    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Plus apps
    Scheduled Pinned Locked Moved SuuntoPlus™ Sports Apps
    172 Posts 41 Posters 55.5k Views 35 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • DMytroD Offline
      DMytro
      I intend this post to gather feedback for existing apps rather than suggestions for the new ones.
      Regarding active look app: That’s impressive functionality, but I hope that with time this can be implemented without the use of s+, since the screen itself is almost empty and this a waste of an s+ app. Still I’m glad that this functionality is present for.those who need it.
      EgikaE flucaF 2 Replies Last reply Reply Quote 1
      • EgikaE Offline
        Egika Platinum Member @DMytro
        @DMytro Suunto is working on being able to use multiple S+ features at the same time.
        This will most likely only come to S9PP, as older models are at their memory limit…
        DMytroD 1 Reply Last reply Reply Quote 5
        • DMytroD Offline
          DMytro @Egika
          @Egika but don’t you think that pairing active look is more appropriate to be done similar to an external sensor/POD rather than using a workout screen?
          I view this style more as an intermittent step to bring the feature out asap and then to try and embed it into HW more seamlessly. Similar to how klimat, relive, intervals.icu were implemented and then SA has gotten a similar suit of features.
          I also think that things like active look pairing might be improved depending on how many users will actually take advantage of this feature.
          In any case, just wanted to leave my feedback:)
          pavel.samokhaP 1 Reply Last reply Reply Quote 0
          • pavel.samokhaP Offline
            pavel.samokha @DMytro
            @DMytro except sensor/PODs are usually things using standard protocol, while ActiveLook or other upcoming third-party devices are having their own “protocols”, so you can’t implement it once and fully support for any vendor, but rather need support specific vendor device.
            I’d think about SuuntoPlus Device Sports App like a “device driver”, which you need to install and use on your desktop OS.
            And FW space is also limited, so we can’t put “drivers” for all possible third-party vendors to the FW, but rather make it possible for specific user to install and select only those he needs.
            Opinions expressed are solely my own and do not express the views or opinions of my employer
            • DMytroD Offline
              DMytro @pavel.samokha
              @pavel-samokha makes sense, thanks!
              In that case wouldn’t it be better to have another menu in SA like ‘external devices’ where user can choose to send up to, say 3, drivers to the watch s.t. an extra exercise screen isn’t used up, s+ capacity isn’t used up?
              Or does the information broadcasting strain the watch too much that it’s indeed comparable to have some other dynamical s+ screens (intuitively, I would say s+ safe, ghost runner and guides probably pull more resources than smth like hydration remainder).
                @DMytro S+ memory capacity is not only about UI shown, but also about actual code running in the background and there are other moving parts. Just to say that 1 S+ app/guide limitation is known issue, but it’s more complex work than could be seen externally.
                DMytroD 1 Reply Last reply Reply Quote 4
                • DMytroD Offline
                  @pavel-samokha I get that and if having an external device connected + running an s+ is too much - that’s fine. What I find a little esthetically displeasing is that active look adds an almost useless screen that one would have to scroll through every time and I wonder is something could be done about it.
                  But than again, it’s not that I’m going to use activelook anytime soon, was just trying to share my perspective on the matter.
                  pavel.samokhaP 1 Reply Last reply Reply Quote 1
                    @DMytro I got you and agree that may be option to hide the screen could make sense
                    • inkognitoI Offline
                      inkognito Platinum Member
                      So, regarding the new SuuntoPlus apps, I really wonder: would it be possible to merge Sun and Moon apps into one Sun/Moon app where one would be able to manually switch between Sun and Moon with the lap button?
                      SV: fingers crossed :D
                      S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
                      Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
                      Despite some pretty bad luck, I still love Suunto!
                      Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 6
                      • Łukasz SzmigielŁ Online
                        Łukasz Szmigiel @inkognito
                        @inkognito this is a great idea. I’m also wondering if it would be possible to use less memory intense S+ apps together. Like Weather and Sun / Moon? I assume a combo of those would be nice for bushcraft, trails, etc.
                        S9PP 2.50.28
                        inkognitoI 1 Reply Last reply Reply Quote 5
                          inkognito Platinum Member @Łukasz Szmigiel
                          @Łukasz-Szmigiel Sounds cool! Just don’t forget that guys without barometer (S9 non-baro, S5, S5P) cannot use Weather 🙂
                          Anyway, now I even think that the coolest solution would be to implement Sun/Moon related information somewhere to the Navigaton menu accesible during any exercise with GPS… No need to waste SuuntoPlus functionality on this simple one-time on-demand calculation…
                          • isaziI Offline
                            isazi Moderator
                            A nice new feature regarding the S+ apps will come with next firmware update, and I believe you will all like it.
                            Blog: isazi's home
                            DMytroD tazidenT 3 Replies Last reply Reply Quote 14
                            • DMytroD Offline
                              DMytro @isazi
                              @isazi activating s+ mid-activity?
                              1 Reply Last reply Reply Quote 3
                              • tazidenT Offline
                                taziden Gold Members @isazi
                                @isazi said in Suunto Plus apps:
                                Do you mean we’ll run faster with next firmware ?!
                                S9PP
                                isaziI H 2 Replies Last reply Reply Quote 6
                                • isaziI Offline
                                  isazi Moderator @taziden
                                  @taziden Kipchoge has no chance 😄
                                  Blog: isazi's home
                                  D 1 Reply Last reply Reply Quote 2
                                  • H Offline
                                    halajos Bronze Member @taziden
                                    @taziden for all watches with S+ support? 🙂
                                    EgikaE 1 Reply Last reply Reply Quote 2
                                    • EgikaE Offline
                                      Egika Platinum Member @halajos
                                      @halajos yep
                                      inkognitoI 1 Reply Last reply Reply Quote 3
                                        inkognito Platinum Member @Egika
                                        @Egika In March? 😆
                                        • D Offline
                                          dulko79 @isazi
                                          @isazi s+ app “make me faster” would be no 1 in the store 😁
                                          App: beta
                                          Phone: Iphone
                                          iOS
                                          • tazidenT Offline
                                            Ability to use both Guide and App (such as Manual Intervals) simultaneously would be great.
                                            S9PP
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
