solar charging
Re: Suunto Vertical: Bug Collection
- Is it possible to know what percentage of the battery I gained during solar charging
- how can it possible for two watches in the same place under the same lighting to receive a different solar charging level (at least this is what is shown in the solar graph of the watches)
@Danny-poleg I guess two watches cannot be in exactly the same place:). May depend on angle of light, etc. I have two Vertical watches and wearing one on either arm for long runs certainly gives different solar charging levels. I do not know what the algorithm does that predicts charging but one could imagine it is not at the level of precision that you are expecting.
@Danny-poleg
You already asked this question here, https://forum.suunto.com/post/125166
Even if no official answer came, there seems to be some hint for you to test (if you want to test
) : reboot the watch which doesnβt charge as fast as the other, and check again.
If you donβt want to test
, donβt hesitate to send me two solar SV, I can try (joke mode
With your input, this post could be even better π
Register Login
