    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Beta Release for Suunto 9 Peak Pro, Suunto 9 Peak, Suunto 9 Baro, Suunto 9 and Suunto 5 Peak
    Scheduled Pinned Locked Moved Watches
    311 Posts 81 Posters 136.9k Views 79 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • DMytroD Offline
      DMytro @isazi
      @isazi unless you had neither turned on in daily mode, which was my setting.
      1 Reply Last reply Reply Quote 4
      • Umer JavedU Offline
        Umer Javed @Guest
        @Dan-Cantir said in Suunto Beta Release for Suunto 9 Peak Pro, Suunto 9 Peak, Suunto 9 Baro, Suunto 9 and Suunto 5 Peak:
        @Ilya-Sul yep, nice addition, but did you notice any battery life impact? I have lost 20% during 1 day and 8 hours with 1h30m of activity only. 😬
        Similar experience on my end on the 9PP. I lost around 20% over 14 hours (7 PM to 9 AM):
        • Only recorded one 30 minute walk during this time, no S+ used.
        • I have all widgets active except NOTIFICATION and ACTIVITY
        • RTW is on, but sleep DND would have been active overnight
        • 24/7 HR is on
        • Sleep tracking is on with SpO2
        • 1 alarm in the morning
        Mff73M 1 Reply Last reply Reply Quote 0
        • inkognitoI Offline
          inkognito Platinum Member @isazi
          @isazi I agree. The problems are somewhere else:
          1. we have lost the “exercise only” option for raise to wake
          2. Low backlight is now unnecessarily bright
          SV: fingers crossed :D
          S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
          Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
          Despite some pretty bad luck, I still love Suunto!
          • Mff73M Offline
            Mff73 @Umer Javed
            @Umer-Javed
            After any FW update, battery calibration may be necessary for the gauge to be reliable. Wait a full discharge/recharge first I would say.
            SSU (retired), SV1, SV2
            Wife : S9PP
            SA: Always the latest beta :)
            Android + Galaxy S205G
            Umer JavedU 1 Reply Last reply Reply Quote 1
            • suzzloS Offline
              suzzlo Moderator
              I’m S9P user, and I have updated, just because I love to test new things.
              Unfortunately I haven’t find anything new except wake on raise that is working fine for me and small UI changes (font?, darker colors, more contrast…) I was expecting something more, like guide alerts…
              Anyway, no problem with the beta 👍🏻👍🏻👍🏻
              @isazi do you know which bugs are corrected in the beta FW?
              BR
              Suunto: Race, S9Peak, Spartan Sport Wrist
              Garmin: FR745, Edge 530
              SA topics:
              • Guides - https://forum.suunto.com/tags/guides
              isaziI 1 Reply Last reply Reply Quote 4
              • A Offline
                ARTi1888
                S9PP
                The option: “backlight during activity” has disappeared 😔
                  Umer Javed @Mff73
                  @Mff73 said in Suunto Beta Release for Suunto 9 Peak Pro, Suunto 9 Peak, Suunto 9 Baro, Suunto 9 and Suunto 5 Peak:
                  @Umer-Javed
                  Thanks! I’ll recalibrate and try again. I’m planning on using it well for a few more days before I fill the survey.
                  B 1 Reply Last reply Reply Quote 0
                  • DMytroD Offline
                    DMytro
                    Apparently this update has decalibrated my battery a little. When I started activity, it said I have 6h worth of charge, after 20m I finished. Next time I looked at my watch, within 10m, it showed empty battery screen.
                    I could be wrong about battery estimate tho, so if it’s the only occurrence, you may as well ignore my comment.
                    • MdzOttM Offline
                      MdzOtt @Thierry Forget
                      @Thierry-Forget the same happened to me. Is there a way to reconnect to Strava?
                      R2
                      S9 Baro
                      SA on Android
                      Ambit 3 Peak
                      Ambit 2 Sapphire
                      MdzOttM 1 Reply Last reply Reply Quote 0
                      • MdzOttM Offline
                        MdzOtt
                        The good: The FW update worked without a flaw.
                        The not so good: i tried to see how the Strava segments would work. But since the update, I don’t have any Guides on the watch, nor I have any “Sport apps”. The SA claims that the sport apps are installed, but the watch says “None”. i stared three segments in Strava, one of them initially showed up in Guides, but even if i Pinned it, it did not synch to the watch (and SA said “not in the watch”). The guide on how to enable Strava segments suggests to unlink the Strava and link it back. Unlinking works, but linking it back does not (when i press the “Authorise” button, another tab is open with “Connect to Strava” button).
                        Are there any ideas on how to sort this out?
                        Edit on Sport Apps - they did sync to the watch, eventually. Btw. selecting the Sport App in the watch is not obvious - the tiny down arrow is hardly visible. Is this new or it was like that for a while (obviously, i haven’t been using Sports Apps for a while).
                        R2
                        S9 Baro
                        SA on Android
                        Ambit 3 Peak
                        Ambit 2 Sapphire
                        • MdzOttM Offline
                          MdzOtt @MdzOtt
                          @MdzOtt said in Suunto Beta Release for Suunto 9 Peak Pro, Suunto 9 Peak, Suunto 9 Baro, Suunto 9 and Suunto 5 Peak:
                          R2
                          S9 Baro
                          SA on Android
                          Ambit 3 Peak
                          Ambit 2 Sapphire
                          • ? Offline
                            A Former User @MdzOtt
                            @MdzOtt ticket has been submitted
                            MdzOttM 2 Replies Last reply Reply Quote 0
                            • MdzOttM Offline
                              MdzOtt @Guest
                              @twekkel i noticed. There is a separate thread on that topic (not much info, though): https://forum.suunto.com/post/122516 (i just noticed that you referenced the same thread) (:-)
                              R2
                              S9 Baro
                              SA on Android
                              Ambit 3 Peak
                              Ambit 2 Sapphire
                              • MdzOttM Offline
                                MdzOtt
                                Someone mentioned before that with the new FW, the Sports App selection is remembered (or could be saved with the Sports Mode (?)). I don’t see it working.
                                R2
                                S9 Baro
                                SA on Android
                                Ambit 3 Peak
                                Ambit 2 Sapphire
                                DMytroD 1 Reply Last reply Reply Quote 1
                                • DMytroD Offline
                                  DMytro @MdzOtt
                                  @MdzOtt on new UI watches
                                  • isaziI Offline
                                    isazi Moderator @suzzlo
                                    @suzzlo one example I know is the double distance in tunnels.
                                    Blog: isazi's home
                                      Dimitrios Kanellopoulos Community Manager
                                      Hi after each update please let the battery drain to 0 and charge to 100. Also a soft reboot. That is needed for calibration
                                      Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
                                      DMytroD C 2 Replies Last reply Reply Quote 4
                                      • DMytroD Offline
                                        DMytro @Dimitrios Kanellopoulos
                                        @Dimitrios-Kanellopoulos you mean each beta or in general?
                                        tazidenT 1 Reply Last reply Reply Quote 0
                                        • tazidenT Offline
                                          taziden Gold Members @DMytro
                                          @DMytro said in Suunto Beta Release for Suunto 9 Peak Pro, Suunto 9 Peak, Suunto 9 Baro, Suunto 9 and Suunto 5 Peak:
                                          Each firmware update (beta or not).
                                          S9PP
                                          • EfejotaE Offline
                                            Efejota Bronze Member
                                            For those not seeing Suunto Apps in the watch and just in case. After the update, the Suunto Apps that Ii had installed previously did not show in the watch. I simply uninstalled and installed back again using the App. Not they all show fine and can select them for any activity. Even during the activity itself!!! Great work, Suunto.
                                            J
                                            1 Reply Last reply Reply Quote 3
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
