    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suggestion : Put ETE (Estimated duration) instead current time in Compass Navigation to POI
    15 Posts 4 Posters 1.1k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Mister PYCM Offline
      Mister PYC Silver Members
      Looking yesteday to the navigation compass with a POI, I noticed that below the distance we can see (again tooooooo small a clock)
      What is the interrest in navigation to see which time it is now ?
      moreover almost impossible as too small ?
      to which navigation question it allow to answer => nothing
      What are the 3 fundamentals questions that someone may ask you when navigating ?
      1. do you know where we should go ? => the direction : OK we have it
      2. do you know how much we still have to walk ? => the distance : OK we have it
      3. do you know when we arrive ? … recurrent question of Shrek’s donkey friend … and here … we dont’ have it !!!
      So
      Instead the time, why not to put the ETE and … in BIG
      The timing distance to reach a point could be as important as the metric distance !!!
      Why ETE is more interresting and not ETA ?
      ETA has not real value here … what is important is to know how much time, so effort still we have to do (Ok we have it also with distance, but some time a distance does not ring a bell to some people)
      ETA without the current time has no value, it is an artificial time.
      I can tell you at 18;30 or 18;45 or 19:31 … it gives you zero indication if you do not know which time it is currently.
      You will tell me, still it is interresting if someone phones you and ask you “when are you arriving ?” … well … not much that if you reply him “approximativelly in 47 minutes … so let’s say in 1 hour”
      Last but not least, is it a problem to put this ETE very big ?
      No ?
      why ?
      because normally you should point the blue arrow in the direction to the target, so the arrow information most best location is on the top or in the top quadrant in any case
      All is possible in IT
      Driven by you fear you stay on the ground, driven by your dreams you fly
      DMytroD Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
      • DMytroD Offline
        DMytro @Mister PYC
        @mister-pyc having training time vs ETE might be helpful for fell running and orienting. Maybe it would be better to make the field configurable via SA?
        • Dimitrios KanellopoulosD Online
          Dimitrios Kanellopoulos Community Manager @Mister PYC
          @mister-pyc Eanble touch and tap on the screen. ETE/ETA and alti diff is there.
          This works also for find back etc
          Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
          Mister PYCM 1 Reply Last reply Reply Quote 4
            Addtionally if you pull up the menu from down, you have all those scrolling
            Mister PYCM 1 Reply Last reply Reply Quote 2
              Mister PYC Silver Members @Dimitrios Kanellopoulos
              @dimitrios-kanellopoulos Hop hop hop … super thanks !!!
              I test this immediately this afternoon and feedback !!!
              I will feedback this evening
                @dimitrios-kanellopoulos Hello Dimitrios, verdict … after a test done this afternoon.
                I should first apologize I may have missed to tell you an important information : I was inside an excercise when I activated the navigation to a POI, but I was not just going to navigation from the “home screen”.
                If you do so, you will realize that the compass view that shows the direction and distance, shows you only the curren time and is blocked on this … nothing change if you touch and tap on the screen. ETA/ETE and alti diif is not displayed.
                May be these feature which are availabel in bearing navigation are not reproduced when you navigate toward a POI in an exercise, so may be a suggestion for being added.
                Also, I reiterate. the secondary information (here the current time) is displayed far too small almost not readable apart if you are un perfect conditions … tomorrow I will post a photo to show you some condition in which I was using the watch 🙂 … you will see … large font is not a bonus, it should be a must have 🙂 🙂 🙂
                isaziI 1 Reply Last reply Reply Quote 0
                • isaziI Offline
                  isazi Moderator @Mister PYC
                  @mister-pyc you need to enable touch during activity with a special battery mode.
                  Blog: isazi's home
                  Mister PYCM 2 Replies Last reply Reply Quote 1
                    Mister PYC Silver Members @isazi
                    @isazi Hello Isazi good to know !!! I will search for this. THANKS !!!
                      @isazi Hello Isazi, hello @dimitrios-kanellopoulos
                      Here the feedback after testing the battery mode allowing to touch the screen.
                      First of all, EXCELLENT, this watch so in fact the guys who develop its interface are genius !!!
                      Now, still 2 proposals of improvements which by the way are now far more simplier
                      1. when you activate the LOCK, still the touch should be enabled otherwise you cannot switch anymore from ETE, ETA, battery, elevation …
                        What is the most important need of the LOCK ?
                        It is to avoid that by accident the top button will be pressed and then the exercise will get closed without you to realize it. it happen to me when I was doing some ki touring this winter and I lost the full road I was recording.
                      2. instead to change the size of the fonts, let me make an alternative proposal which I hope you will agree with me should be far more simplier … : when you tape and touch the screen, why not to inverse the information which is written as secondary (so super small) with the one written in big …
                        in fact not exactly inversing, but a rolling effect which will not only change the secondary info, but will place the current secondary info as the primary info and then will display the next info in the secondary … and so and so …
                      Doing so you have absolutely nothing to change in your screen design but just the information that you want to see as big
                      PS : do not forget to allow the touch screen even if locked. personally I systematically lock the screen during an exercise to avoid any accident. the touch & tap screen is of no risk to damage the exercise hence should not be locked.
                      DMytroD 1 Reply Last reply Reply Quote 2
                      • DMytroD Offline
                        DMytro @Mister PYC
                        @mister-pyc I think touch needs to be locked too in case you have contact with water (rain, river, etc). But 2. is a good idea.
                        Mister PYCM 1 Reply Last reply Reply Quote 1
                          Mister PYC Silver Members @DMytro
                          @dmytro Hello dmytro. thanks for point 2. I may create a special post for this so that people can vote especially for this.
                          Concerning the lock. for me the touch & tap screen should remain active even in lock situation
                          why ?
                          3 reasons for that
                          1. as it is blocked, if you want to switch and see another information , then the number of manpulations is big : longue press on below button, deactivate the lock, shift, long press on below button, reactivate the lock
                          2. it open a risky window with a potential risk of a bad action that could unfortunately result into closing accidentally the erxecise
                          3. touch & tap screen is in reverse of no risk as it is reversible, even if you tape 10 times on the screen there is no risk to damage the exercise by stopping it accidentally.
                            It happen to me to face this situation and due to that I lost totally the route I was trying to capture and I realized this when I arrived to the summit …
                          Dimitrios KanellopoulosD DMytroD 2 Replies Last reply Reply Quote 0
                            @mister-pyc
                            Press middle button. You can switch info
                            • DMytroD Offline
                              DMytro @Mister PYC
                              @mister-pyc still, if screen is wet, it starts to go crazy. Sure, activity won’t stop, but screen may change which I would like to prevent.
                              Mister PYCM 1 Reply Last reply Reply Quote 0
                                @dmytro Personnaly I observe something different … when the screen is wet, then it is becoming useless, no more reaction.
                                  @dimitrios-kanellopoulos 👍 I test this tomorrow !!!
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
