    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    GPS altitude meter
    gpsaltitudemeter
    48 Posts 8 Posters 10.2k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • freeheelerF Offline
      freeheeler @Fenr1r
      @fenr1r
      not everyone can pull an A3P out of his drawer šŸ˜‰
      living sideways
      Fenr1rF MRonyM 2 Replies Last reply Reply Quote 0
      • Fenr1rF Offline
        Fenr1r @freeheeler
        @freeheeler said in GPS altitude meter:
        Ha! Good point. (Altho’, as detailed elsewhere, my A3P [FusedAlti] was outclassed by an SSU [Baro only] in a comparison a while back. So it may not be at its best.)
        However, as long as there is postal delivery and selfless dedication to the scientific method …
        It occurs to me that there is a more definitive test: against another 9Baro of known, recently-demonstrated accuracy.
        You can fall back in affection with your Airboss in the interim.
        • MRonyM Offline
          MRony @freeheeler
          @freeheeler today i was a Tour, and the gps failed~ 100m! Photo i will load up in 3houers!
          freeheelerF 1 Reply Last reply Reply Quote 1
            freeheeler @MRony
            @mrony
            let’s say, without knowing details, the altitude was wrong… not GPS failed. at least that’s what I understand from the context, it could be misleading.
            I’m curious about your details. šŸ‘
            living sideways
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @Fenr1r
              @fenr1r said in GPS altitude meter:
              @freeheeler
              we need samples from @MRony where we can see the graph and have some fix points to indicate the deviation in altitude.
              Preferably with simultaneous, co-located fixes from other devices with known generally superior accuracy.
              All that is really needed is to get a fit file and compare corrections in Runalyze
              Vector/T6c/Vertical 2 Ti
              Fenr1rF 1 Reply Last reply Reply Quote 1
              • Fenr1rF Offline
                Fenr1r @Brad_Olwin
                @brad_olwin Will that tell you the GNSS reception conditions for the route or the corrections made for a notionally optimum route?
                • MRonyM Offline
                  MRony @freeheeler
                  @freeheeler - Now I have attached the pictures IMG_5172.PNG IMG_5171.jpg -------------------------------------------- IMG_5235.PNG IMG_5237.PNG
                  • MRonyM Offline
                    MRony @freeheeler
                    freeheelerF fazelF 2 Replies Last reply Reply Quote 1
                      freeheeler @MRony
                      @mrony
                      PTE 5.0, are you running with your skis?? šŸ™Š
                      The pics are nice and the data, but it would be good if we could associate the info better.
                      @Brad_Olwin mentioned runalyze, but I don’t use that, hence, no idea about that one.
                      If you would upload to QS and share the link it would help to see if there are unregularities in the graph.
                      living sideways
                      MRonyM 1 Reply Last reply Reply Quote 0
                        freeheeler @MRony
                        @mrony
                        1. is 14m too high
                        2. 90m too low
                        3. 11m too high
                          correct?
                        living sideways
                        • MRonyM Offline
                          MRony @freeheeler
                          @freeheeler correct
                          freeheelerF 1 Reply Last reply Reply Quote 0
                            freeheeler @MRony
                            @mrony
                            personally I would only worry about the 90m low.
                            let’s look at your 90m low activity isolated in quantified-self.io
                            living sideways
                            kabziorK 1 Reply Last reply Reply Quote 0
                            • MRonyM Offline
                              MRony @freeheeler
                              @freeheeler -
                              My father-in-law - always makes sure that I work up a sweat. šŸ™‚
                              What means QS an how i do this?
                                freeheeler @MRony
                                @mrony
                                you can upload exported activities to here… or do a complete sync, publish, share… if you’re concerned about privacy make it private again after we checked
                                https://quantified-self.io/user/jBm0qOhihUMykVYD8HBJMshQrJc2/event/e5b5d4f153619dbd9d24526cf725eb736779f29171438dc1a528c43aa3135019
                                living sideways
                                • MRonyM Offline
                                  MRony @freeheeler
                                  @freeheeler i will try this tomorow - now i musst bring my kids to bed. Thanke you for your support. KR Rony
                                  • MRonyM Offline
                                    MRony @freeheeler
                                    @freeheeler Hello, I spoke to Suunto Customer Service. There I was informed that a deviation of 1-3m would be normal (would also suit me) - my deviations (values) are too high. I should reset the clock to factory settings (test again) - if that doesn’t help, i shoud send it to customer service. Info will follow! BR Rony
                                    Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                                      Dimitrios Kanellopoulos Community Manager @MRony
                                      @mrony how high are the deviations and how is the refernce defined?
                                      10meters is also ok. 20 no. only as an exception
                                      Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                                        freeheeler @Dimitrios Kanellopoulos
                                        @dimitrios-kanellopoulos
                                        @MRony has sent samples with
                                        1. 14m too high
                                        2. 90m too low
                                        3. 11m too high
                                        living sideways
                                        Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                                          Dimitrios Kanellopoulos Community Manager @freeheeler
                                          @freeheeler with a baro device ?
                                            If you want me to analyse what happend please provide a link from suunto app, the expected values and so on
                                            With your input, this post could be even better šŸ’—
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
