    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Bug: charging and maps download issues
    Scheduled Pinned Locked Moved Suunto Vertical
    6 Posts 5 Posters 1.2k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • D Offline
      dombo Bronze Member
      Hi, today I put watch on charger as it was ~15%. I forgot that I marked another map for download meanwhile. When I came to watch ~1 hour later, I saw on screen map download in progress. I was surprised, so I check in suunto app and selected map was already downloaded. So I waited a bit, then I disconnected charger from watch, but downloading in progress was still there. nothing helped to remove it, but watch was connected to suunto app, so I sent logs ~9:48CEST, then I did soft reset. What was my another surprise that watch battery was still 15%. So I sent logs again. When I connected to charger, it went down to 14% and then started to charge. I sent logs again. If you need more details, feel free to contact me.
      • wmichiW Offline
        wmichi
        My SV also doesn’t charge while downloading maps.
        • sartoricS Offline
          sartoric Moderator
          Well, there’s a reason why you need to keep it connected to the charger to download maps.
          Very probably the wifi connection is energy hungry
          Or maybe the watch was just stuck 😁
          SVTS - 2.50.28
          SSSWHR BARO Amber - 2.8.32
          Samsung A5 2016 - Android 7.0
          Suunto App Android 6.11.12 beta
          • D Offline
            dombo Bronze Member
            so my watch today freeze again on the charger. this time no map download. when I remove it from the dock it was black screen and no reaction. I had to do soft reset. is it only mine?
            JacobusJ 1 Reply Last reply Reply Quote 0
            • JacobusJ Offline
              Jacobus @dombo
              @dombo I had exactly the samen a ffew weekse ago , also had to do a soft reset after loading
              • Milan ŠádekM Offline
                Milan Šádek Bronze Member
                This issue has not been fixed until now as I have recently expecienced with charging my SV with 7% - 1 hour later one map (which I forgot I set for download ages ago) got downloaded and the battery was as low as at 6%… You have to disconnect and connect the cable once again to start charging the watch - this is pain in guess where… Any idea is this is getting fixed in the upcoming update?
                Register Login
                • First post
                  Last post
                Suunto Terms | Privacy Policy
