    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    solar charging
    Scheduled Pinned Locked Moved Suunto Vertical
    129 Posts 35 Posters 43.1k Views 35 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • M Offline
      mikeorbreak @freeheeler
      @freeheeler said in solar charging:
      @DMytro
      @Egika once explained it well to me in a pm… I stopped worrying that moment 😉 👍
      Do you want to tell us? With permission of @Egika of course…
      freeheelerF 1 Reply Last reply Reply Quote 1
      • freeheelerF Offline
        freeheeler @mikeorbreak
        @mikeorbreak
        as said before, long story short (what I recall): don’t worry, it takes long for watches to reach charging cycles 🙂
        living sideways
        • surfboomerangS Offline
          surfboomerang
          The solar widget confuses me a little bit.
          I had an office day on Friday with probably 1 hour of sun that day. On Saturday I had a 3 hour windsurf session with probably 5 hours of sun, but the graph doesn’t seem to show that.
          Suunto Vertical Titanium Solar
          OnePlus Nord 4
          W D 2 Replies Last reply Reply Quote 0
          • W Offline
            wotus Bronze Member @surfboomerang
            @surfboomerang Could it be that the graph shows the relative energy balance, on Saturday the collected and consumed energy during windsurfing were almost equal, but on Friday more energy was collected than consumed?
            surfboomerangS 1 Reply Last reply Reply Quote 0
            • V Offline
              vlado
              I left it this morning on clear sun for some 3 hours, battery was at 14% at the begining and after those 3 hours it was still on 14%, it did not raise…but that was 8 hours ago and it is still on 14. My question is…when it is being solar charged does the percentage raise or it just stays on that initial percentage for a lot longer than when it did not had solar charge?
              Suunto Ocean
              Suunto Vertical Solar Canyon
              Suunto Ambit 3 peak Sapphire
              surfboomerangS valdis830V 2 Replies Last reply Reply Quote 1
              • SuperFlo75S Online
                SuperFlo75 Silver Members Bronze Member
                The last two days I could test the solar charging… after a long period of raining we had a slighty cloudy sky with periods of sun 🤩 I noticed the the force of the solar charging is very very depending of the direction or the angle of the incoming sun… but I don‘t want to change the watch from the left to the right wrist when I change the direction of my activity… 🤣
                Suunto Vertical 2 Titanium Sage
                Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
                Suunto Wing
                Suunto 9 Peak Pro Titanium (owns my wife now)
                Suunto Spartan Ultra
                SA iOS 3.9.0 (22101)
                Instagram @superflo75
                sartoricS 1 Reply Last reply Reply Quote 0
                • sartoricS Offline
                  sartoric Moderator @SuperFlo75
                  @SuperFlo75 said in solar charging:
                  Well, that’s actually how solar panel works, unfortunately
                  SVTS - 2.50.28
                  SSSWHR BARO Amber - 2.8.32
                  Samsung A5 2016 - Android 7.0
                  Suunto App Android 6.10.7 beta
                  • D Offline
                    deserthike20 Bronze Member @surfboomerang
                    @surfboomerang I’m seeing similar behavior on the weekly solar chart as well. It doesn’t seem to be displaying the info correctly.
                    Suunto 9 Peak Pro
                    Suunto Vertical
                      surfboomerang @wotus
                      @wotus would definitely be a nice idea, but then I would suspect negative values since I ended up with a lower battery percentage at the end of the day.
                      OnePlus Nord 4
                        surfboomerang @vlado
                        @vlado it does raise, but you need a lot of sun and patience.
                        OnePlus Nord 4
                        • C Offline
                          craigeggleton Bronze Member @Dimitrios Kanellopoulos
                          @Dimitrios-Kanellopoulos left mine in direct sunlight for 30 minutes (off wrist), screen went black, and zero charging.
                          surfboomerangS MiniForkliftM 2 Replies Last reply Reply Quote 0
                            surfboomerang @craigeggleton
                            @craigeggleton it took me around 50 minutes for 1%. So normally 4-5 full solar bars
                            OnePlus Nord 4
                            TieutieuT 1 Reply Last reply Reply Quote 2
                            • MiniForkliftM Offline
                              MiniForklift Platinum Member @craigeggleton
                              @craigeggleton said in solar charging:
                              The screen will go blank if the watch isn’t being moved, but it will still be charging. IIRC the solar functioning is actually better once the watchface has gone off
                              SV Titanium Solar Forest
                              • TieutieuT Offline
                                Tieutieu Platinum Member @surfboomerang
                                @surfboomerang today tried during a car travel.
                                With this amount, I didn’t won any single % of battery. Still have to experiment…maybe amount of sun behind glasses was not as strong as direct sun. 😧 IMG_5163.jpeg
                                Suunto’s devices at home :
                                Vertical titanium solar
                                Suunto Race S
                                S9pp titanium sand
                                Suunto Wing & Spark
                                S9B titanium Ambassador edition, A3P, X6
                                surfboomerangS M 2 Replies Last reply Reply Quote 0
                                  surfboomerang @Tieutieu
                                  @Tieutieu No, the amount of sunlight in the car is way less than outside. When I wrote 4-5 bars, I meant totally full bars. I was outside and the watch was facing the sun.
                                  Also, if I understood correctly, the bars are only showing 50000 lux and the watch is capable of collecting more than that. So it could be that in my test the watch was receiving way more light than a full bar.
                                  OnePlus Nord 4
                                  TieutieuT 1 Reply Last reply Reply Quote 1
                                  • TieutieuT Offline
                                    @surfboomerang thanks for explanations ! It Confirms I need more time (more sun !!) to have decent results. I have a long race to come next weekend, it will be a good test !
                                    My only concern is that I my skin turns usually very quickly to full red when there is a bright sun !! 😆
                                    Suunto Race S
                                    S9pp titanium sand
                                    Suunto Wing & Spark
                                      freeheeler @Tieutieu
                                      @Tieutieu
                                      …the solar charging bar can be dual use… when one bar is full it’s time to think about putting on sunscreen 😉
                                      living sideways
                                      isaziI 1 Reply Last reply Reply Quote 4
                                      • aroo7A Offline
                                        aroo7 Bronze Member
                                        Is it known what exactly the stripes on the viewer represent? Suunto only reports light output in lux (or I didn’t read something) but that’s not information on how much of that energy we gained.
                                        A cool addition, by the way would be a statistic info in the solar widget showing how much energy we gained from the solar panel during the day and the whole week
                                        L 1 Reply Last reply Reply Quote 3
                                        • L Offline
                                          Likarnik Gold Members @aroo7
                                          @aroo7 And graph in SA like steps/calories
                                          • isaziI Offline
                                            isazi Moderator @freeheeler
                                            @freeheeler I know that if the battery of my Vertical solar starts going up I need to apply suncreen more than once. Happened to me twice.
                                            Blog: isazi's home
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
