    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 baro is stuck on boot
    12 Posts 4 Posters 1.1k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Nikola PenevN Offline
      Nikola Penev
      Hi there,
      My watch is stuck on the arrow. Suuntolink is telleing me “Failed to reset the watch. Please check your internet connection settings”, but there is not problem, no proxy and etc…
      Any suggestions?
      10x
      • isaziI Offline
        isazi Moderator
        Try this first https://forum.suunto.com/topic/7062/arrow-pointing-down-issue
        Blog: isazi's home
        Nikola PenevN 1 Reply Last reply Reply Quote 1
          Nikola Penev @isazi
          @isazi What exacly you point? If i hold the buttons again is going to the arrow.
          The watch was with dead battery. Now i[m tryin suuntolink but when i choose to reset the watch says: Failed to reset the watch. Please check your internet connection settings
          freeheelerF 1 Reply Last reply Reply Quote 0
          • freeheelerF Offline
            freeheeler @Nikola Penev
            @nikola-penev
            did you try softreset? 12sec upper button.
            https://www.suunto.com/en-gb/Support/faq-articles/lifecycle/how-to-reset-your-suunto-watch/
            my daughter’s watch had the same issue this week. I fully charged it connected to SuuntoLink, performed an update and the world started spinning again ✊
            living sideways
            Nikola PenevN 1 Reply Last reply Reply Quote 0
              Nikola Penev @freeheeler
              @freeheeler nahh, its was from the version of windows…
              now i’m tring with win10, so the reset is starting, but its stuck on right after tthe half of the process. disconect and connect few times and error: update failed…
              any suggestion with this?
              its trying from 2.11.38 -> 2.11.38
              freeheelerF 1 Reply Last reply Reply Quote 1
                @nikola-penev
                sorry, no useful help from my side. But really skilled and experienced guys in here will help you out, just wait until they pickup the topic ✊
                living sideways
                  Nikola Penev
                  it seems i dont have the gear icon in suuntolink 4.0.4. Can someone share older version ?
                  BulkanB isaziI 2 Replies Last reply Reply Quote 0
                  • BulkanB Offline
                    Bulkan Moderator @Nikola Penev
                    @nikola-penev do you have another cable? Maybe is the cable.
                    If soft reset didn’t work and suuntolink is not working I suggest to try another port in the pc.
                    I don’t know if older version of suuntolink will help.
                    Try the softreset one more time and give a try on suuntolink just in case.
                    Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
                      Nikola Penev @Bulkan
                      @bulkan I have another cable - same situation. Stuck right after the half of the process and Update failed.
                      • isaziI Offline
                        isazi Moderator @Nikola Penev
                        @nikola-penev said in S9 baro is stuck on boot:
                        Just drag and drop the zip file in the top corner of Suuntolink, not sure if left or right, try both.
                        Blog: isazi's home
                          Nikola Penev @isazi
                          @isazi anyway, we found a oler version. Dropped a different fw versions and always update is failing on the 9 o\clock of the process.
                          isaziI 1 Reply Last reply Reply Quote 0
                          • isaziI Offline
                            @nikola-penev if nothing suggested on the forum works, it is better if you contact support.
                            Blog: isazi's home
                            Register Login
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
