    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    NO GOOD DATA ASCENT (AND DESCENT)
    baro ascent problem
    37 Posts 7 Posters 4.9k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Matteo ZambenedettiM Offline
      Matteo Zambenedetti
      Re: GPS altitude meter
      Hi everyone, I have a 9 Baro and a problem with measuring the ascent (and descent). The difference with the real one is around 15%, what is the solution?
      freeheelerF isaziI 2 Replies Last reply Reply Quote 0
      • freeheelerF Offline
        freeheeler @Matteo Zambenedetti
        @matteo-zambenedetti
        could be several reasons… it’s in-depth discussed in here already 😉
        check if the graph recorded has unrealistic spikes (down and up again). if so: the baro holes were covered.
        other reasons could be dirty sensor, manual calibration before the activity or wind gusts during stormy weather.
        we’ll find out if you share the graph or the link to your activity with us 👍
        living sideways
        • isaziI Offline
          isazi Moderator @Matteo Zambenedetti
          @matteo-zambenedetti we need to look at the route before anyone can answer 🙂
          Blog: isazi's home
          Matteo ZambenedettiM 1 Reply Last reply Reply Quote 1
            Matteo Zambenedetti @isazi
            @isazi I try to senso It. Hiking_2022-06-19T02_32_03.fit
            isaziI 1 Reply Last reply Reply Quote 1
            • isaziI Offline
              @matteo-zambenedetti also, does it measure more or less than you expect?
              Blog: isazi's home
              Matteo ZambenedettiM 1 Reply Last reply Reply Quote 0
                @isazi much more. In this track the real ascent is about 1500 MT, 9 Baro says about 3000 MT…this morning, real about 500, 9 Baro about 650
                freeheelerF 1 Reply Last reply Reply Quote 0
                  and the graph doesn’t match the topographie of the recorded track if I’m not completely wrong. but it doesn’t exactly look like the sensor was covered.
                  did you calibrate the altitude manually just before the activity?
                  living sideways
                    Matteo Zambenedetti @freeheeler
                    @freeheeler yes, both times. Do I have to reset It?
                      no… next time: don’t touch it 🙂 if alti is completely wrong, just start your activity. FusedAlti will calibrate it for you and will do it also throughout the activity when it compares to gps alti and detects it’s shifting
                      living sideways
                        @freeheeler OK I will do. A question: Does Fusedalti start automatically when I start my Activity?
                        • isaziI Offline
                          @matteo-zambenedetti yes, during the first 15 minutes.
                          Blog: isazi's home
                            Matteo Zambenedetti
                            Good morning everyone,
                            I return to the subject to post some files to better explain my problem.
                            First of all, I don’t understand why SUUNTO does not provide software for pc but only apps for android (or mac) …
                            So, this is the screenshot of my hike according to the data of my 9 Baro and the app Suunto Screenshot_Suunto.jpg in my phone
                            ASCENT 3168MT!!! UNREALISTIC!!!
                            and this is the screenshot of the same track but downloaded on Openrunner softwareScreenshot Open Runner.jpg
                            ASCENT 1368MT!!! REALISTIC!!!
                            and this is the track.gpssuuntoapp-Hiking-2022-06-19T00-32-03Z-track.gpx
                            can anyone help me to understand and solve the problem?
                            what is the exact procedure to follow before starting a hike or a bike ride?
                            I apologize if I can’t answer right away but I’m working and I don’t have much time
                            ? cosme.costaC 2 Replies Last reply Reply Quote 0
                            • ? Offline
                              A Former User @Matteo Zambenedetti
                              @matteo-zambenedetti what is the problem?
                              If you start higher than 1800m, and climb till 3200…at least roughly: 3200-1800=1400.
                              You have some other climbs on the graph, but also, you start higher than1800, so I can’t understand where is the issue.
                              • cosme.costaC Offline
                                cosme.costa @Matteo Zambenedetti
                                @matteo-zambenedetti Can you also share the ascent graph in the Suunto phone app?
                                  Matteo Zambenedetti
                                  the problem that openrunnere says I climbed 1368 meters (correct) while summarized says that I climbed 3168 meters (wrong)
                                  cosme.costaC 1 Reply Last reply Reply Quote 0
                                    Matteo Zambenedetti
                                    the .gps track that posted before cannot be opened?
                                      @matteo-zambenedetti I understand that the watch says the same than the Suunto app, am I right?
                                      I want to see if the ascent graph from the watch has spikes, so it means that for some reason the baro sensor has been blocked (skin, jacket, wind,…) and for that reason you have higher ascent than expected.
                                        Matteo Zambenedetti @cosme.costa
                                        @cosme-costa I understand what you mean. I therefore report the profile of my excursion: you will notice that there are no peaks.
                                        However, if there were, Openrunner would have had to show me the same rise as Suunto. My problem is why was my 9 baro wrong?
                                        freeheelerF cosme.costaC 2 Replies Last reply Reply Quote 0
                                          because of several small spikes that I can already see without zooming in… maybe the other platform filters it by default? Strava filters by request
                                          living sideways
                                            @freeheeler Does your 9b the same?
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
