    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Plus apps
    Scheduled Pinned Locked Moved SuuntoPlus™ Sports Apps
    172 Posts 41 Posters 56.7k Views 35 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Łukasz SzmigielŁ Offline
      Łukasz Szmigiel @DMytro
      @DMytro I wonder if it’s possible for S+ app to steal the focus if it’s not currently displayed? If not, only vibration and / or sound would be possible.
      S9PP 2.50.28
      DMytroD 1 Reply Last reply Reply Quote 1
      • DMytroD Offline
        DMytro @Łukasz Szmigiel
        @Łukasz-Szmigiel that’s another thing I’d like suunto to implement actually. Some s+ apps would benefit from that imo
        • HighlandsH Offline
          Highlands
          I wonder if the fat burner app and aerobic decoupling can’t be combined into one app and changing screens. And of course, a HR gauge rainbow at the top?
          • DMytroD Offline
            DMytro @Highlands
            @Highlands a bit different functionality tho, no? E.g. I want to go hiking, I don’t care about decoupling, especially in challenging terrain, while I could (personally I don’t) care about calories.
            HighlandsH 1 Reply Last reply Reply Quote 1
              Highlands @DMytro
              @DMytro Aerobic decoupling doesn’t work for hiking? I haven’t used it so far in hiking because I use the two slots for other apps.
              DMytroD 1 Reply Last reply Reply Quote -1
              • DMytroD Offline
                DMytro @Highlands
                @Highlands technically it does, but it wouldn’t make too much sense I think? Bc when you ascend and descend, HR can be very different, speed as well. Likewise if there’s some scrambling/via ferrata - so it’s too difficult to draw any conclusions from decoupling.
                HighlandsH 1 Reply Last reply Reply Quote 2
                  Highlands @DMytro
                  @DMytro Then, I think for faster hiking or trail running must be OK?
                  isaziI 1 Reply Last reply Reply Quote 0
                  • isaziI Offline
                    isazi Moderator @Highlands
                    @Highlands aerobic decoupling makes sense only if all segments are the same. If there are differences that affect pace/HR then it is broken, because the difference that you may see in the decoupling will be caused by external factors and not pace/HR.
                    Blog: isazi's home
                    HighlandsH Łukasz SzmigielŁ 2 Replies Last reply Reply Quote 2
                      Highlands @isazi
                      @isazi Got it. Thanks 🙏
                      C 1 Reply Last reply Reply Quote 0
                      • C Offline
                        Croatoan @Highlands
                        What do you guys use for biking (no power meter)
                        Burner is ok but if there are no climbs, I dont know what to activate. Maybe weather but that can be mostly achived in the backgound.
                        freeheelerF EgikaE 2 Replies Last reply Reply Quote -1
                        • freeheelerF Offline
                          freeheeler @Croatoan
                          @Croatoan
                          I use HR zones frequently
                          living sideways
                          • EgikaE Offline
                            Egika Platinum Member @Croatoan
                            @Croatoan nothing. No need to activate an S+ all the time 😉
                            1 Reply Last reply Reply Quote 5
                              Łukasz Szmigiel @isazi
                              @isazi Hm, why not filter the asc/desc segments in decoupling? Wouldn’t it help in getting the app more useful?
                              S9PP 2.50.28
                              • isaziI Offline
                                isazi Moderator @Łukasz Szmigiel
                                @Łukasz-Szmigiel no, decoupling makes sense if the course is the same, always, there is no need to use it if you know that your course is changing continuously. Decoupling can be used to test your aerobic capacity, but tests require discipline and planning.
                                Blog: isazi's home
                                Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 3
                                  @isazi so basically that would require a treadmil or a raceway. Even changing ground or wind can skew the results.
                                  S9PP 2.50.28
                                  • isaziI Offline
                                    @Łukasz-Szmigiel I usually do the tests (aerobic/anaerobic) doing loops in a park, always the same park, so that terrain is similar. Of course I am not the same every day, nor is the weather, but it is a good approximation. Your idea of filtering data would not work because the effect of terrain on your body would still be measured.
                                    Example: your route is flat, then climbs, then descends, than is flat again. If we filter ascent and descent, in the last flat section we will still feel in the body the fatigue of the previous ascent descent, possibly have a higher HR and skewing the results.
                                    Blog: isazi's home
                                    MdzOttM 1 Reply Last reply Reply Quote 2
                                    • flucaF Offline
                                      fluca Silver Members @DMytro
                                      @DMytro I tried, but no luck atm
                                      • MdzOttM Offline
                                        MdzOtt @isazi
                                        @isazi if we are talking about decoupling a very basic question: do you need a power meter for cycling, or the app can calculate the power (effort) based on the HR, speed, cadence(?)?
                                        R2
                                        S9 Baro
                                        SA on Android
                                        Ambit 3 Peak
                                        Ambit 2 Sapphire
                                        • isaziI Offline
                                          isazi Moderator @MdzOtt
                                          @MdzOtt I think the app is based on pace and only works for running, but never checked.
                                          Blog: isazi's home
                                          • ? Offline
                                            A Former User @isazi
                                            @isazi Theoretically, it’s also available for cycling (see app description), but it doesn’t work.
                                            isaziI 1 Reply Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
