    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    GPS altitude meter
    gpsaltitudemeter
    48 Posts 8 Posters 8.6k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • MRonyM Offline
      MRony
      Hi, I’m new here. can you please tell me how much the altitude data (altitude meters) may deviate. On my last tours (training started where gps signal was found and also with iphone sync) the deviation at the summit was always greater than 10m! thank you for your help!!!
      Fenr1rF freeheelerF 2 Replies Last reply Reply Quote 0
      • Fenr1rF Offline
        Fenr1r @MRony
        @mrony Hello. Couple of extra details, please:
        Do you have the Baro version?
        How much greater than 10m? (On average)
        MRonyM 1 Reply Last reply Reply Quote 1
        • MRonyM Offline
          MRony @Fenr1r
          @fenr1r yes, i have the baro9! With the newest Update! It is between 10 and 20m!! 14m, 11m and so on! BR
          Fenr1rF 1 Reply Last reply Reply Quote 0
          • Fenr1rF Offline
            Fenr1r @MRony
            @mrony Thanks.
            Tricky. 10m altitude variance is the upper threshhold for what Suunto consider reasonable performance for the Baro version. (For the non-Baro, your experience wouldn’t really indicate a problem.)
            @Dimitrios-Kanellopoulos and others may want to weigh in on the 10-20m you are seeing.
            MRonyM 1 Reply Last reply Reply Quote 0
            • MRonyM Offline
              MRony @Fenr1r
              @fenr1r said in GPS altitude meter:
              Thanks for the answer, i will Connect Suunto! BG
              • freeheelerF Offline
                freeheeler @MRony
                @mrony
                did you set the altitude before your activity manually?
                living sideways
                • MRonyM Offline
                  MRony @freeheeler
                  @freeheeler i have Open the activity, waited for the Signal (~10min)! infront of That, i Sync the baro9 with the suunto-App! After That i Start the activity!
                  freeheelerF 1 Reply Last reply Reply Quote 0
                    freeheeler @MRony
                    @mrony
                    was your observation a one time thing or do you observe that frequently?
                    living sideways
                    • MRonyM Offline
                      MRony @freeheeler
                      @freeheeler frequently - in every activity
                        freeheeler @MRony
                        @mrony
                        honestly, I did not notice this behaviour. It could be that FusedAlti is not correcting the altitude good enough but this should be in all directions, most likely under a Gauss bell.
                        I once passed by a marked point on a hike and my watch was to the spot.
                        Honesty again: I don’t care so much about 10 or 20m. When I look at the map and know by topography plus approximate altitude where I am, I’m fine.
                        But I understand disappointment.
                        BTW changing and windy weather does challenge FusedAlti IMHO
                        living sideways
                        • MRonyM Offline
                          MRony @freeheeler
                          @freeheeler as a rule it might not matter, but if I track with the watch - it should be reasonably accurate. When I’m at the summit, the data should be correct when the sun is shining!
                          • ? Offline
                            A Former User @MRony
                            @mrony Yesterday at work I take a break and look at my current altitude and decide to update it via GPS.
                            After few minutes the watch notify me it’s ok.
                            I was at -7m … I try it 3 or 4 times it vary -5m , -6m.
                            I was close to the bigest river of France not under the sea level…
                            Like you 9baro. I really hope the next update will improve/correct this.
                            • MRonyM Offline
                              MRony @Guest
                              @g287-sf i also do!! I‘ll Tell this Theme to Suunto!
                                freeheeler @MRony
                                @mrony
                                I need to mention something before this thread gets locked due to redundancy… if I climb summits that are between 2’500-3’500m I personally do not care about 10 or 20m. But maybe it’s just me?!
                                Japanese cars by the way tend to show about 10% higher speeds.
                                living sideways
                                Fenr1rF ? 2 Replies Last reply Reply Quote 1
                                • Fenr1rF Offline
                                  Fenr1r @freeheeler
                                  @freeheeler It’s clearly far from just you but I have uses for that accuracy. And, as it doesn’t increase my hiking weight by too much, better to have it and not need it than …
                                  freeheelerF 1 Reply Last reply Reply Quote 1
                                    freeheeler @Fenr1r
                                    @fenr1r
                                    true, I don’t fancy going over a cliff because of bad weather and wrong values. That’s why I also do not rely too much on the watch.
                                    But the precision still is better than a compass, altimeter and a 50’000 map 😉
                                    living sideways
                                    • MRonyM Offline
                                      MRony @freeheeler
                                      @freeheeler 😉✌🏻
                                      • ? Offline
                                        A Former User @freeheeler
                                        @freeheeler you’re right. But maybe some people need accurate gps for other thing than sport 🤷🏻‍♂️
                                          freeheeler @Guest
                                          @g287-sf
                                          I think before we keep this discussion going we need samples from @MRony where we can see the graph and have some fix points to indicate the deviation in altitude.
                                          Location is most of the times spot on with my watch.
                                          notice where I left the sidewalk and cut the corner? (counter clockwise direction).
                                          and altitude recorded e.g. at the highest point of the ride compared to what’s stored in swiss topo maps.
                                          I think it’s close to top notch.
                                          living sideways
                                          • Fenr1rF Offline
                                            Fenr1r @freeheeler
                                            @freeheeler
                                            Preferably with simultaneous, co-located fixes from other devices with known generally superior accuracy.
                                            freeheelerF Brad_OlwinB 2 Replies Last reply Reply Quote 1
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
