried to create one but failed to find sensor’s data there
                            3. There may be third party S+ apps that show pod pace. But I don’t find any in S+ store
                            So, is there a way to get Stryd’s pace while training?
                            Zdeněk HruškaZ 1 Reply Last reply Reply Quote 0
                            • Zdeněk HruškaZ Offline
                              Zdeněk Hruška Bronze Member @Alexey Kholodkov
                              @Alexey-Kholodkov @v.sacre
                              I had the same issue with 5.0. I had contacted the Stryd support and they enabled an extra update which fixed pairing to Suunto.
                              I would think that the update is already out for everyone but it doesn’t seem to be the case.
                              They may be another issue that the pairing with Suunto breaks after some time and it needs to be repaired but that seems to be more on the Suunto side. However after the Stryd update I am able to properly pair Stryd 5.0 as a foot pod which takes power, cadence, pace.
                              SquirrelS 1 Reply Last reply Reply Quote 1
                              • SquirrelS Offline
                                Squirrel Silver Members @Zdeněk Hruška
                                @Zdeněk-Hruška Can you see the fixed firmware version of your Stryd 5 in Stryd app?
                                Race S
                                  Zdeněk Hruška Bronze Member @Squirrel
                                  @Squirrel It says 3.1.9
                                  • K Offline
                                    kurtpenter Bronze Member
                                    I noticed only now after years probably that I don’t get vertical oscillation and ground contact from Stryd.
                                    I paired Suunto Vertical with Stryd NextGen as footpod. When I end a workout both metrics in the Stryd app are always 0. I have however the footpath graph and I guess all or most of the other metrics.
                                    There is a link saying you need to use the Stryd SuuntoPlus app to “see” more metrics: https://apac.suunto.com/ja-jp/blogs/blog/improve-your-running-technique-with-suunto-and-stryd
                                    I thought that was useful to SEE the metric while running, but the recording on the pod would include everything.
                                    Plus others in this thread say you get more metrics via food pod pairing.
                                    Any hint? I’m puzzled.
                                    Christoph Van LaethemC 1 Reply Last reply Reply Quote 0
                                    • Christoph Van LaethemC Offline
                                      Christoph Van Laethem @kurtpenter
                                      @kurtpenter
                                      Hi, i had also some problems, but now, this is how i do it now. I have the Vertical 2 and the Stryd 5. I just connect my stryd 5 in connections, i have not installed the suunto stryd+ app. I just put a power training into the interval app. In interval on the watch, you can see te power your running, HB and time. after the run i can see all data in Stryd app are online in stryd.
                                      for me this works
                                        If you use the stryd from the suunto +app, then this will only work if you disconnect de stryd in connections, it seems not compatible
                                        K 1 Reply Last reply Reply Quote 0
                                        • K Offline
                                          kurtpenter Bronze Member @Christoph Van Laethem
                                          @Christoph-Van-Laethem thank you, I had the same setup as yours (barring older Stryd and Vertical… Lucky you! 😉). I see many metrics (and power obviously) but never see Vertical Oscillation nor Ground Contact. I’ve been trying last 2 runs with Suunto+ after disconnecting as sensor… it seems to work so far, I’ll try more. The thing which bothers me is you do not see if Stryd connected when about to start… you start… miss the power info, stop, go to the Stryd app and check, then restart. Not great.
                                          Register Login
                                          • First post
                                            Last post
                                          Suunto Terms | Privacy Policy
