    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Strava segments will be disabled temporary
    Scheduled Pinned Locked Moved Watches
    31 Posts 16 Posters 6.8k Views 17 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • isaziI Offline
      isazi Moderator @GuillaumeF
      @GuillaumeF it should be real soon.
      Blog: isazi's home
      • v.sacreV Offline
        v.sacre Silver Members
        https://www.suunto.com/en-be/sports/News-Articles-container-page/chase-strava-segments-with-suunto/
        Following this procedure makes now Strava Live segment (both running and cycling) syncing well on my Suunto App šŸ¤™
        Will go for a run to test today or tomorrow
        A3S | S9B | S9P | S9PP | SV1 Ti | SV2 Ti
        Suunto Wing
        Suunto App: Android Beta
        • J Offline
          Janne Leppamaki Bronze Member
          Tested with S9PP / running and worked fine šŸ‘
          • MiniForkliftM Offline
            MiniForklift Platinum Member @Dimitrios Kanellopoulos
            @Dimitrios-Kanellopoulos said in Strava segments will be disabled temporary:
            @trailcafe check your guides. I think you need to have a fieldtest account or be an official reviewer to have that feature.
            I’d actually quite like that, what’s the process to apply or at least be considered? Thanks in advance
            SV Titanium Solar Forest
            • MdzOttM Offline
              MdzOtt
              I am trying to get the Strava segments showing up in the watch and have no success.
              I loaded the beta (pre-release) f/w to the watch and for a brief moment, the starred segment (only one) showed up in the SA. But it never loaded into the watch.
              I disconnected the Strava account, went through the problems of reconnecting, connected back, and… nothing.
              I dropped all starred segments in Strava, restarred a few, disconnected and connected back to Strava, and still nothing.
              Is there some secret handshake needed to get it going? Do I need to load some additional guide or app?
              The instructions on Suunto site are pretty simple and straightforward. I must be missing some step.
              Any advice?
              R2
              S9 Baro
              SA on Android
              Ambit 3 Peak
              Ambit 2 Sapphire
              VylliV M 2 Replies Last reply Reply Quote 0
              • VylliV Offline
                Vylli Bronze Member @MdzOtt
                @MdzOtt I have tried everything I can think of but no luck with my S9B. Live segments work fine on my wives vertical though.
                • isaziI isazi unpinned this topic on
                • isaziI Offline
                  isazi Moderator
                  The segments have been officially announced by Strava too.
                  Blog: isazi's home
                  MdzOttM 1 Reply Last reply Reply Quote 1
                  • MdzOttM Offline
                    MdzOtt @isazi
                    @isazi I noticed and the S9B is included. But no segments come across from Strava.
                    update: i disconnected from Strava, removed all routes, and connected back. The routes came across fine, but still no segments.
                    update2: i got it working, eventually. I disabled all starred segments in Strava, disconnected Strava in Partner services, uninstalled the SA, rebooted the phone, installed SA again, reconnected to Strava, re-starred a few segments in Strava. After a few minutes, they showed in SA. An extra sync and they now show on the watch. I am not saying that all these steps are required, but that after all these steps it started to work.
                    @Vylli it is worth the try. Most of the configuration is kept in the watch (usually, we complain about it), so there is not that much you need to do after the reinstallation. Of course, you need to pair the watch again and set up notifications.
                    R2
                    S9 Baro
                    SA on Android
                    Ambit 3 Peak
                    Ambit 2 Sapphire
                    • MdzOttM Offline
                      MdzOtt
                      At long last, I managed to put in an activity with the Strava segments on. I use S9B. You have to remember to include it as a ā€œGuideā€ every time you start a new activity. The first time I tried, the watch crashed completely (rebooted). Fortunately, it happened almost immediately, so I lost some 300 m of the ride. Interestingly, not all my ā€œstarred segmentsā€ came across. When riding, the watch reminds you that there is a Strava segment nearby and gives you a distance count (metres, in my case). When you enter the segment, the watch displays 3 fields: your delta to the PR (I assume), distance to the end, and your time. I am not sure if you have to switch to the extra page (watch face) to see those or if it would come automatically. On the first segment i intentionally scrolled to the end to see it and it worked.
                      I was planning to check if it would come on its own, but the next segment never popped up. Unfortunately, the numbers are smallish (the same size as if it was a 5 field face, but there are only three fields). I did not notice any indication that the segment started and or finished. I wish there was a noticeable sound signal indicating the start and end of the segment. If you ride and keep the watch on your arm, you will have a hard time seeing the data. I like the idea, but it is a bit hit and miss, for the time being.
                      R2
                      S9 Baro
                      SA on Android
                      Ambit 3 Peak
                      Ambit 2 Sapphire
                      • M Offline
                        Mi_chael Bronze Member @MdzOtt
                        @MdzOtt said in Strava segments will be disabled temporary:
                        Any advice?
                        It works for me….
                        Don’t forget to have a Strava premium account.
                        šŸ˜‰
                        MdzOttM 1 Reply Last reply Reply Quote 0
                        • MdzOttM Offline
                          MdzOtt @Mi_chael
                          @Mi_chael see my reply a few entries above. I managed to get it going, eventually. And yes, I knew that you have to have the premium account with Strava.
                          R2
                          S9 Baro
                          SA on Android
                          Ambit 3 Peak
                          Ambit 2 Sapphire
                          With your input, this post could be even better šŸ’—
                          Register Login
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
