    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Issue pairing Baro 9 with Pixel 7
    17 Posts 7 Posters 2.6k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • J Offline
      Johann
      Hello,
      I have an issue when I try to pair my Suunto 9 Baro with my new Pixel 7 (Suunto App).
      The mobile detect well the watch as I can select my watch, but after I have an unknown error asking me to retry.
      I have already restarted the watch and the mobile.
      The pairing with my old UTC worked fine.
      I have already deleted the mobileapp paired in the watch.
      Any idea ?
      Thanks
      Łukasz SzmigielŁ freeheelerF 2 Replies Last reply Reply Quote 0
      • Łukasz SzmigielŁ Offline
        Łukasz Szmigiel @Johann
        @Johann remove the watch from Android Bluetooth devices and try pairing it again via SA.
        S9PP 2.50.28
        • AlexMmmA Offline
          AlexMmm
          Just got a new Pixel 7 and my 9 Baro is also not pairing. Have already worked through the list of actions in the Suunto help guide. Nothing works. Watch paied fine with old phone.
          Did you get this solved?
          • S Offline
            SvenG
            I have the exact same problem with my Pixel 7a. Connecting as a normal bluetooth device works fine but within the app I don’t get the question for PIN and no PIN is showing up on the watch. And yes, I’ve removed the watch from the list of bluetooth devices before I tried to connect from the app.
            Łukasz SzmigielŁ Mff73M 2 Replies Last reply Reply Quote 0
              Łukasz Szmigiel @SvenG
              @SvenG did you remove the connection from the watch too?
              S9PP 2.50.28
              S 1 Reply Last reply Reply Quote 0
              • Mff73M Offline
                Mff73 @SvenG
                @SvenG said in Issue pairing Baro 9 with Pixel 7:
                And did you reboot your phone after this removing from BT list?
                Sometimes it is removed but still putting mess somewhere
                SSU (retired), SV1, SV2
                Wife : S9PP
                SA: Always the latest beta :)
                Android + Galaxy S205G
                • freeheelerF Offline
                  freeheeler @Johann
                  @Johann
                  @Alex-Machado
                  @SvenG
                  did you manage to connect your watch with the phone by now?
                  I’ve had the same issue with my up to date Pixel 4a 5G.
                  what helped was to clear cache and storage of SA. after that connecting worked flawlessly like always
                  living sideways
                  AlexMmmA 1 Reply Last reply Reply Quote 0
                  • J Offline
                    Johann
                    I had to pair (bluetooth) the watch with the mobile first.
                    After, the app was able to detect my watch.
                    Thanks for your help.
                    freeheelerF 1 Reply Last reply Reply Quote 0
                      freeheeler @Johann
                      @Johann
                      strange this is exactly the way it never worked and afaik shouldn’t work
                      living sideways
                      J 1 Reply Last reply Reply Quote 0
                      • J Offline
                        Johann @freeheeler
                        @freeheeler
                        • freeheelerF freeheeler referenced this topic on
                        • S Offline
                          SvenG @Łukasz Szmigiel
                          @Łukasz-Szmigiel Yes I did
                          • S Offline
                            SvenG @Mff73
                            @Mff73 Yes I reboot my phone and removed the bluetooth connection in the phone. Even did booth soft and hard reset of the watch, nothing helped.
                            • AlexMmmA Offline
                              AlexMmm @freeheeler
                              @freeheeler
                              I have not managed to get them paired.
                              I was chatting with Suunto support earlier today and they are both aware of the problem and monitoring this thread. They seemed very informed on the issue and said Engineering is also aware and working on a fix with haste.
                              I got a good sense they’re working it, from the chat.
                              S 1 Reply Last reply Reply Quote 3
                              • S Offline
                                SvenG @AlexMmm
                                @AlexMmm Good to hear that they are aware of the problem and work on it. I spoke with the chat a week ago and then they seemed to never heard of the problem. It is however frustrating that it doesn’t work.
                                isaziI 1 Reply Last reply Reply Quote 0
                                • isaziI Offline
                                  isazi Moderator @SvenG
                                  @SvenG have you checked this?
                                  https://forum.suunto.com/post/125505
                                  Blog: isazi's home
                                  • S Offline
                                    SvenG @isazi
                                    @isazi That suggestion actually worked. Thank you.
                                    • isaziI Offline
                                      @SvenG a proper solution is also being tested by the app developers, apparently something changed with a recent Pixel update.
                                      Blog: isazi's home
                                      Register Login
                                      • First post
                                        Last post
                                      Suunto Terms | Privacy Policy
