    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical is here
    Scheduled Pinned Locked Moved Suunto Vertical
    1.2k Posts 139 Posters 645.6k Views 122 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • TieutieuT Offline
      Tieutieu Platinum Member
      Last full charge 8 days ago…since then been wearing it h24 with hr and sleep tracking, doing 34 hours of exercice with gps to best, with Maps almost all the Time.
      Still 31% battery left and I just had the message « are you training soon ? Don’t Forget to charge your watch »…
      I think Suunto can change the algorithm and provide the alert when you only have 5% left !! 😄 😄
      Suunto’s devices at home :
      Vertical titanium solar
      Suunto Race S
      S9pp titanium sand
      Suunto Wing & Spark
      S9B titanium Ambassador edition, A3P, X6
      1 Reply Last reply Reply Quote 7
      • MiniForkliftM Offline
        MiniForklift Platinum Member
        Yep, battery is incredible alright! I don’t have the daily HR or phone notifications on but I do use the sleep tracking, I’m 11 days out from a full charge now, I’ve done about 12hrs of training with GPS set to the best settings and quite a bit of map usage… still at 58% 😎
        SV Titanium Solar Forest
        1 Reply Last reply Reply Quote 3
        • SuperFlo75S Offline
          SuperFlo75 Silver Members Bronze Member
          Dose anybody know when all colors of the new athletic wrist band will be available? Actually it changes daily… and I never saw the dark ruby one to buy…
          Suunto Vertical 2 Titanium Sage
          Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
          Suunto Wing
          Suunto 9 Peak Pro Titanium (owns my wife now)
          Suunto Spartan Ultra
          SA iOS 3.12.0 (22937)
          Instagram @superflo75
          • ? Offline
            A Former User
            A+ for GPS accuracy
            1 Reply Last reply Reply Quote 17
            • B Offline
              bnorthrop @Brad_Olwin
              @Brad_Olwin said in Suunto Vertical is here:
              @Jole13 Force quit the app and restart, it should be ok, I have not had mine perpetually attempt to load the AGPS file.
              I’ve been having the same problem with my Suunto Vertical. I’ve had it for five days and connected to the Suunto app on my phone running iOS several times successfully. Workout files transfer, resources transfer, sleep data transfers, etc. and the “optimizing GPS” part of the sync finishes as well. However, the weather widget has always not worked at all, it simply continues to say “Sync with Suunto app to see weather data”
              Any suggestions? Jole13, were you able to get the weather widget to work for you? Thanks!
              D J 2 Replies Last reply Reply Quote 0
              • D Offline
                deserthike20 Bronze Member @bnorthrop
                @bnorthrop The weather widget need access to the location from your phone. Can you double check that you gave Suunto access to that?
                In iOS itself (not the Suunto app) select Settings, scroll down to your apps and select Suunto then at the top allow Suunto access to your location and select Always.
                That should be it, you might need to sync once but after that it should work and update on its own.
                Suunto 9 Peak Pro
                Suunto Vertical
                B 1 Reply Last reply Reply Quote 1
                • B Offline
                  bnorthrop @deserthike20
                  @deserthike20 perfect - thank you!
                  TieutieuT 1 Reply Last reply Reply Quote 1
                  • TieutieuT Offline
                    Tieutieu Platinum Member @bnorthrop
                    Does someone knows if with a personnal sport mode with gps to best, GPS accuracy automatically switches to a less precise mode when battery gets under a certain level ? I didn’t had any advertisment from the watch (or didn’t saw it) and I’am at 4%. Gps track from the run I just finished his really good so I couldn’t tell if it was recording in best precision, or less.
                    Just noticed that I started with 5% and finished at 4% (1 hour run, maps diplayed, no app).
                    Thanks !
                    Suunto Race S
                    S9pp titanium sand
                    Suunto Wing & Spark
                    isaziI 1 Reply Last reply Reply Quote 0
                    • isaziI Offline
                      isazi Moderator @Tieutieu
                      @Tieutieu it does not change battery mode without telling you. Only at 1% it will go to power saving mode on its own.
                      Blog: isazi's home
                      TieutieuT 2 Replies Last reply Reply Quote 2
                      • TieutieuT Offline
                        Tieutieu Platinum Member @isazi
                        @isazi Ok thanks !
                        Suunto Race S
                        S9pp titanium sand
                        Suunto Wing & Spark
                        • TieutieuT Offline
                          @isazi said in Suunto Vertical is here:
                          Actually it switched to power saving mode tonight when 2% where remaining.
                          I finally succeded to drain battery to 0% !
                          Here are the final results of my first whole battery cycle (I had a “small” one before a big race).
                          Last full charge 13 days ago.
                          H24 HR and sleep tracking on, no notifications, turn to raise to low. Backlight to low.
                          39,50 hours of activities with GPS to best for all, maps almost always on. Few apps used. Few sun received (my skin commands me to seek for shadow…).
                          Activities : Trail running, hikking, climbing, cycling and moutainbiking, cardio-training…achieved around 300km, 10000meters D+ in various and demanding terrain.
                          • I estimate daily consumption to 1,5% to 2% max. So around 20/25% for 13 days. That means almost 40hours of activities for about 80/75% battery used in exercice.
                          • Even if I mostly use chest strap, the OHR battery consumption is very low compare to my S9B. Almost same consumption as with chest strap.
                          Perhaps few people haven’t set properly the watch or may use functions combinations that lead to bugs or extra battery consumption…
                          But my point of view is that this is a really fu**** awesome device for all my adventures !!
                          Suunto Race S
                          S9pp titanium sand
                          Suunto Wing & Spark
                          1 Reply Last reply Reply Quote 16
                          • TieutieuT Offline
                            Hehe…nice new survey about maps with vertical when opening SA…some cool things may come, considering the questions asked (at last, I would say it gives indications about hardware capacities of the watch 🙂 😊
                            Suunto Race S
                            S9pp titanium sand
                            Suunto Wing & Spark
                            DMytroD surfboomerangS 2 Replies Last reply Reply Quote 3
                            • DMytroD Offline
                              DMytro @Tieutieu
                              @Tieutieu can you share a summary/screenshots for those who don’t have the vertical?
                              • surfboomerangS Offline
                                surfboomerang @Tieutieu
                                @Tieutieu No survey here 😢
                                Suunto Vertical Titanium Solar
                                OnePlus Nord 4
                                TieutieuT 1 Reply Last reply Reply Quote 0
                                • TieutieuT Offline
                                  Tieutieu Platinum Member @surfboomerang
                                  @surfboomerang it appeared when I finished synchronising last activity.
                                  Suunto Race S
                                  S9pp titanium sand
                                  Suunto Wing & Spark
                                  DMytroD surfboomerangS 2 Replies Last reply Reply Quote 2
                                  • DMytroD Offline
                                    DMytro @Tieutieu
                                    @Tieutieu very nice survey indeed.
                                      @Tieutieu
                                      Check
                                      • Data field(s) on map
                                      • Marine maps
                                      • Auto zoom
                                      • re-routing
                                      Oh nevermind…
                                      • Something else - please specify: I want it ALL ! 😄 😄
                                      OnePlus Nord 4
                                      1 Reply Last reply Reply Quote 4
                                      • J Offline
                                        Jole13 @bnorthrop
                                        @bnorthrop delete and reinstall the app. Worked for me.
                                        • Hexa62H Offline
                                          Hexa62
                                          After almost 3 weeks with non solar vertical, outdoor activities such as climbing, walking, running, cycling, even pool swimming, I‘m really impressed with the accuracy of GPS recording (better than apple watch ultra!!!). Only thing remaining is open water swimming, which will start next week in still cool baltic waters. However, one annoying thing is that theres no way that screen gets dark during night (at least, I haven‘t found it). Would be nice if this could get implemented in one of the updates that one could chose a dark mode during sleep time.
                                          isaziI mikekoski490M 2 Replies Last reply Reply Quote 0
                                          • isaziI Offline
                                            isazi Moderator @Hexa62
                                            @Hexa62 OWS improvements are being worked on by Sony, and the hotfix will already include a GPS firmware that is better at handling signal loss (but not OWS specific). As for the night, if you enable “do not disturb” the watch does not have backlight active.
                                            Blog: isazi's home
                                            helgonet12H 1 Reply Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
