    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Beta Release for Suunto 9 Peak Pro, Suunto 9 Peak, Suunto 9 Baro, Suunto 9 and Suunto 5 Peak
    Scheduled Pinned Locked Moved Watches
    311 Posts 81 Posters 139.0k Views 79 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • zhang965Z Offline
      zhang965 @Highlands
      @Highlands said in Suunto Beta Release for Suunto 9 Peak Pro, Suunto 9 Peak, Suunto 9 Baro, Suunto 9 and Suunto 5 Peak:
      jthomi Same with my 9pp. Also, for me the lag seems to be still in place. Initially, after I updated my watch the lag when starting an activity seemed less annoying for me but eventually, lag in its full beauty came back. A friend here in the forum suggested to me to factory reset the watch and that would solve it. I haven’t done it yet cause I don’t have the time to deal with factory resets.
      You should be a little bit positive, vertical has the missing name bug as well at least your S9PP has the same user experience as vertical
      Winners Wear Winners
      • Djordje SD Offline
        Djordje S Bronze Member
        Do anyone have a problem with battery duration after latest firmware? Before upgrade,battery lasts cca four and half days and now little but more than 3 days. (S9).Thx.
        cosme.costaC inkognitoI 2 Replies Last reply Reply Quote 0
        • cosme.costaC Offline
          cosme.costa @Djordje S
          @Djordje-S I do not know your configuration but if you had active raise to wake backlight only for activities with the new firmware it stays active in all situations, even in normal mode, so this could be the cause. With a S9B I disabled it and I have the same battery life than before, or at least I haven’nt noticed more battery consumption.
          Djordje SD 1 Reply Last reply Reply Quote 0
            Djordje S Bronze Member @cosme.costa
            @cosme-costa thx.raise to wake is active ut it was active as well with previous fw veraion.
            cosme.costaC 1 Reply Last reply Reply Quote 0
              @Djordje-S Yes, an now is brighter so maybe here there is more comsumption and as I have said, if before was active only during activities now is always active, even in watch mode.
              • flucaF Offline
                fluca Silver Members @jthomi
                @jthomi yes haapens to me as well
                  @cosme-costa that was my assumption as well initially but did nit expect that it will consume that much.
                  • Łukasz SzmigielŁ Offline
                    Łukasz Szmigiel
                    I have limited rise to wake to a dim light with this update and my feeling is that the battery lasts longer now (9PP).
                    S9PP 2.50.28
                    • HighlandsH Offline
                      Highlands @Łukasz Szmigiel
                      @Łukasz-Szmigiel We are all beta testers now… 😂
                      zhang965Z Łukasz SzmigielŁ 2 Replies Last reply Reply Quote 1
                        Djordje S Bronze Member @Łukasz Szmigiel
                        @Łukasz-Szmigiel did that already.Set it on Low and for now I do have a feeling that it lasts longer but will see
                        • inkognitoI Offline
                          inkognito Platinum Member @Djordje S
                          @Djordje-S My S9 usually consumed ~15% per day (with HR and notifications on, low backlight, no Raise to wake, no Standby backlight). Now (after several calibration cycles) it is ~20%. It definitely feels like an increase… Battery consumption during night seems the same as before, so I would really blame the newly increased low backlight level (during notifications or any other interaction with the watch) in my case…
                          SV: fingers crossed :D
                          S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
                          Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
                          Despite some pretty bad luck, I still love Suunto!
                          • zhang965Z Offline
                            zhang965 @Highlands
                            Damn, are you able to identify your watch is S9PP or s9p ?
                            HighlandsH 1 Reply Last reply Reply Quote 0
                              Highlands @zhang965
                              @zhang965 Mine is 9 peak pro.
                                Łukasz Szmigiel @Highlands
                                @Highlands you want to beta test, yeah, you want to? Ok, we’ll make everybody a beta tester now, that’ll show you! 😄
                                S9PP 2.50.28
                                HighlandsH 1 Reply Last reply Reply Quote 1
                                  @Łukasz-Szmigiel Yeah, they learn fast the old Garmin tricks.
                                    Highlands
                                    Hey guys, has any of you figured out mermaiding and snorkeling? What’s the difference? Is Mermaiding about the dives mainly? And the snorkeling is about diving too but the distance gets measured as well?
                                    Umer JavedU 1 Reply Last reply Reply Quote 0
                                    • Umer JavedU Offline
                                      Umer Javed @Highlands
                                      …Is Mermaiding about the dives mainly? And the snorkeling is about diving too but the distance gets measured as well?
                                      That’s basically how I understand it and what the manual says.
                                      Basically I’ve been using Mermaiding weekly at my friend’s pool because it’s shorter than the minimum pool swimming length and GPS fix is not great. At least I can capture my subsurface dives well lol
                                      C HighlandsH 2 Replies Last reply Reply Quote 0
                                      • C Offline
                                        Croatoan @Umer Javed
                                        @Umer-Javed
                                        Isn’t mermaid8ng snorkling with a monofin?
                                        Umer JavedU 1 Reply Last reply Reply Quote 1
                                          Umer Javed @Croatoan
                                          @Croatoan that’s correct. I just culturally appropriated the sport because my friend’s pool is too short to use any of the other modes 😅
                                          • V Offline
                                            vietpq Bronze Member
                                            I still have no Strava segment on my Suunto 9 peak, I tried both IOS and Android. The Suunto 9 peak is updated via beta link.
                                            MdzOttM 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
