    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Watch turned off and does not reboot
    Scheduled Pinned Locked Moved Suunto Vertical
    74 Posts 30 Posters 25.4k Views 27 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • darxmurfD Offline
      darxmurf Platinum Member @freeheeler
      @freeheeler went swimming with mine as a first activity test 2 days ago and it’s fine too 😂 problem is elsewhere maybe
      https://www.instagram.com/darxmurf/ - https://www.instagram.com/omch.swiss/
      N 1 Reply Last reply Reply Quote 0
      • N Offline
        Norbert
        Hello,
        Had exactly the same problem with my Vertical yesterday.
        Went swimming in the Ocean using snorkeling mode. 30 Min 5 dives. After that the watch went funny. It was difficult to navigate the watch via screen or push buttons. I then did a soft rest and the watch went blank. Tried the charger, holding reset again, pushing all button at the same time, etc. Nothing works. An Eur 800 watch which lasted about 2.5 Months. Now dead.
        First time this ever happened to a Suunto watch. Been using Suunto since the Ambit.
        Going through this thread, it it clear that this is not an isolate case. It seems certain Suunto Verticals have issues with water.
        Once returning from our vacation, there is no option left other then opening a repair ticket and sending it back to Suunto.
        Regards
        Norbert
        D6I / Ambit / Ambit 2 / Ambit 3 Peak Safire HR / S7 /
        S9 Baro / S9T / S9 Baro T RB / S9 Peak / SV / Ocean
        • N Offline
          Norbert @darxmurf
          @darxmurf Went swimming with mine yesterday in the ocean, after that needed to do a soft reset and the watch went blank. The watch is dead since.
          darxmurfD surfboomerangS 2 Replies Last reply Reply Quote 0
          • darxmurfD Offline
            darxmurf Platinum Member @Norbert
            @Norbert I kept the sequence to reset or shutdown the watch, can you try it?
            • press 4 seconds the middle button
            • 1 press middle
            • 9 press down then center then top to shutdown the watch
              OR
            • 8 press down then center then top to factory reset the watch
            N 2 Replies Last reply Reply Quote 3
            • darxmurfD Offline
              What I find pretty sad here it’s the fact that suunto is not publishing anything about that issue.
              M 1 Reply Last reply Reply Quote 0
              • M Offline
                MKPotts Bronze Member @darxmurf
                @darxmurf
                It’s not just the Vertical, my 9 Peak Pro died in the same way last night and I can’t get it to turn back on.
                • surfboomerangS Offline
                  surfboomerang @Norbert
                  @Norbert Was the watch recording an activity or was it just submerged?
                  Suunto Vertical Titanium Solar
                  OnePlus Nord 4
                  • sartoricS Offline
                    sartoric Moderator
                    by any chance did you pressed any button while under water?
                    SVTS - 2.50.28
                    SSSWHR BARO Amber - 2.8.32
                    Samsung A5 2016 - Android 7.0
                    Suunto App Android 6.11.8 beta
                    • N Offline
                      Norbert @darxmurf
                      @darxmurf Many thanks. Will try. But not quite clear on the sequence though.
                      Regards
                      Norbert
                      • N Offline
                        Norbert @sartoric
                        @sartoric No I did not.
                        • N Offline
                          Norbert @surfboomerang
                          @surfboomerang I had it in Snorkel Mode. When out of the water it had about 30min and 5 dives recorded. So I guess the answer is yes m.
                          After being back on shore the watch went funny. I could not navigate it probably. I the. Did a soft reset and the watch went blank. It is blank since.
                          • N Offline
                            Norbert @darxmurf
                            @darxmurf I tried your suggestions in various combinations. The watch remains unresponsive. I think the watch is dead. Once back in Europe I’ll send it back to Suunto.
                            I am using Suunto since the early Ambit versions., plus I have a D6I. This happened never to me before.
                            Thank you for your help though.
                            Regards
                            Norbert
                            • darxmurfD Offline
                              My brother just received his watch back. Here is the explanation.
                              Dear Customer, I have examined your unit for the faults reported in the fault description and performed all the necessary tests. I discovered that the issue you have faced is caused by a known software bug. We are currently working on solving this issue and the problem should be fixed in the next software release. Best regards
                              isaziI 1 Reply Last reply Reply Quote 1
                              • isaziI Offline
                                isazi Moderator @darxmurf
                                @darxmurf I also forwarded all the forum discussions and topics to Suunto, in case there is some information here that’s relevant for the developers
                                Blog: isazi's home
                                B 1 Reply Last reply Reply Quote 4
                                • B Offline
                                  bruno.tanqueray @isazi
                                  @isazi : Thank you Isazi. It will be nice to understand this “monster bug”, to get some recommendations from Suunto to avoid it and a procedure to reboot the SV if necessary. 😉
                                  darxmurfD 1 Reply Last reply Reply Quote 1
                                  • darxmurfD Offline
                                    darxmurf Platinum Member @bruno.tanqueray
                                    @bruno-tanqueray if they found the bug in question and already have a fix, I strongly suggest them to push that update asap 😬 😬
                                    • B Offline
                                      bruno.tanqueray @darxmurf
                                      @darxmurf : Yes you are right I’m waiting also this update!
                                      • B Offline
                                        bruno.tanqueray
                                        Hello,
                                        I just received my SV few minutes ago, which had been repaired in Finland after more than 15 days (DHL was very slow due to bank holidays in France). Good news, it’s not a new watch but my model repaired without reset and return to factory settings. So all my settings and maps have been kept. However no new firmware, I stay with 2.25.66 ;-(
                                        The battery of my watch was completely empty, I understand that to obtain a reboot it is the best solution. But how do we do this on our own when faced with a watch that is off and no longer responding to anything… There must be a solution while waiting for the firmware update!
                                        N 1 Reply Last reply Reply Quote 1
                                        • N Offline
                                          Norbert @bruno.tanqueray
                                          @bruno-tanqueray Yes, it is a very unfortunate situation. For such situations there needs to be a mechanical reset.
                                          In my case, we are here in the middle of the Caribbean and the Suunto Vertical died. There is no way to do a hard reset and get this watch going again… Even if this bug is fixed, the watch needs to be sent to Suunto. Since the watch is unresponsive, it cannot be updated also. Connecting it to Suunto Link does not do anything.
                                          This is a €800 watch. By the time we have returned home and there is some resolution, it’s going to be 4 weeks.
                                          zhang965Z 1 Reply Last reply Reply Quote 2
                                          • zhang965Z Offline
                                            zhang965 @Norbert
                                            @Norbert said in Watch turned off and does not reboot:
                                            Hope you paid the watch with cashback service…
                                            Winners Wear Winners
                                            GiPFELKiNDG 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
