    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9B Elevation gain not working properly
    13 Posts 6 Posters 841 Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Argonaut330A Offline
      Argonaut330
      As per subject, since few weeks whenever i run the elevation gain is zero.
      I know well that this is not realistic cause i am running the same route and i know how much the gain should be.
      Is this maybe an issue linked to the baro ?? Anyway i can reset this ?
      Thanks to all
      Suunto Ocean
      Suunto 9 Baro
      TheGuyFromTheSummitT Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
      • TheGuyFromTheSummitT Offline
        TheGuyFromTheSummit Silver Members @Argonaut330
        @argo320
        You can try a soft reset,
        if this does not help, a hard reset (all data gets deleted).
        But I don’t know if this helps, those are just the reset options
          Dimitrios Kanellopoulos Community Manager @Argonaut330
          @argo320 show us the altitude chart please
          Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
          Argonaut330A 1 Reply Last reply Reply Quote 0
            Argonaut330 @Dimitrios Kanellopoulos
            @dimitrios-kanellopoulos please check 2 charts from almost identical route
            Suunto Ocean
            Suunto 9 Baro
            isaziI Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
            • isaziI Online
              isazi Moderator @Argonaut330
              @argo320 maybe it’s time to clean the baro hole with lukewarm water and a baby toothbrush. Or just leave it a hour or two in lukewarm water and rinse it afterwards.
              Blog: isazi's home
                @argo320 about the second chart it looks ok for no ascent
                Argonaut330A 1 Reply Last reply Reply Quote 1
                  @dimitrios-kanellopoulos the second chart should represent the same identical vertical ascent profile like the first above, same route, same hills… just few hundred metres less at the end… that’s the problem.
                  Looks like the baro is stuck, will try to clean it properly as suggested above and also a soft reset.
                  Will come back with outcome later.
                  Tx
                  Suunto Ocean
                  Suunto 9 Baro
                  Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                    @argo320 on the second chart you climbed 5m after many kilometers and those are not counted.
                    For ascent to count you need to climb 3m at least in 5mins or so. Then it does not count.
                    Mff73M MiniForkliftM 2 Replies Last reply Reply Quote 1
                    • Mff73M Offline
                      Mff73 @Dimitrios Kanellopoulos
                      @dimitrios-kanellopoulos said in S9B Elevation gain not working properly:
                      the issue of @Argo320 is that the chart seems not OK, so the point is not to check if ascent is calculated properly 😉 , but altitude values seems not OK : second graph should look like the first one (more altitude).
                      SSU (retired), SV1, SV2
                      Wife : S9PP
                      SA: Always the latest beta :)
                      Android + Galaxy S205G
                        Argonaut330 @Mff73
                        @mff73 exactly this !!
                        BTW i have just done a soft reset and now the baro shows the correct barometric pressure (before it was stuck at 970 hPa).
                        Will go for same run/route and check it out.
                        Thanks to all
                        Suunto Ocean
                        Suunto 9 Baro
                        1 Reply Last reply Reply Quote 3
                          Argonaut330
                          Hi All, just tested on a route i know well, and elevation looks good and accurate again, likely before for some reason the baro was stuck at 970hPa, and the soft reset did the trick.
                          Thanks to all for support,
                          Cheers
                          Suunto Ocean
                          Suunto 9 Baro
                          1 Reply Last reply Reply Quote 5
                          • MiniForkliftM Offline
                            MiniForklift Platinum Member @Dimitrios Kanellopoulos
                            Bit of a random question but do some of you have your watch ascent also increase in increments of 4m? Mine ascent mostly goes up in 3m chunks but every now and then I get a 4m increase. Just curious, thanks 👍
                            SV Titanium Solar Forest
                              Dimitrios Kanellopoulos Community Manager @MiniForklift
                              @miniforklift yes. Anything above 3m
                              Register Login
                              • First post
                                Last post
                              Suunto Terms | Privacy Policy
