    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto+ Loop (pace) issue
    Scheduled Pinned Locked Moved SuuntoPlus™ Sports Apps
    12 Posts 3 Posters 2.1k Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S Offline
      smopi
      Hi,
      Does the Loop (pace) app work for you?
      Today I went to the park and at the beginning of the loop I pressed the bottom right button. I passed the starting point several times, but not once was a new lap recorded. There is also no lap information in the activity summary. What could be the reason?
      Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
      • Łukasz SzmigielŁ Online
        Łukasz Szmigiel @smopi
        @smopi did you press the loop button while on the S+ screen?
        S9PP 2.50.28
        S 1 Reply Last reply Reply Quote 0
        • S Offline
          smopi @Łukasz Szmigiel
          @Łukasz-Szmigiel, thank you for your answer. I’m not sure but it’s possible it was on the first screen, not on the S+ screen.
            @smopi as far as I’m aware, the lap button should add a manual lap when on regular data screens and launch a special action when on S+ screen. However, in case of “Loop” S+, it should be necessary to just add one manual lap to mark the place where laps meet. On other S+ apps you can, for example, skip the workout phase by hitting the lap button.
            S9PP 2.50.28
            S EzioAuditoreE 2 Replies Last reply Reply Quote 0
            • S Offline
              @Łukasz-Szmigiel said in Suunto+ Loop (pace) issue:
              I did, but possibly not on the S+ screen. I’ll check it next time and let you know if it helps.
              • S Offline
                smopi
                @Łukasz-Szmigiel, It seems that the app only works when navigation is enabled in the activity options. Bug or feature?
                I don’t know why it would matter, but when I turned off navigation before turning on the activity, the app didn’t work, no matter what screen I was on.
                  @smopi meaning that it didn’t work when you disabled the navigation screen (breadcrumbs)? This is strange - I wonder if devs know about it. It may be that the app is using the data from the navigation screen for performance reasons.
                  S9PP 2.50.28
                  • S Offline
                    No, it didn’t work when navigation was not enabled at all before I started the activity.
                    • S Offline
                      smopi
                      Hi, the latest update fixed this problem. The application works properly even after turning off navigation (with GPS turned on, of course).
                      • EzioAuditoreE Offline
                        EzioAuditore Gold Members @Łukasz Szmigiel
                        Do you know if this applies to TrainingPeaks Guides? I’ve tried multiple times to advance an interval by pressing the lap button but it never did.
                        Suunto watches: Vertical 2 (Titanium Sage), Race 2 (Titanium Trail), Ocean (Sand), Race (Titanium Charcoal), Vertical (Titanium Solar Sand), 9 Baro (Ambassador Edition), Spartan Ultra (Copper Edition), Ambit 2, S6
                        Suunto Wing
                          Łukasz Szmigiel @EzioAuditore
                          @EzioAuditore no idea, I’ve never used TrainingPeaks.
                          S9PP 2.50.28
                          EzioAuditoreE 1 Reply Last reply Reply Quote 0
                            @Łukasz-Szmigiel okie, thanks!
                            Suunto Wing
                            • isaziI isazi moved this topic from Suunto Vertical on
                            Register Login
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
