    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    solar charging
    Scheduled Pinned Locked Moved Suunto Vertical
    129 Posts 35 Posters 45.7k Views 35 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Brad_OlwinB Offline
      Brad_Olwin Moderator @SvenSchroeter
      @SvenSchroeter I am in the US and had to send in a 9PP, had it back in 1.5 weeks and went to Finland and back. Hopefully yours will be quicker than two weeks. The RaceS is a great second watch, in fact I wear my RaceS most of the time (easy to sleep with) and use the Vertical when I want the bigger screen and longer battery life.
      Vector/T6c/Vertical 2 Ti
      1 Reply Last reply Reply Quote -1
      • sartoricS Offline
        sartoric Moderator @SvenSchroeter
        @SvenSchroeter
        Shipping is really fast, usually, like a couple of days.
        I’ve noticed that the “weekly” bars widget, with the production FW, seem to refresh only after a restart. They normally are stuck to the min value while the complication works correctly
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.11.8 beta
        SvenSchroeterS 1 Reply Last reply Reply Quote 1
        • SvenSchroeterS Offline
          SvenSchroeter @sartoric
          @sartoric instead I notice the weekly bars are at a minimum value (barely registering) and the hourly one the same… but the complication is not registering anything, and the hourly bars are not incriminating past the minimum. Been like that for a while for me now. Somehow and somewhere it’s getting stuck. In HW or FW. 😅 lucky me 😇
          Suunto Vertical Ti Solar (Daily)
          Suunto Race (Wife Daily)
          Retired: Suunto Ambit3 / Ambit / Core
          https://www.strava.com/athletes/142980701
          • Wojciech ŁużniakW Offline
            Wojciech Łużniak
            Hi,
            I’m connecting to the thread of solar charging but with slightly different issue. I have Vertical for several months and I’ve noticed that when charging, i.e. the whole day (meaning the bars are full for most of the time, morning till late afternoon), I’ve noticed that battery % might go a little up, by 1-2%. Or when doing some activities, it drops by smaller amount than usual. And that seems ok to me.
            But the real issue comes later - the watch suddenly reports battery % dropping over the next hours, by several %. It seems very odd, like the power measurement is providing false measures. I can’t tell if in the end the whole battery life remains the same. In a very short period of time the battery can drop by even more than 10%.
            Has anyone noticed similar issue?
            sartoricS 1 Reply Last reply Reply Quote 0
            • sartoricS Offline
              sartoric Moderator @Wojciech Łużniak
              @Wojciech-Łużniak
              you’re probably experiencing battery drain
              SVTS - 2.50.28
              Wojciech ŁużniakW 1 Reply Last reply Reply Quote 1
                Wojciech Łużniak @sartoric
                @sartoric
                Thanks for reply but I doubt that’s the case. I’ve read mentioned thread before - my settings are as suggested, did my battery calibration just 2 weeks ago and in general the battery life is fine.
                Only when solar charging gets involved, suddenly I start setting significant drops in battery %.
                In example today I spent most of the day outdoors, used the watch for swimming that lasted 20 mins max and day was really sunny. My watch started the day with 49% and swimming took 1, maybe 2%. For the rest of the day the battery was dropping down quickly and currently is at 41%. It seemed like the quickest drops were when watch was only partially charging those charges were interrupted.
                sartoricS Mff73M 2 Replies Last reply Reply Quote 0
                • sartoricS Offline
                  @Wojciech-Łużniak
                  That’s exactly what happens with battery drain. It’s not solar, it’s very probably due to GPS, or maybe solar but causes are not 100% identified
                  Did you soft reset the watch before ?
                  SVTS - 2.50.28
                  Wojciech ŁużniakW 1 Reply Last reply Reply Quote 0
                  • Mff73M Offline
                    Mff73 @Wojciech Łużniak
                    @Wojciech-Łużniak
                    https://forum.suunto.com/post/152083
                    SSU (retired), SV1, SV2
                    Wife : S9PP
                    SA: Always the latest beta :)
                    Android + Galaxy S205G
                      @sartoric said in solar charging:
                      @Wojciech-Łużniak
                      In the end, I get it 😉. you’re correct. The drain continued today, without any particular reason.
                      I’ve connected watch to charger and for the last 10 mins it remains at 30%.
                      I did the soft reset in the past, also when calibrating the battery.
                      Thanks guys for help, I’ll wait for the fix 🙂
                      Register Login
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
